Yamaha Soavo NS-F901 Loudspeakers
Yamaha Soava NS-F901 Loudspeakers
Yamaha just introduced its next generation of Soavo 3-way bass reflex floor standing loudspeakers. The NS-F901 feature new speaker units that have undergone extensive sound quality tuning. Proprietary advanced polymer-injected mica diaphragm (A-PMD) midrange drivers, which have the extreme lightness, rigidity and stability complement A-PMD woofers with large ferrite non-shielded magnets to provide high-drive power and ample bass volume. Aluminum dome tweeters, which provide both material hardness and responsiveness, are combined with neodymium magnets to deliver sound that smoothly links midrange and high frequency output.
The NS-F901 Soavo speakers are made with non-parallel surfaces, slanted partitions between the woofer and midrange sections and vertical ladder bracing to reduce vibration and achieve superior sound reproduction. To generate more powerful and accurate bass, Yamaha employs 3-way mitered construction to ensure extremely tight joints that make the speakers behave as super stable single-piece units.
Yamaha Soava NS-F901 Loudspeakers InsideThe crossover networks employ the highest quality parts, including Solen metalized polypropylene capacitors and large iron-core coils with carefully selected wire. All parts are connected by directly soldering each one individually, instead of using printed circuit boards, further contributing to the rich and vivid sound. Finally, meticulous sound tuning ensures optimum transitions between drivers for smooth and natural sound across the entire frequency range.
“The NS-F901 Soavo speakers are a definitive statement for Yamaha, as they embody the innovation and pristine natural sound quality for which we have always been known,” said Bob Goedken, general manager, Yamaha Corporation of America, AV Division. “These speakers deliver the sublime and transcendent listening experience of being with an artist for their performance in a studio or concert venue. It just doesn’t get better.”
Pricing and Availability
The Yamaha NS-F901 Soavo speakers are currently available for $5,000/pr in piano black finish.
Specifications
Type 3-way bass reflex floorstanding speaker system
Woofers Dual 6-1/2” A-PMD cone
MidRange Driver 5” A-PMD cone
Tweeter 1” aluminium dome
Frequency Response 32 Hz-50 kHz
Nominal Input Power 50 W
Maximum Input Power 200 W
Sensitivity 89 dB / 2.83 V / 1 m
Crossover Frequencies 450 Hz / 3.5 kHz
Impedance 6 ohms
Dimensions (W x H x D) 10-5/8” x 41-3/4” x 16-3/4”
Weight 67 lbs. / unit
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
The very best personal audio experience from Yamaha combines the new HA-L7A headphone amplifier and YH-5000SE headphones. Total system cost is $9,000.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
Yamaha's new True X soundbar lineup includes two soundbar models, an optional wireless subwoofer, and optional wireless surround speakers.
