Earbuds & In-Ear Headphones
Yamaha Releases Flagship TW-E7B True Wireless Earbuds
The flagship Yamaha TW-E7B True Wireless Earbuds need to be exceptional considering the competition.
Yamaha TW-E7B True Wireless Earbuds in Charging Case
Yamaha today introduced their flagship TW-E7B true wireless earbuds for $279.95. These feature packed earphones combine proprietary Advanced Active Noise-Cancelling (ANC) with a Listening Optimizer that analyzes and corrects in real time for individual ear shapes and wearing styles.
Key Features
Yamaha TW-E7B True Wireless Earbud ANC Illustration
Advanced Active Noise Cancellation (ANC)
Advanced Active Noise Cancellation (ANC): The headphones analyze and make adjustments to minimize unwanted background noise, but without diminishing the sound quality of the content you want to listen to.
Ambient Sound: The TW-E7B has built-in microphones to monitor ambient sound so that you are still aware of your surroundings in case you need to communicate or react to something outside your listening environment.
Tip: ANC or Ambient Sound don’t work at the same time, but you can select one or the other when needed.
Yamaha TW-E7B True Wireless Earbud Listening Optimizer
Listening Optimizer
Listening Optimizer: Yamaha’s Listening Optimizer feature makes automatic continuous adjustments to compensate for changes in wearing conditions.
Listening Care: Headphone listening can be frustrating because the output across all frequencies isn’t always balanced. As a result, listeners keep turning the volume up and down with a piece of content. Although you will be able to hear the softer frequencies better, the already loud frequencies become louder and can damage your hearing.
Yamaha’s Listening Care feature compensates for this by delivering sound across a wide frequency range and volume setting. You can set the volume once and hear an entire song or movie without fiddling with the volume control.
Qualcomm Inside:  The Yamaha TW-E7B includes Qualcomm® cVc (Clear Voice Capture) to improve voice quality for phone calls, as well as  Qualcomm® TrueWireless™ Mirroring for seamless earbud “role swapping” for a more stable connection with Bluetooth sources while saving power.
In-Ear Detection: Music playback automatically pauses when an earbud is removed and playback resumes when an earbud is re-inserted.
Gaming Mode: A low-latency mode is included for gameplay support or watching videos.
Yamaha Headphone Control App (iOS, Android): This allows you to turn Listening Care, Ambient Sound, and Game Mode features on and off as well making additional adjustments such as EQ (Equalizer) by using your smartphone.
Tip: There are also limited control buttons on the TW-E7B.
Voice Assistants:  The TW-E7B works with both Siri and Google Assistant.
Yamaha TW-E7B True Wireless Earbud Driver Housing
Additional Specifications
  • Driver Size/Type: 10mm/Dynamic
  • Frequency Response: 20Hz-20kHz
  • Microphone: Phone calling is supported by Yamaha’s advanced mic design.
  • Bluetooth Version: 5.2
  • Playback Time (full Charge): Up to 22 hours
  • Playback Time (10-minute charge): One Hour
  • Waterproof Rating: IPX5
  • Charging Time: Approximately 2 hours
  • Weight: 7.3 grams
  • Included Accessories: Storage/Charging Case, USB Power Cable, Eartips
  • Color Choices: Dark Blue, Beige, Black, and White
Yamaha TW-E7B True Wireless Earbuds with Charging Case
Yamaha TW-E7B True Wireless Earbud Accessories
Price & Availability
The Yamaha TW-E7B True Wireless Earbuds are available for $279.95 at Amazon.
To dig deeper into features/specs and purchasing options, check out the official product page and user guide (pdf)
Beyerdynamic Free Byrd Wireless Earbuds: Review
Sennheiser Momentum True Wireless 3 Earbuds: Review
Edifier Neobuds S Noise Canceling Wireless Earbuds: Review
LG Introduces T90 And TF8 Tone-Free Wireless Earbuds
Cleer ARC True Wireless Earbuds: Review
Astell&Kern UW100 Wireless Earbuds: Review
1More Evo Wireless Noise Canceling Earbuds: Review
Klipsch And EAR Micro Unveil The T10 Ear Computers
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
At $299, the Bose Ultra Open Earbuds offer excellent situational awareness, support for Snapdragon Sound, and one surprising feature.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
With enhanced adaptive noise cancellation and a new driver design, Technics latest True Wireless Earbuds will give Bose, Sony and Sennheiser a run for...
