Yamaha YHT-5960U HTIB System is Designed to Keep it Affordable
Not interested in a soundbar? The Yamaha YHT-5960U HTIB is an affordable home theater system with everything you need for a small setup at a great price.
Yamaha YHT-5960U HTIB Lifestyle
Soundbars provide a simple, no-hassle solution to improve TV sound, but there is another option that can provide a full surround sound experience without spending a lot of money.
home theater-in-box system (aka HTIB) is a solution that supplies a home theater receiver (or similar central unit) a set of speakers, remote control, and connection cables in one package, making shopping and setup easy.
Yamaha has announced its entry into this product category for the 2021/22 model year, the YHT-5960U HTIB. This system comes with a 5.2 channel receiver (RX-V4A), a five-channel bookshelf speaker system (left, right, center, left surround, right surround), and one powered subwoofer (a second subwoofer can be added – requires additional purchase).
The Receiver
Yamaha RX-V4A A/V Receiver with Remote
The included RX-V4A home theater receiver provided is rated at 80 wpc with .06% THD (Total Harmonic Distortion) which is enough power to provide clean sound for a medium-size room.
The receiver is compatible with most Dolby Dolby and DTS surround sound formats including Dolby TrueHD and DTS-HD Master Audio (up to 5.1 channels). However, it is important to point out that Dolby Atmos and DTS:X are not supported.
Several preset surround processing modes, as well as a compressed music enhancer, are provided. The compressed music enhancer uses audio processing algorithms to restore what is commonly lost with compressed music file formats, such as MP3.
4K/8K/HDR (HDR10, Dolby Vision, HLG are included – HDR10+ will be added with a pending update). video pass-through HDMI ver 2.1 inputs and one HDMI output is provided. HDMI support for ARC/eARC is included.
Yamaha RX-V4A A/V Receiver Rear
NOTE: No analog video inputs or outputs are provided.
For gaming enthusiasts, a pending firmware up will add features such as ALLM (Auto Low Latency Mode) and VRR (Variable Refresh Rate)
The RX-V4A receiver included with the YHT-5960U also incorporates Bluetooth, as well as network connectivity via Ethernet or Wi-Fi, which provides access to Yamaha’s MusicCast streaming platform and works with Apple AirPlay2, and Spotify Connect.
MusicCast also supports wireless multiroom audio with compatible Yamaha wireless speakers, as well as a wireless surround speaker option that you can use in place of the YHT-5960U’s wired surround speakers.
Another MusicCast bonus is voice control compatibility with Alexa, Google Assistant, and Siri.
The Speaker System
The center, front left/right, and surround speakers have the same driver complement (except that the center channel speaker is horizontal). The center channel speaker has two 2-3/4″ 6-ohm drivers in a sealed cabinet (acoustic suspension), while the other speakers each have one 2-3/4″ full-range cone full range 6-ohm driver in a ported cabinet (bass reflex). All the speakers can be a shelf, stand, or wall-mounted.
Yamaha YHT-5960U Speaker System
The provided subwoofer features an 8-inch cone driver supported by its own 50-watt amplifier. The subwoofer also has a front-firing Yamaha twisted flare port (Bass Reflex design) that provides extended low-frequency response.
To make speaker connection easy, the back of the receiver features well-spaced and clearly labeled speaker terminals, with an etched diagram that provides an example of how to connect and place the speakers and subwoofer. All the required speaker connection wires/cables are provided.
YPAO
To optimize the performance of the YHT-5960U, Yamaha includes its YPAO (Yamaha Parametric room Acoustic Optimizer).
Yamaha YPA0
Using a provided microphone and following prompted steps, YPAO analyzes speaker distance, placements, and room acoustics, via test tones generated by the receiver. YPAO then adjusts the system to get the best performance from the receiver and speakers in relation to your room.
TIP: One really great bonus is that since this system includes a standard home theater receiver and speakers from Yamaha’s product line, you can, at a later date, upgrade your system with different speakers and/or subwoofer. The downside, as mentioned previously, is that the receiver is not compatible with the Dolby Atmos or DTS:X immersive surround sound formats.
However, if you want a basic home theater setup with practical features, the YHT-5960U might just be the ticket for you. Take a deep dive into everything that it offers on the official product page
The suggested price of the Yamaha YHT-5960U is $649.95 and is available through several retailers including Amazon and Best Buy.
1 Comment
1 Comment
  1. Joshua L
    December 2, 2021 at 3:17 pm
    Why didn’t you then suggest the direct Yamaha upgrade for those of us who, afyer reading your article, realize we need more wattage? That would have been very helpful
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
Treat the audio enthusiast in your life to the best DTS-powered products this holiday season.
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
