Zu Audio Union 6 Series Pay Homage to the Past and Look Forward to the Future
Zu Audio consolidates several of its speaker lines into the Union 6. Did they make the right move? Let’s see what it offers.
Zu Audio Union 6 Series Loudspeakers Lifestyle
Zu Audio has been making loudspeakers for 22 years and we’ve been fans and customers for over a decade. Sean Casey has never played by the rules in the high-end audio world and that’s perfectly fine on our book. The pandemic has not been kind to our friends in Utah; supply chain issues have led to long delays and the end of the Omen Dirty Weekend project as well. The new Zu Union 6 lineup has been unveiled and we’re very intrigued.
The Zu Union 6 Series
Zu Audio has decided to revamp its speaker product line. Their new Zu Union 6 Series are designed to replace several recent models: Omen Dirty Weekend, Omen 2, Soul Supreme, Omen Bookshelf, Omen Center Channel, and Zu Cube
Making such a move is a big undertaking. Here is what Zu Audio had in mind:
  • Raise resolution, transparency, and tone.
  • Make each speaker unfussy with respect to room placement and connected gear.
  • Remove 12 ohms and 16-ohm models and go with the mass market 8-ohm standard.
  • Eliminate the Zu set-up task of finding the right room floor-to-speaker gap.
The Union 6 is described by Zu Audio as a “full-spectrum, highly resolving and robust floor-standing loudspeaker”.
Zu Audio Union 6 Series Loudspeakers Lifestyle Black
Features and Specifications
  • Design: Floorstanding with North American-made composite wood, skinned with real wood veneer or epoxy.
  • Full-Range Driver: ZuCX-ND-8 10.3” coaxial paper/CNT cone, under-hung 2” (50.8 mm) coil on paper/Kapton former.
  • Tweeter: Eminence UAPT50-3
  • High-Pass Network: Single element mono pole filter (ClarityCap MR 1.0 µF)
  • Crossover: None. In addition there are no filter components on the full-range driver
  • Frequency Response: 30 – 22k Hz
  • Sensitivity: 99 dB-SPL @ 2.8V, 1m
  • Impedance: 8 ohms
  • Wavefront: Virtual point source
  • Max SPL Program: 120 dB-Z
  • Max Input Power: 150 W / 300 W (high-pass at 50 Hz, 12 dB/octave)
  • Left/Right Pair Matching: 0.5% on drivers and 0.1% on all other components
Input Connections:
  1. ZuB3 via speakON NL8 (parallel with binding posts).
  2. Posts that 1/4” (6.3 mm) and oversized spades, bare wire ≤ #4 AWG (5.1 mm), and banana plugs.
Size and Colors:
  • Dimensions (WDH):  12 x 12 x 36 inches (30.5 x 30.5 x 91.5 cm) – Each.
  • Weight: 60 pounds (27 kg) – Each.
  • Available Colors: Hickory Clear, Hickory Black, Black Satin, Mercury (some may require extra charge).
  • Driver Ring Color: Silver or Black.
Zu Audio Union 6 Series Loudspeakers Finishes
Included Accessories
  • Hard plastic slip-fit driver covers
  • 1–1/2” (38 mm) adjustable carpet spikes
  • Stainless steel adjustable hard surface oval-end footers with 9/16” jam nuts (installed)
Amplifier Power Guidance
  • 4 – 10 watts for low to moderate SPL (sound pressure level)
  • 10 – 100 watts for moderate to very loud SPLs
  • 100 – 500 watts for loud to ear damagingly loud SPLs
Availability and Pricing
The Union 6 Series floorstanding loudspeakers are available direct from Zu Audio with prices starting at $2,899/pair.
Tip: Zu Audio has also indicated that a Union 6 Supreme floorstanding version starting at $3,899 as well as a Bookshelf version starting at $1,799 are expected to become available sometime in July 2022.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our top floorstanding loudspeakers for 2025 come from Magnepan, Q Acoustics, KLH, Audiovector, and ATC—five brands delivering standout engineering, scale, and true high-end performance.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
AUER Acoustics brings its very expensive VERSURA speakers to the US, featuring tankwood cabinets, refined design, and high-end engineering aimed at serious audiophiles.
JBL unveils its new flagship 4369 Studio Monitors at the Tokyo International Audio Show for audiophiles and studios alike. Available Q1 2026, price TBA.
Audiovector Trapeze Ri speakers offer warm, bass-forward sound, precise top end, and natural midrange. Rock-solid Danish design meets high-end performance, requiring a powerful amp...
Polk Audio have been quite aggressive with their Reserve and Legend Series speakers, and news has dropped on a brand new lineup called the...
