CD Players
Tivoli Audio Music System BT: Review
Enjoy the convenience of a CD player, FM/AM radio and Bluetooth in an all-in-one retro chic tabletop stereo system.
Tivoli Audio Music System BT Black Lifestyle
The Tivoli Audio Music System BT is a compact integrated stereo system that incorporates a 2.1 channel amplifier, CD player, FM/AM radio, with an additional Aux input, and Bluetooth which provides access to streaming via compatible devices, such as smartphones.
This system was first introduced in 2013 and continues to sell well for Tivoli Audio and we applaud them for integrating both streaming functionality and keeping the CD player.
Tivoli Audio Music System BT Front
Core Features
Speaker Drivers: (2) 2 x 3-inch full-range drivers, and (1) 5.25-inch downward firing subwoofer
Amplifier Power Output: Information not provided
CD Player: Slot loading. CD, CD‐R, CD‐RW, MP3 CD, and WMA CD playback compatible
Radio: AM/FM
Wireless source: Bluetooth (8 Device Pairing Memory)
Alarm Clock: Dual Alarm and Sleep Timer
Status Display: Illuminated front panel status display featuring time/date, source/station, and track title information (when available)
System Dimensions: 5.25″ x 14.125″ x 9.5″
System Weight: 13.20 lb
Connections
Tivoli Audio Music System BT Connections
The connection options on the Tivoli Audio Music System BT include:
Auxiliary Input: 3.5mm (can be used with RCA to 3.5mm adapter cable)
Mix Input: 3.5mm Source audio connected with this input will be mixed with audio from another selected input (sort of like a Karaoke/Singalong function).
Record Out/Line Out: 3.5mm (can be used to connect to a cassette or CD recorder or to an external amp or subwoofer – the onboard speakers are not muted when in use).
AM Antenna In: A plug AM Antenna is provided, you can also use one of your own as well.
FM Antenna In: An external Antenna is included but you can use one of your own as well.
Power Receptacle: Detachable power cord provided.
Headphone Output: Front panel, 3.5mm minijack (not shown in the photo).
Control
Tivoli Audio Music System BT Front Display
Front Panel: Power, CD playback controls, AM/FM tuning and presets, Source Selection, Alarm Set, Sleep timer, Volume, EQ, Menu, Information/Status Display options
Rear Panel: Bass Level, Internal/External FM Antenna Switch
Top Panel: Snooze/Mute Button
Remote Control: Duplicates most functions of the front panel controls with additional Repeat, Shuffle, and Audition options for the CD Player.
Tivoli Audio Music System BT Remote Control
What You Get
Here is what comes in the box with the Tivoli Music System BT
  • (1) Music System
  • (1) User Manual (not shown in photo)
  • (1) External Wire FM Antenna (pre-attached to the ack of the system – not visible in photo)
  • (1) External AM Antenna
  • (1) Remote Control (Battery Included)
  • (2) AA Batteries
  • (1) Power Cord
Tivoli Audio Music System BT Accessories
Music System Setup
From Tivoli: “Before operating the Music System BT, wait until it has reached room temperature. Otherwise, condensation may form inside the CD player and it may not operate correctly. The display can also be affected by hot or cold temperatures.”
Step 1: Insert the two provided “AA” backup batteries for the clock into the rear battery compartment before connecting the AC power cord.
Step 2: (optional): Connect the provided AM Radio Antenna
Step 3: (optional) Connect external FM Antenna (telescoping FM Antenna already built-in)
Step 4: Connect the Music System BT to AC power.
Step 5: Press the red Power button on the front panel.
Step 6: Press the Source button or insert a CD into the CD slot. If AM is selected, attach the included external AM antenna and adjust for receiving AM stations.
Step 7: Turn up the volume and start listening.
Tivoli Audio Music System BT on Bookshelf
The Skinny
My first impression of the Music System BT is an appreciation for its retro design and features, especially the inclusion of a CD player. Although the Music System doesn’t directly incorporate streaming (it was first released in 2013), the inclusion of Bluetooth allows the playback of streaming content via compatible mobile devices.
However, sometimes I just want to listen to the radio or play one of the many CDs in my collection while working, relaxing, when I wake up in the morning and go to sleep at night. For me, I thought the Music System BT works well in that regard.
This system delivers a good listening experience for a compact system. the sound is clear and detailed, especially from CDs, physically connected, and Bluetooth sources. I found the FM reception to be very good in my location. On the other hand, although AM reception was good, the sound quality was poor. Of course, although this is typical for AM, I was expecting a little bit more refinement on the Tivoli.
One odd thing I noticed is the location of the bass level control on the back of the Tivoli rather than including it on the front panel with the rest of the controls. There is no bass level control on the remote control either.
On other hand, one of the settings accessible from the front panel and the remote that I liked was the SpacePhase Wide Mode. This setting expands the left and right channels beyond the physical Music System cabinet to provide a more expansive stereo image. On the other side of the coin, if you are listening to a weak FM radio station, the Mono setting reduces noise and distortion, although this eliminates the stereo listening experience.
Tivoli Audio Music System BT Front Dark
One thing to keep in mind is that although the Music System BT can provide decent sound, it is a compact system and isn’t going to provide the same listening experience as a high-end 2-channel audio system with good bookshelf or floor standing speakers and a separate subwoofer. If you push the volume and bass level controls to their limit you will hear some distortion. However, it does save space as a self-contained system.
On the connectivity side, the Music System provides a lot of options, but there isn’t a dedicated phono/turntable input. This means that if you have a turntable that doesn’t have a built-in phono preamp, to connect to the Tivoli Music System BT, you will have to place an external phono preamp between the turntable and the Music system’s aux input.
In addition to the music features, since the Music System is also a Clock Radio. The time/date display is large and readable from across a small room or office, and there are provisions to set two independent alarms as well as to set the sleep timer. The sleep timer interval is 20 minutes (no other sleep time intervals are provided).
I enjoyed using the Tivoli Audio Music System BT, but if I was shopping for a compact audio system, this one carries a hefty price tag of $699.99 (and has since its introduction in 2013) – At $399.99 I might consider it. Although it’s great to have a compact system these days with a built-in CD player, not also having built-in streaming, as well as either Alexa or Google Assistant voice control is a turn-off at its price point.
Tivoli Audio Music System BT Lifestyle
Pricing and Availability
The Tivoli Audio Music System BT is available now for $699.99 at Amazon, Tivoli Audio and B&H Photo (prices may vary by dealer).
Pros
  • Retro Design
  • Solid Build
  • Built-in CD Player
  • Wide Stereo Audio Processing Option
  • Easy Bluetooth Pairing
  • Easy to Read Front Panel Status Display
  • Abundant controls on the front panel and remote
  • Audio line out for recording
Cons
  • No Dedicated Phono Input
  • Poor AM Radio Quality
  • No Airplay Support
  • No built-in streaming features (other than Bluetooth)
  • Inconvenient location for bass level control
  • The sleep timer only has one setting.
  • Expensive!
6 Comments
6 Comments
  1. Efab
    March 9, 2022 at 7:52 am
    There is a big problem with the Tivoli products. The remote control is of very poor quality.
    • Danny
      June 20, 2023 at 1:51 am
      No shit! That’s an understatement….I’m on my 7th one from Tivoli…now they’re out of stock…finally got an aftermarket and porgramed it
      • gordy mass
        June 30, 2024 at 10:36 am
        getting my 3rd tomorra, bro
        (gordy mass)
  2. Andrew Franz
    October 27, 2024 at 1:31 pm
    With all the buttons it more designed for hands on use than with a remote.
    • Ian White
      October 27, 2024 at 3:19 pm
      Andrew,
      And there are a lot of buttons. So many. I’m not of the belief that everything should use a touchscreen to operate every feature; a good remote and some useful front panel buttons go a long way. A well-designed app that is reliable also helps.
      IW
  3. Adam
    July 4, 2025 at 12:35 pm
    What other models are comparable to this, but might have a lower price? i.e. compact shelf unit with decent speakers and CD player
CD Players
Onkyo's new Icon C-30 CD player brings audiophile tech at a surprising price. Discover why physical CDs still matters at Audio Advice Live 2025...
Portable CD players are back, but with better sound, Bluetooth, and DACs. FiiO and Shanling are leading the charge in 2025's retro revival.
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
The Cyrus Audio 40 series hi-fi components includes matching Integrated Amplifier, Streamer, CD Player and Power Supply for $16,480.
CD Players
Shanling’s EC Zero T brings hybrid tube/solid-state sound to a portable CD player with R2R DAC, Bluetooth 5.3, and high-end headphone amp—CDs just got...
A deep dive into two legendary 1990s CD players—the Copland CDA 288 and YBA CD1 Blue Laser. Vintage, overbuilt, and sonically elite, these eccentric...
At $219, the Tivoli Audio Model One BT 70's Color Collection is both a Bluetooth speaker and table-top radio in five retro colors.
Tivoli Audio's limited-edition SongBook Max, made in collaboration with Grammy-winning producer Sounwave, brings leather, chrome, and serious attitude to a retro-style Bluetooth speaker built...
