Zero Gravity Deluxe Electric Lift Table
Zero Gravity Tables
Zero Gravity Tables makes the Deluxe Electric Lift Table, which turns a traditional desk into a standing desk with the touch of a button. The contemporary, motororized computer desk is adjustable to any height between 24- and 50-inches, and offers presets to quickly change to preferred settings.
The Deluxe Electric Lift Table’s motor supports more then 300 lbs to work perfectly with desktop, laptop and multiple monitor setups. The desk supports up to four monitors, and has a keyboard tray that not only slides out, but also swivels. Built-in electrical outlets make it easy to connect all your electronics.
Finally, the desks’ unique tabletop surface doubles as a dry erase board for note taking or brainstorming. You can write on it with any dry erase marker.
Price and Availability
The Zero Gravity Deluxe Electric Lift Table is priced from $1400 to $2000, and is available in four Sizes – 36″x30″, 48″x30″, 60″x30″ and 72″x30″. Choose white or black legs with 4 Tabletop Colors – Whiteboard White, Gloss Black, Cherry Woodgrain, Maple Woodgrain.
About Zero Gravity Tables
Zero Gravity Tables is a premier adjustable sit to stand furniture manufacturer located in the heart of Los Angeles, CA. Zero Gravity Tables is part of Versa Products Inc., a leading Southern California furniture company. Zero Gravity Tables originates from four furniture manufacturing companies. In total, the company has a combined 80 years of furniture manufacturing expertise, doesn’t outsource, and only uses eco friendly manufacturing techniques.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
