Ypsilon Aelius Hybrid Power Mono Amplifier
Single-Ended and Push-Pull Valve Monoblock Amplifier Delivers Sonic Purity, High Power, Top Build Quality
Aaudio Imports, a leading supplier of world class high-end audio products, introduces into the U.S. market the revolutionary Aelius, a new high-performance push-pull hybrid monoblock power amplifier by Ypsilon of Greece, and the latest addition to Ypsilon’s broad line of amplification products.
Capable of driving any loudspeaker, the Aelius is a remarkable product using an outstanding hybrid design that combines the sonic purity of single-ended triode (SET) amplification with the power of push-pull amplification, all with unmatched build quality.
SET amplifiers help instruments and voices retain their natural presence, making listeners feel they are hearing real music played by real people. Music flows in a way that happens only in live unamplified performances. Operating in Class A, where current flows independently of the audio signal, they deliver a sound that makes it easier to feel music’s inherent drama and momentum.
SET amps are best at relatively low wattages, and with loudspeakers having very even impedance curves. Push-pull amplifiers tend to be better at low frequencies and operate better at higher power levels. However, their sound tends to be not as convincingly natural. Ypsilon’s solution elegantly combines the two approaches in a way that avoids each one’s limitations.
The Aelius delivers more power, drive and transparency than either style could independently, while retaining a sense of musical involvement and music’s natural flow. With only two gain stages, tube input and rectification, and a metal–oxide semiconductor field-effect transistor (MOSFET) output stage, the Aelius achieves all-valve SET amplification with significant power, enough gain, low distortion, and a sufficient output impedance. It provides a tonal palette of immense width, producing clear, undistorted music that brings listeners as close as possible to the actual music event.
The Aelius’ monoblock configuration uses a Siemens C3g valve in the input stage and a 6CA4/EZ81 rectifier tube. It produces 220 watts/channel into 8 Ohm, 380 watts/channel into 4 ohms, and 500 watts/channel into 2 ohms for almost endless power
The Aelius can be integrated into any audio system, regardless of speaker impedance or cable length. It includes a balanced/unbalanced switch and an easily accessible ground/lift switch on the rear panel.
The Aelius Push-Pull Hybrid Monoblock Power Amplifier is available now from authorized Aaudio Imports dealers at a suggested price of $34,000/pair (U.S. MSRP).
About Ypsilon
Ypsilon Electronics, based in Greece, is a highly regarded designer and manufacturer of innovative amplifiers, preamplifiers, DACs, CD Transports and related components. Founded by veteran sound engineers, Ypsilon is dedicated to developing products whose reproduced audio is indistinguishable from live music.
Splurge Audio Video Hi-Fi Tech Gifts 2026
