Audioengine A2+ Gen 3 Adds aptX Adaptive and More Power for $299
2026 Audioengine A2+ Gen3 Powered Desktop Speakers Colors
Audioengine has a strong presence in the compact powered speaker category, and one of its most enduring products is the A2+ Series. Labeled as a home music system, the A2+ began as the A2 Desktop Hi-Fi system in 2007, followed by the first A2+ in 2013, which added a USB DAC. The A2+ Wireless followed in 2019 with Bluetooth connectivity, followed by the A2+ Next Gen and Anniversary Editions in 2025.
Building on the success of one of its best-known products, Audioengine has unveiled the A2+ Gen 3 for 2026 with additional improvements designed to keep it relevant in today’s market.
As with its predecessors, the A2+ Gen 3 consists of two compact powered speakers. The primary speaker (left) incorporates wireless and wired source connectivity, along with the amplification required to power both speakers. The secondary speaker (right) is passive and connects to the primary speaker using standard speaker cable.
Audioengine has been a major supporter of this type of system, with the A2 and A2+ helping inspire additional high-performance compact speaker systems such as the A5+, HD3, HD4, HD5, HD6, A1-MR, and more.
audioengine-a2-plus-gen3-speakers-yellow-desktop
What’s New with A2+ Gen 3
The significant addition to the A2+ Gen 3 is the incorporation of Bluetooth 5.3 with Qualcomm aptX Adaptive Bluetooth, along with more refined USB compatibility.
“For years, the A2+ has been the product people recommend when someone asks how to get the highest-quality sound from a small desktop setup,” said Nate Rodriguez, President and CEO of Audioengine. “The A2+ Gen 3 keeps the size and simplicity people already know and love, but gives it broader Bluetooth support and better USB compatibility.”
aptX Adaptive is designed to dynamically adjust transmission based on the audio content and wireless environment. The system supports aptX Adaptive, aptX HD, aptX, AAC, and LC3. Bluetooth audio support now provides a 24-bit input through compatible aptX codecs, while the internal Qualcomm QCC3040 Bluetooth receiver handles wireless playback.
Another update Audioengine is including in the A2+ Gen 3 is the switch from Class A/B amplification to Class D, as well as an increase in power output from 15 to 20 watts per channel.
What Makes the A2+ Legacy Special
The A2+ has remained a successful part of the Audioengine lineup since its initial introduction as the A2, combining high-quality sound, straightforward connectivity, and a compact footprint without requiring apps, accounts, or a complicated setup. The A2+ Gen 3 continues that focus while introducing updated amplification and wireless connectivity to the platform.
“Technology changes, but the reason people buy an A2+ really hasn’t,” Rodriguez said. “They want their music to sound great without turning listening into a project. That continues to be the idea behind this product.”
audioengine-a2-plus-gen3-black-front-back
A2+ Gen3 keep the same exterior design, drivers, and inputs, but swaps amplification.
Comparison
Audioengine Model A2+ Gen 3 (2026)Audioengine A2+ Next Gen (2025)
Price $299$279
Product TypePowered Wireless Speaker SystemPowered Wireless Speaker System
System Configuration1 x Primary Speaker
1 x Secondary Speaker
1 x Primary Speaker
Amplifier TypeClass DDual Class AB
Power Output20W RMS per channel at 4 ohms (measured in compliance with 16 C.F.R. § 432.3)
Peak Power Output per channel 30W per channel at 4 ohms (AES)
Total Peak Power Output: 60W (AES)
15W RMS per channel at 4 ohms (measured in compliance with 16 C.F.R. § 432.3)
Peak Power Output:30W per channel at 4 ohms (AES)
Woofer (each speaker)1 x 2.75” aramid fiber 1 x 2.75″ aramid fiber
Tweeter (each speaker)1 x 0.75“ Silk dome1 x 0.75″ silk dome
Bass Reflex Yes – Front SlotYes – Front Slot
Bluetooth Bluetooth 5.3Bluetooth 5.3
Bluetooth ChipQualcomm QCC3040 Qualcomm QCC 3031/3034/3040
Bluetooth CodecsaptX Adaptive, aptX HD, aptX, AAC, and LC3aptX HD, aptX, AAC, SBC
Inputs3.5mm stereo mini-jack, RCA L/R, USB-C3.5mm stereo mini-jack, RCA L/R, USB-C
Built-in USB DACYes – PCM5100A DAC ChipChip model not indicated
Outputs RCA variable line-outRCA variable line-out
Input Voltages 100-240 V 50/60 Hz auto-switching115/240 V, 50/60 Hz
SNR>95 dB (typical A-weighted)>95 dB
THD+NLess than 0.05% at all power settings<0.05%
Crosstalk<50 dB<50 dB
Frequency Response 65 Hz-22 kHz ±2.0 dB65 Hz-22 kHz ±2.0 dB
Enclosure Material Hand-crafted and hand-painted cabinets using a 13-step processHand-crafted and hand-painted cabinets using a 13-step process
Finishes Black (matte)
Green (matte)
Yellow (high gloss)
White (high gloss)
Red (high gloss)
Satin Black
Matte Blue
Hi-Gloss White
Hi-Gloss Red
Dimensions (HWD)6″ (15.6 cm) x 4″ (10.6 cm) x 5.25″ (13.8 cm)6″ (15.6 cm) x 4″ (10.6 cm) x 5.25″ (13.8 cm)
WeightLeft (active) – 3.6 lb (1.72 kg)
Right (passive) – 3.2 lb (1.51 kg)
Included Accessories1 x A2+ Gen 3 Home Music System w/ Bluetooth aptX Adaptive powered (left) speaker
1 x A2+ Gen 3 Home Music System w/ Bluetooth aptX Adaptive passive (right) speaker
Pre-Stripped Speaker wire
1 x USB-C cable
1 x AC power cord
1 x Mini-jack audio cable
2 x Microfiber speaker bag
1 x Microfiber cable bag
1 x Setup guide
1 x A2+ Next Gen Home Music System w/ Bluetooth aptX Adaptive powered (left) speaker
1 x A2+ Next Gen Home Music System w/ Bluetooth aptX Adaptive passive (right) speaker
1 x USB-C cable
1 x Power supply
3.5mm mini-jack audio cable
Quick start guide
Protective microfiber bags for speakers and cables
audioengine-a2-plus-gen3-white-ds1m-desktop-stands
A2+ Gen3 with optional D1SM desktop speaker stands ($39 at Amazon)
The Bottom Line
The wireless powered speaker category has become an increasingly popular option for a wide range of audio setups. These include computer workstations, gaming systems, soundbar replacements, and space-saving compact music systems.
Audioengine is a go-to brand in this category, offering consistently solid products that often perform beyond expectations. The periodic upgrades to the A2+, now in its third generation, continue that trend while keeping the price at or below $300.
However, despite the addition of Bluetooth aptX Adaptive, claimed improvements in USB audio, and the switch from Class A/B to Class D amplification, there are still some omissions from the A2+ that may be deal breakers for certain users.
For example, the A2+ still doesn’t provide HDMI ARC or a dedicated phono preamplifier. Adding these two features would noticeably improve setup flexibility, making the A2+ a more practical soundbar alternative while also bringing vinyl enthusiasts into the fold.
It is also important to keep in mind that there is some notable competition from brands such as KEF and Edifier.
KEF commands much higher prices but includes some of the aforementioned features, such as HDMI eARC, on several models, including the LSX II and LSX II LT. KEF also includes Wi-Fi, providing access to more streaming options than Bluetooth alone.
On the other hand, Edifier’s M90 does include HDMI eARC and is often on sale for around $300, while its step-up R2750DB MKII could appeal to listeners who don’t mind a larger speaker.
Ultimately, the Audioengine A2+ Gen 3 is for those looking for a compact desktop audio solution with minimal connectivity needs, or who primarily intend to use its Bluetooth wireless connection.
Where to Buy:
2026 Clearaudio Compact Phono in Silver and Black Front
Dongle DACs
The $599 SOUNDBOKS Rider delivers 118dB, a swappable battery and IP66 protection without requiring a hand truck to move it.
The Druid R2R DAC delivers smooth, fluid sound, balanced outputs, and swappable op-amps without the usual high-end price.
Neumann’s KH 310 II and KH 350 add 32-bit DSP, MA 1 room correction, more power and deeper system integration for pro and home...
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Is Bose trying to make open ear audio mainstream? The $199 Sport Open Earbuds and $299 Ultra Open Earbuds 2nd Gen target fitness and...
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
The compact Yamaha B200A adds Dolby Atmos and built in bass for under $300, but can you live without external surrounds or a subwoofer?
Can TAD modernize a high-end integrated amp without turning it into a streamer? The 250W A1000D adds DSD256 and D700 clock technology.
