Yamaha Launches First Ever XM Satellite-Ready Digital Home Theater Receivers — Four From the RX-V Series and Three From the HTR Series
1RXV757BFU
YAMAHA LAUNCHES FIRST EVER XM SATELLITE-READY DIGITAL HOME THEATER RECEIVERS —-FOUR FROM RX-V SERIES AND THREE FROM HTR SERIES
New Affordable Receivers Feature 6.1 Channel and 7.1 Channel Models with Cinema DSP, Dolby Pro Logic IIx, DTS-ES Matrix 6.1, Component Video Up Conversion and Yamaha Parametric Room Acoustic Optimizer
BUENA PARK, CA —- Yamaha Electronics Corporation, the innovator in home theater and digital audio and video reproduction, today introduced four new affordable A/V digital home theater receivers equipped with XM Satellite Radio capability (XM-Ready) that will enhance and diversify the overall home entertainment experience at a variety of reasonable price points, beginning as low as $349.95 MRSP.
Yamaha will be first to market with its new line of XM-Ready A/V receivers. The RX-V757, RX-V657, RX-V557 and RX-V457 will allows users to plug an XM Connect-and-Play home antenna into the Yamaha XM-Ready A/V receiver and activate the XM service to receive 150-plus digital radio channels. No additional accessories or installation are required. Using XM’s industry-leading chipset technology, as well as a new proprietary chip and signaling protocol, the XM Connect-and-Play home antenna is capable of receiving XM’s satellite and terrestrial signals as well as channel tuning, decoding and audio transmission. It will be the only accessory needed to get XM through an XM-Ready Yamaha component.
The RX-V757 and RX-V657 include an essential feature called YPAO (Yamaha Parametric Room Acoustic Optimizer), which is a technology that completely simplifies the home theater set-up process by automatically optimizing room acoustics via a parametric equalizer. YPAO will then sets parameters for optimum sound quality at the listening position at the touch of a button.
The 7.1 channel RX-V757 and RX-V657, and the 6.1 channel RX-V557 and RX-V447 receivers all feature Quad-Field Cinema DSP, Dolby Pro Logic IIx, Dolby Digital , Dolby Digital-EX, DTS Digital Surround, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS Neo:6 and DTS96/24 decoding with extreme accuracy. All models have high-current discrete amplification for the highest quality sound reproduction, and easy-to-use setup menu with 5-band center channel EQ and night listening modes. In addition, all of the new receivers use Yamaha’s Digital ToP-ART technology, which maximizes digital quality while minimizing analog circuitry by bringing together several key elements to create the best-sounding, user friendly A/V components available.
Yamaha’s advanced Quad-Field CINEMA DSP system provides a choice of 14 realistic-sounding surround programs. It is capable of delivering 6.1 or 7.1 channels of sound that is compatible with all the latest surround sound formats. When used with front presence speakers, the Dialogue Lift function ensures correct sound imaging when the center speaker is placed below a large screen and enables users to make extensive adjustments to achieve optimum sound quality. It offers a Direct Stereo mode for high quality two-channel sound reproduction. The receivers also offer a SILENT CINEMA mode for enjoying surround-like sound through headphones.
The RX-V757, with a suggested retail price of $649.95, is a highly sophisticated 7.1 channel A/V receiver that is rated at 100W x 7 high discrete power (20Hz-20 kHz) and features an on-screen display and a preset remote control with an LCD display. XM channel information is displayed on the front panel and can also be viewed on the on-screen display. XM programming can also be enjoyed via the Zone 2 output.
For true audiophiles, the Pure Direct feature ensures highest-quality sound reproduction with both analog and digital sources. A Night Listening Enhancer ensures that all programs (including Dolby Pro Logic IIx) sound natural at lower volume levels.
Other features include eight-channel analog inputs for external decoders to accommodate high-resolution audio formats like DVD-Audio, SACD (or other future formats); four optical and two coaxial input terminals; one optical output terminal; front-panel A/V inputs with a digital input; two component video inputs and one output with HDTV 720p/1080i compatibility; five total video inputs and two outputs; S-video connections for all inputs and outputs; and a phono input. The receiver does full component video-up conversion from composite and S-video, to provide high-quality picture from all video components connected to the receiver for optimal viewing. In addition, the 96 kHz/24-bit digital-to-analog converters are used for all seven channels.
Next in the series is the RX-V657 (95W x 7) discrete A/V receiver (20Hz-20kHz), which replaces the RX-V650 and is priced at $549.95. This new model has all of the features of the RX-V757 except for the LCD on the remote control and phono input connection.
The RX-V557, priced at $449.95, replaces the RX-V550 and is a 6.1-channel home theater receiver that is rated at discrete 90W x 6 channels (20Hz-20kHz). Other important features include component video-up conversion from composite and S-video at a low price point; two component video inputs and one output for HDTV 720p/1080i compatibility; four total video inputs and one outputs S-video connections for all inputs and outputs; six-channel external decoders to accommodate future formats; three optical and one coaxial input terminal, one optical output terminal; a front panel A/V input; A/B speaker switching; and a preset remote control.
The most affordable receiver in the new series is the (85W x 6) RX-V457, which replaces the RX-V450 and is priced at $349.95. This unit has all of the features of the RX-V557, but only has two optical and one coaxial digital input terminal, one optical digital output terminal, and is without video conversion and has S-video connections. All of the RX-V457’s many capabilities are easily controlled via a luminescent preset remote control with colored buttons.
In addition, Yamaha will release four new receivers from their HTR-series beginning at $229.95 MSRP, three of which are XM-Ready from $349.95 MSRP to $549.95 MSRP and will be available in April for mass-channel distribution. Yamaha will also introduce several XM-Ready home-theater-in-a-box-solutions from its YHT line of products for mass-channel distribution.
For more information, write Yamaha Electronics Corporation, P.O. Box 6660, Buena Park, CA 90622; telephone (714) 522-9105; email infostation@yamaha.com; or visit www.yamaha.com/home.
–END–
About Yamaha
Yamaha Electronics Corporation (YEC), USA, based in Buena Park, California, is a wholly owned subsidiary of Yamaha. YEC offers Home Theater components and systems, featuring A/V Receivers, Amplifiers, DVD/CD, Speakers, Mini-Systems, Video Projection, as well as A/V & IT Convergence Products
Press Contact:
Steve Massinello / Giles Communications
(914) 798-7127 (smassinello@giles.com)
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
The very best personal audio experience from Yamaha combines the new HA-L7A headphone amplifier and YH-5000SE headphones. Total system cost is $9,000.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
Yamaha's new True X soundbar lineup includes two soundbar models, an optional wireless subwoofer, and optional wireless surround speakers.
