Yamaha A-S3000 Integrated Stereo Amplifier
Yamaha A-S3000 Integrated Amplifier
Yamaha just released its flagship A-S3000 integrated stereo amplifier costing $8,000 for audiophiles who crave the utmost in 2-channel fidelity. The company says the A-S3000’s floating and balanced design, with MOSFETs and a large toroidal transformer mounted within an independent three-dimensional inner frame, produce a warm tube-like sound. Yamaha further boasts the A-S3000 was designed-by-ear to create closer bonds between artists and listeners for truly elevated audio experiences.
The A-S3000 offers the ultimate expression of Yamaha’s craftsmanship, featuring anti-vibration and distortion eliminating measures, including a rigid streamlined construction with the shortest possible cabling routes. The components’ classic styling includes clean lines and rich black piano finish side panels along with large eye-catching level meters.
Yamaha A-S3000 Integrated Amplifier - Back
Features:
  • Rigid streamlined construction — provides strict anti-vibration protection and enables shortest cabling routes
  • Large toroidal transformer, solidly mounted with independent three-dimensional inner frame
  • Comprehensive low impedance design, shortened signal paths and copper-plated chassis
  • 1/4″ thick top panel made of non-magnetic aluminum plate
  • Left-right symmetrical design for independent pre amp and power amp blocks
  • Floating and Balanced Power Amplifier with MOSFETs
  • All-stage balanced transmission
  • Direct drawing toroidal transformer for complete elimination of signal transmission loss
  • Exceptionally low impedance through secure screw connections
  • Superior quality electronic volume control for optimum sound
  • Discretely configured phono amp
  • Exquisite, large level meters reflect the dynamics in the music
  • Meticulously designed and beautiful in appearance — just like a musical instrument
  • Original speaker terminals for high sound quality, as well as beauty and ease of use
  • Obsessive, meticulous switch design — elaborate, richly textured, easy-to-use
Pricing and Availability
The Yamaha A-S3000 will be available exclusively at authorized Yamaha dealers in September 2013 for $7,999.95.
Specifications
Maximum Power (8 ohms, 1 kHz, 10% THD) 130 W + 130 W / (4 ohms, 1 kHz, 10% THD) 210 W + 210 W
Minimum RMS Output Power (8 ohms, 20 Hz-20 kHz, 0.07% THD) 100 W + 100 W / (4 ohms, 20 Hz-20 kHz, 0.07% THD) 150 W + 150 W
Dynamic Power/Channel (8 / 6 / 4 / 2 ohms) 120 / 150 / 200 / 300 W
Damping Factor (8 ohms, 1 kHz) 250
Input Sensitivity/ Impedance CD 200 mV / 47 kilohm, Phono MM 2.5 mV / 47 kilohm, Phono MC 100 μV / 50 ohms, Main in 1 V / 47 kilohm
Frequency Response CD, etc. to speaker out, Flat position 5 Hz-100 kHz +0 dB / -3 dB, CD, etc. to speaker out, Flat position 20 Hz-20 kHz +0 dB / -0.3 dB
RIAA Equalization Deviation Phono MM (20 Hz-20 kHz) ±0.5 dB / Phono MC (20 Hz-20 kHz) ±0.5 dB
Total Harmonic Distortion (20 Hz–20 kHz) CD balanced to speaker out 0.025% (50 W / 8 ohms), CD, etc. to speaker out 0.025% (50 W / 8 ohms), Phono MM to Rec Out 0.005% (1.2 V), Phono MC to rec out 0.02% (1.22 V)
Signal-to-Noise Ratio [IHF-A Network] CD, etc., (200 mV, Input Shorted) 103 dB, Phono MM (5 mV, Input Shorted) 93 dB, Phono MC (500 μV, Input Shorted) 85 dB
Residual Noise CD, etc., IHF-A-Network
Channel Separation (1 kHz/10 kHz) CD, etc., Input 5.1 kilohm Terminaled 74 dB / 54 dB, Phono MM, Input Shorted, Vol: -30 dB 90 dB / 77 dB, Phono MC, Input Shorted, Vol: -30 dB 66 dB / 77 dB
Tone Control Characteristics Bass Boost / Cut (at 50 Hz) ±9 dB, Bass Turnover Frequency 350 Hz, Treble Boost / Cut (at 20 Hz) ±9 dB, Treble Turnover Frequency 3.5 kHz
Audio Muting -20 dB (approx.)
Load Impedance If you use two sets (A and B), the impedance of each speaker must be 8 ohms or higher.
Dimensions (W x H x D) 17-1/8” x 7-1/8” x 18-1/4”
Weight 54.2 lbs.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
The very best personal audio experience from Yamaha combines the new HA-L7A headphone amplifier and YH-5000SE headphones. Total system cost is $9,000.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
Yamaha's new True X soundbar lineup includes two soundbar models, an optional wireless subwoofer, and optional wireless surround speakers.
