Samsung The Frame 65-inch 4K TV Review: Television or Art?
The Frame is a head turning 4K QLED TV that hangs on your wall and looks like a piece of artwork.
Samsung The Frame 4K QLED HDR TV (2020)
Overview
The 2020 Samsung The Frame is not your typical 4K TV. In fact, there is no other TV like it on the market. When hung on the wall it doesn’t even look like a TV. It looks like art, and it will certainly turn heads. If you want a TV that blends into the decor of your room, then The Frame is it!
Getting The Frame to appear like wall art is only one part of the story. There is quite a lot to unpack. This review examines picture quality, mounting, hookup, functionality, usability, art mode, ambient mode, streaming options, voice features, design options, and more. When all is said and done, The Frame has a lot going for it, but like any piece of art — some people find it breathtaking, others bewildered. Similarly, The Frame had me in awe and perplexed.
Samsung The Frame 4K TV Parts
The Frame’s Parts:
Left – mounting plates and stand
Center – One Connect Box
Right – Remote and Invisible Connection
The Frame is actually two products in one. It’s both a high-end digital picture frame and a LED-backlit QLED 4K HDR TV. And since it comes with a wall-mount (most other TVs don’t) buyer’s should realize they’re getting everything in the box, including some unique extra parts. To get a perfectly flush mount, the brains of the TV are housed in an external box, called the One Connect. Only a thin fiber-optic wire, called the “Invisible Connection”, connects between The Frame and the One Connect box. That means any ugly wiring to/from other components go into the One Connect, instead of the TV. Plus, the box doesn’t need line-of-sight to the remote and can be hidden anywhere within reach of the 5 meter (16 foot) “invisible” cable. For longer runs, Samsung offers a 15 meter “invisible” cable for $299.
Samsung One Connect Box Top Front View
Samsung One Connect Box (2020) Rear View
Rear view of Samsung One Connect Box:
Ports (left to right): Power (top-left), EX-LINK, USB 2.0, ANT IN, OPTICAL OUT, LAN, HDMI 1, HDMI 2, HDMI 3 (eARC), HDMI 4 (Gaming), ONE CONNECT
If you’re upgrading from a TV more than a few years old, you certainly won’t be disappointed. The Frame is essentially Samsung’s Q70T 4K TV (65-inch, $1299 at Amazon) wrapped into a prettier design. Comparing picture quality alone, The Frame and the Q70T should be indistinguishable. Although it should be noted, the Q70T (and the Frame) is a mid-specification model in regards to picture quality that’s two steps down from Samsung’s top-of-the-line Q90T 4K TV (65-inch, $1,899 at Amazon) for 2020. Of the three models, The Frame still makes a compelling case. It’s sleek, jaw-dropping design, especially when mounted are the reason you’d want The Frame even though you pay a premium for design. There simply is no better priced alternative to achieve a no-gap wall-mountable TV at its price point.
Samsung The Frame Wall Mounting Hardware
Samsung The Frame – No Gap Wall Mount Parts
samsung-frame-tv-mount-hook-open
The Frame TV Mounting Plate and Invisible Connection cable attached
Mounting
The Frame is designed to be wall mounted. It also comes with a basic low profile stand that’s helpful to get the TV upright while preparing for mounting. The mounting kit includes two main parts: a wall plate that screws into the wall and TV plate that screws into the back of the TV. Once both are installed, two people can lift the TV into the interlocking position on the wall for a perfectly flush mount. Optionally, the mount allows for a few degrees of forward tilt. Just remember to connect the Invisible Connection cable to the back of the TV before mounting. It’s also a good idea to snap a photo of the serial number on the back of the TV. You’ll need it if there’s ever a warranty issue.
samsung-frame-tv-mounting-guide
Wall Mounting Cut-out to help align mount
Once The Frame is mounted the Invisible Connection cable will hang down from the center of the TV, but it could be channeled into conduit within the wall. Oddly, the included “invisible” cable is not in-wall rated. However, it should be safe within in-wall conduit. To adhere to building code, Samsung offers an in-wall rated Invisible Connection cable for $299. For increased longevity don’t bend that cable.
Samsung The Frame Wall Mounting Paper Cut-out Guide
Distance between screw holes, 16-inches maximum
Mounting the Frame is very simple, but somewhat limited. While other TV mounts provide 36-inches of width to attach to three studs, The Frame’s wall mount is only 20-inches wide, which limits mounting between two studs (normally 16-inches apart). That’s fine if your desired wall hanging position is between studs. However, in my case a stud was dead center of the room and the mount wasn’t wide enough to reach another stud. That left me only two screw holes in the middle to burrow into a stud. Smaller sized Frame TVs would probably hold. I didn’t want to risk hanging a 65–inch, 56 lbs TV based only on two screws. Drywall anchors are included for such cases, but I couldn’t get a tight fit with them. Purchasing heavy duty wall anchors would had been my next step had The Frame not been on loan from Samsung. Instead, the The Frame ended up on its low profile stand (also included).
samsung-frame-tv-on-stand
Samsung The Frame on stand with BDI Elements 8779 media console. The Frame bezel still wrapped in clear plastic.
Setup
When the Frame is first turned on, it greets you with a screen directing you to download the Samsung SmartThings App, create an account, and agree to a bunch of terms that nobody reads. Once the TV is connected to your home Wi-Fi, the SmartThings app on your smartphone should be able to locate the TV. Going forward you don’t need the SmartThings app, but it serves as a secondary remote and control center for automated tasks — not just for the TV, but other smart devices too. The initial setup took about 15 minutes including installation of software updates.
Watching TV
Once the initial setup completed, the Samsung Home Screen appears. It’s the central place to access everything from TV settings to streaming apps. Free live streaming TV channels are instantly accessible to start watching, including Bloomberg, CBSN, Cheddar, and hundreds more niche channels. It seems mostly the same channels found within the Pluto TV app, but Samsung makes it accessible and integrates it into its own app called Samsung TV Plus.
Samsung The Frame 65-inch TV Glare while watching football
Picture Quality
Don’t be alarmed if the TV picture quality looks sub optimal when you first start watching. The problem is the default Standard color mode that is way too bright, over saturates colors and makes skin blotchy. Once switching to the Movie color setting, picture quality drastically improved. There’s even more advanced color settings to tweak in the menu, but I think most people would be just fine with Movie mode regardless of the content displayed.
One of the stand-out features of The Frame is Dual LED backlighting. While many budget LCD TVs have a single edge-lit backlight, Samsung uses two. Each is set to a different color temperature in which Samsung claims improves color and contrast. Although this technology may improve some scenes, it’s still a step-down from direct full array backlighting found in Samsung’s premium models.
Samsung The Frame TV showing Zebra photo
Issues that affect many LCD TVs don’t escape The Frame. Brightness drops off dramatically at off angle viewing. Anyone seated beyond 30-degrees to the left or right will notice a washed out picture. The screen is highly reflective and can pickup a good amount of glare from nearby windows, especially at off-angles. Also, too much sunlight won’t be friendly to picture quality either. Yet despite the issues, I was still able to watch football games during the day just fine as long as I was seated straight on.
Overall picture quality is respectable. I wasn’t blown away, but I suspect most people would be! Black levels struggled a bit on some of the darker scenes from Disney’s Mandalorian, but not to the point any casual observer would be displeased. Colors in movie mode have a nice cinematic warmth to them, and the screen is not obnoxiously bright. Scenes with fast moving motion held together without any noticeable pixelation or distracting trailing blur. I’d also recommend turning off Eco and Intelligence features, as they both seemed to hurt picture quality more than help. Once I got settings dialed in, I truly enjoyed watching for hours. Despite some early apprehensions, The Frame was growing on me with time.
Samsung R-NZ White Remote Control for The Frame
Usability
The Frame comes with an ergonomic white remote that’s slightly curved. It feels nice in your hand and most of the buttons are intuitive. However, the volume up/down initially had me stumped, because you don’t actually press them down, you nudge it up from bottom. I don’t recall encountering such behavior in another remote. Luckily it was easy to get used to. There aren’t many buttons on the remote, and it’s mainly designed for navigating the menu and loading apps. In that respect it’s easy to use. Also, there’s a voice button for speaking commands. Alexa and Google Assistant voice services are compatible. Samsung’s Bixby too.
I was able to connect my Amazon Echo to The Frame fairly easily. Then I tried asking Alexa what seemed logical to me. After much trial and error (comical error), the most I could successfully get Alexa to do was power on/off the TV or change the volume. With multi-step commands, Alexa wouldn’t have a clue. There are key phrases to memorize that would have helped, but I never remembered which order to say things. Perhaps others may have better luck trying Google Assistant or Samsung’s Bixby. Regardless, the better use case for voice is built into the remote. Just hold down the microphone button and speak. For example, “Play most popular videos on YouTube” or “Start Netflix” worked. But it only works when the TV is already on, whereas the other voice services can work hands-free via wake word (such as Alexa) when the TV is off.
The Frame comes pre-loaded with many popular apps like YouTube, Netflix and Amazon’s Prime Video. You just need to login with your account credentials. For others, you have to manually install from the TV’s “app store”, where I added HBO MAX, CBS All Access and Showtime. Alternatively, you can stream videos from Apple devices via AirPlay 2. However, The Frame doesn’t include Chromecast, which would have been a nice-to-have feature. I believe Android users can still mirror their smartphone screen to get similar functionality, but I was only able to test AirPlay from a MacBook Pro (2012), iPad Pro (2018), iPhone 11 Pro and iPhone 12 Pro. All worked, except a picture-in-picture feature called Multi-view would sometimes load the AirPlay stream into a split screen along with whatever was previous playing. Multi-view is a feature that allows you to watch two programs at once. But for me it just kept getting in the way when I didn’t expect it, and I couldn’t find a way to disable it. Others may like the option of watching two things at once.
Samsung The Frame TV Default Home Screen
Samsung Default Home Screen – Where are the apps?
Having never reviewed or owned a Samsung TV, the on-screen menu system took some getting used to. Again, it’s another default settings issue. All the streaming apps are tucked behind an app icon that’s four clicks away and not even visible on the home screen. The default path to YouTube took a frustrating 7 clicks. Then one day I discovered the “Favorites” feature. Once you Favorite (heart) your preferred apps, they’ll stay on your home screen menu bar (next to Samsung TV Plus) where they’re just a click or two away. What an improvement. If only I had found this feature a month earlier.
Samsung Home Screen with Favorite Apps
Samsung Home Screen now with Favorite Apps
One final thing on usability. You’ll want to dig into the settings menu under “General -> Smart Features” and enable “Auto run last app” to keep things where you left off. Otherwise, you’ll end up having Samsung’s TV Plus app load all too often as the default.
Samsung The Frame in Art Mode
Finally, the Art
All of this being said and I haven’t even mentioned the art. The art is the best part! It’s the reason to buy the TV in the first place. 20 free art images are included to try out, and it works with any digital print you can find — even your own photos. When using your own images, the main thing to remember is to crop to 3840×2160 resolution to natively fill the screen. Art aficionados and less tech-savvy users will appreciate the convenience of Samsung’s $4.99/monthly art subscription to access over 1,200 pieces of artwork from the likes of the Royal Collection Trust, Magnum Photos, Artspace and more. Samsung also sells individual digital prints for $19.99.
Once you find art to your liking, you can apply a matte style and matte color to achieve a realistic picture frame look. Once set, the art can appear manually or automated. The manual method loads the previously selected art upon pressing the power (art) button on the remote. If the TV is off, double clicking power loads art. If the TV is on, a single power press loads art. A long (hold) power press turns the TV all the way on for watching TV or all the way off. Somewhat confusing to write, but easy to pick up on as the Art Mode resides in a middle state between off and on. For automation, return to the SmartThings app to customize the display of art, such as at specific times of day or other triggers. Lastly, motion and light sensors act can be activated in the menu to turn off the TV completely when nobody is around.
In addition to Art mode, there’s Ambient mode which plays music corresponding with a various full screen still or moving images. It’s somewhat like a fancy screensaver, but with more options. It’s also found in other Samsung TVs, and because of Art mode I found little use for it.
2020 Samsung The Frame Bezel Colors
Optional Bezel Colors for The Frame
Style Options
The Frame’s black bezel comes standard, but a white, beige or brown bezel can be purchased for an additional $199. The optional bezels come in pieces that snap into place around the TV, covering up the black frame. In lieu of wall mounting, Samsung offers a three-legged Studio Stand for $299. Lastly, if you need an Invisible Connection cable longer than the 5 meter (16.4′) one that’s included, Samsung makes a 15 meter (49.2′) cable that’s $299.
Competition
There isn’t much that competes against The Frame for the price. Other no-gap wall-mountable 2020 TVs include LG’s Wallpaper OLED 4K TVs ($3999 at Amazon) and LG’s GX Gallery Design OLED 4K TVs (65-inch, $2599 at Amazon). Sony’s A8H OLED 4K TV with mount (65-inch, $2146 at Amazon is another strong contender that’s super-thin, but can’t be mounted as flush to the wall as The Frame. All cost a lot more, and the main reason to buy them is if money is no object and picture quality is of greater importance than appearance.
Samsung The Frame 4K QLED HDR TV (2020) Angle View
Conclusion
The 2020 Samsung The Frame 65-inch is a good 4K TV with a stellar design. Art mode and its unique picture frame style are the main reasons to buy this TV. It’s not perfect out of the box, but with a few tweaks you’ll have a television that will not only impress, but will fool people that it’s even a TV at all. Simply amazing!
ProsCons
Gorgeous design
Flush wall-mount
Voice control – Google, Alexa, Bixby
Art mode
Ambient mode
Gaming mode
HDR
eARC
SmartThings app control/automation
Optional bezels in different colors
AirPlay 2 – mirroring from Apple Devices
Easy to hang
Screen glare
Off-angle viewing loses contrast
TV picture good, but not highest quality
Default settings not ideal
Remote takes getting used to
Hanging could require extra parts
One connect Box / cable sound sync issues
Lots of menus
Invisible cable not in-wall rated
Replaceable parts can be expensive
No Chromecast
No Dolby Vision
No HDMI 2.1
No DTS
More Info
Learn more about Samsung The Frame 65-inch at the Samsung.com product page, model QN65LS03TAFXZA. Available in 32″, 43″, 50″, 55″, 65″ and 75″ screen sizes. All models do not have the same specifications.
  • Models 55″, 65″, 75″ have same specs:
  • Models 43″ and 50″ have lower specs:
    • Excludes FreeSync for gaming
    • Doesn’t support 4K@120Hz (HDMI Port 4)
    • Have Motion Rate 120 instead of 240.
    • Have worse Wide Viewing Angle
    • Have 20-watt speakers instead of 40-watt
  • Model 32″ has even lower specs:
    • 1080p HD, not 4K
    • Uses different One Connect, only 2 HDMI inputs (not 4)
    • Black remote, not white
    • Has protruding Samsung logo
    • Different stand
Pricing & Availability
Buy the 65-inch The Frame reviewed for $1899 at Amazon or at Samsung.com.
Prices as of December 1, 2020 at Samsung.com:
  • QN32LS03TBFXZA 2020 The Frame 32-inch – $479.99
  • QN43LS03TAFXZA 2020 The Frame 43-inch – $999.99
  • QN50LS03TAFXZA 2020 The Frame 50-inch – $1,199.99
  • QN55LS03TAFXZA 2020 The Frame 55-inch – $1,399.99
  • QN65LS03TAFXZA 2020 The Frame 65-inch – $1,899.99
  • QN75LS03TAFXZA 2020 The Frame 75-inch – $2,199.99
The 2020 The Frame has been replaced by the Samsung’s 2022 The Frame, which is thinner and has a brand-new matte, anti-reflective display. There’s a new 85-inch screen size too!
The 2022 The Frame TV is available in sizes from 32- to 85-inches, priced from $600 to $4300 at Amazon.com and Samsung.com.
  • QN32LS03BBFXZA 2022 The Frame (32-inch) – $599.99
  • QN43LS03BAFXZA 2022 The Frame (43-inch) – $999.99
  • QN50LS03BAFXZA 2022 The Frame (50-inch) – $1,299.99
  • QN55LS03BAFXZA 2022 The Frame (55-inch) – $1,499.99
  • QN65LS03BAFXZA 2022 The Frame (65-inch) – $1,999.99
  • QN75LS03BAFXZA 2022 The Frame (75-inch) – $2,999.99
  • QN85LS03BAFXZA 2022 The Frame (85-inch) – $4,299.99
Related reading: All Samsung 4K & 8K TV for 2022
3 Comments
3 Comments
  1. Georhe
    March 12, 2022 at 3:05 am
    Hey mate, do you still have the wall mount template? I cannot find an online version to reinstall my tv at my new place , but the photo uploaded is too pixelated and I can’t see the dimensions. Mine is a 75″. Thanks!
    • Brian Mitchell
      March 12, 2022 at 7:23 am
      The Frame has been returned to Samsung so I don’t have anything to share. The wall mount fits between 16-inch wide studs.
  2. Michelle
    September 14, 2024 at 10:54 pm
    Anyone of you owners of this tv having issues? We have this tv for like 2 years and now it’s not working. It’s just all the sudden the picture is dim and is not connecting to our cable. We reset it a few times but still no luck. We look around if we can just buy another one connect box but seems like we can’t find one. Please have if having the same issue. Thank you!
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Samsung’s new Movingstyle lineup brings mobility to the living room with the 27-inch LSM7F and 32-inch M7 Smart Monitor, combining style, flexibility, and power.
Ask an Expert
QD-OLED TVs blend OLED’s perfect blacks with Quantum Dots for brighter, more accurate color. Here’s how they work—and what sets them apart from regular...
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
