ZVOX Z-Base 220, 320, 420 Sound Bars
ZVOX has expanded their lineup of Z-Base single-cabinet home theater sound bars, which are designed to be placed under a flat-panel TV set. Three new models — Z-Base 220, Z-Base 320 and Z-Base 420 (priced at $199.99, $249.99 and $299.99 respectively) — are the most affordable Z-Base systems ever offered. Each system uses high quality speakers and amplifiers, wood (MDF) cabinets and ZVOX’s proprietary PhaseCue II virtual surround sound system.
Z-Base 220
About the size of a DVD player, the Z-Base 220 can fill a room with 3D sound — including excellent bass — with no external speakers, subwoofers or speaker wires. Use it on a shelf below the TV, or under most TVs from 22″ to 32″ in size. Three full-range speakers, 5.25″ powered subwoofer, 35-watt amplifier and PhaseCue II virtual surround sound — all in a single cabinet. 17″ x 14.5″ x 3.4″. $199.99
Z-Base 320
ZVOX Z-Base 320 Sound Bar
Only 24″ wide and 11.5″ deep, the Z-Base 320 fits just about anywhere — even a bookshelf. But it’s big and strong enough to support most TVs from 27″ to 46″ in size. Three full-range speakers, 5.25″ powered subwoofer, 40-watt amplifier and PhaseCue II virtual surround sound — all in one cabinet. $249.99
Z-Base 420
ZVOX Z-Base 420 Sound Bar
Big enough to support TVs up to 55″ in size, the Z-Base 420 is the perfect home theater system for many applications and room sizes. It produces high performance 3D sound from five full range speakers, a 45-watt amplifier and a 5.25″ powered subwoofer using PhaseCue II virtual surround sound. 28″ x 14.5″ x 3.4″ $299.99
Features
  • Dialog Emphasis — Incredibly Clear Voices. ZVOX’s exclusive Dialog Emphasis feature uses hearing aid technology to make voices unbelievably clear. It’s amazing. Voices seem to just “jump into your head.”
  • Output Leveling — Tame Loud Commercials. Tired of commercials that blast you out of your chair? The ZVOX Output Leveling feature reacts instantly and turns down loud commercials…and also boosts quiet dialog.
  • PhaseCue II — The new systems use ZVOX’s proprietary PhaseCue II virtual surround processing to provide rich three-dimensional sound with movies or music — without external speakers and speaker wires.
  • Controlled Remotes — Uses Your Remote Control. The Z-Base systems can be programmed to respond to most remote controls, so a TV remote…or cable box remote…or satellite receiver remote…can control volume, mute, power and input functions.
  • Multiple Inputs — multiple inputs…including front-panel connection for iPod® and other portable devices. The new Z-Base sound bars offer two analog audio inputs, one optical (toslink) digital input, one coaxial digital input – plus a front panel 3.5mm analog stereo input for convenient connection of an iPod or other portable audio device. Just plug in your iPod and the system automatically switches to iPod sound. Unplug it and the Z-Base automatically switches back to TV sound. Any input can be selected using either the remote control or the controls below the speaker grille.
  • Great Sound — The most important feature for any home theater system is high quality sound. The new Z-Base systems use premium quality speakers and amplifiers and were designed by the ZVOX team of speaker designers. Their sound quality is comparable to surround sound systems that are much larger, more complicated and more expensive.
1 Comment
1 Comment
  1. Frank
    January 9, 2015 at 2:34 am
    If I get a good sound system, should I be able to bring women back to my room and have a good time? I do not want to spend a lot of money on a sound system if good sex is not to be.
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
