Yamaha NS-SW1000 1,000-watt Powered Subwoofer
Yamaha NS-SW1000 Subwoofer
Yamaha today introduced the flagship NS-SW1000 1,000-watt subwoofer that integrates the company’s signature technologies to deliver superior bass to premium home theater systems for $2500. This serious bass blaster tips the scales at over 90 lbs!
The NS-SW1000’s innovative cabinet design features Yamaha’s own Twisted Flare Port that delivers a smooth flow of air to reduce extraneous noise and achieve the perfect tuning of the subwoofer enclosure. The model also shows off an impressive black gloss finish, reminiscent of a Yamaha grand piano, which provides a touch of elegance to any living space.
This subwoofer features a 3-way mitered construction that ensures extremely tight joints, which enable its entire cabinet to behave and respond as a single unit, allowing for powerful and accurate bass reproduction without noise-causing vibration. The heavy bass reflex enclosure is constructed of thick, medium-density fiberboard and is supported by cast-iron legs for added stability to guard against distortion at any volume.
Yamaha NS-SW1000 Subwoofer Gloss Black
Advanced Yamaha Active Servo Technology II dynamically compensates for the negative effects of speaker impedance and this helps maintain superior control of the subwoofer’s driver for clean audio reproduction.
The NS-SW1000 uses the latest Yamaha DP200 digital amplifier integrated circuit, which supports a high current MOSFET discrete push-pull design for the output stage. This, along with a triple-wound litz wire, high capacity output coil and specially designed capacitors allow this subwoofer to reproduce extremely powerful low frequencies.
The NS-SW1000’s 12-inch driver incorporates Kevlar fibers in the cone and is able to generate long strokes with superior linearity due to its twin-stacked, large diameter ferrite magnets with double dampers and air vent. Delicate tonal nuances are seamlessly reproduced with the help of an aluminum die-cast frame that suppresses unwanted resonance and provides extra strength for optimal performance.
Yamaha NS-SW1000 Subwoofer Drive
To conserve energy, the NS-SW1000 has Auto Power Standby that turns the subwoofer off when no signal is received for a period of time and back on when an audio signal is detected by the subwoofer’s amplifier. A system control is also available and will automatically turn the unit on and off when connected to compatible devices.
“The NS-SW1000 is the latest evolution of the subwoofer, representing our best technologies and structural design elements to deliver uncompromised sonic performance,” said Bob Goedken, general manager, AV Division, Yamaha Corporation of America. “Every component, including the black gloss finish, has been carefully considered to meet the demands of those seeking superior listening experiences.”
Pricing and Availability
The Yamaha NS-SW1000 will ship in June 2015 for $2,499.95.
Specifications
Driver 12″ cone
Output Power 1,000 W
Frequency Response 18–160 Hz
Advanced YST Advanced YST II
Twisted Flare Port Yes
Auto Standby Yes
Standby Power Consumption 0.3 W
System Connector Yes
Bass Action Selector Switch Yes
Phase Control Yes
Aluminum Front Panel Yes
Power and Volume Switch Yes (front panel)
Dimensions (W x H x D) 17-3/8” x 18-3/16” x 20-5/8”
Weight 90.4 lbs.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
