CD Players
Yamaha CD-S3000 CD/SACD Player
Yamaha CD-S3000 SACD Player
Yamaha just released their flagship CD-S3000 CD/SACD player costing $7,000. It features the exceptionally high performing 32-bit ESS SABRE32 REFERENCE DAC that provides unprecedented dynamic and expressive sound from all disc-based media. The CD-S3000 player accomplishes superior vibration control and ultra-precise signal reading via an optimized high-precision rigid CD mechanism.
The CD-S3000 was created with meticulous care to ensure rigidity with superior vibration control properties and ultra-precise reading—to draw out all the music recorded to the disc. Yamaha incorporated a newly designed drive mechanism with added heavy anchors in front of and behind the loader mechanism to achieve the highest rigidity and block vibrations from inside and out.
Each CD-S3000 unit is assembled by first attaching the drive mechanism to the chassis, then carefully performing minute horizontal adjustments. While this process is time-consuming and labor-intensive, it demonstrates Yamaha’s genuine desire to realize the ultimate in precise signal reading. These efforts eliminate any minute tilting of the mechanism, achieving stable rotation and ultra-precise signal reading. Reducing the load of the servo which drives the pickup, in order to minimize the impact of servo current changes to the signal, provides a clean signal output that is virtually unaffected by noise. In addition, the loader mechanism has a structure in which a highly rigid chassis designed for integration with the loader mechanism supports the entire CD drive. Moreover, Yamaha applied only the strictest selection of parts for the pickup, which aims a beam of light at the disc as it rotates at high speed to read the signals, and a drive mechanism which stably rotates the disc. This is how audio data on the disc is read with high precision to achieve the highest purity in reproduction.
Features:
  • Optimized high-precision rigid CD mechanism with heavy anchors improves vibration control and achieves precise signal reading
  • High rigidity aluminum CD tray
  • High rigidity main chassis improves anti-vibration properties and left-right symmetrical construction
  • Independent configuration of digital and analog circuits
  • Digital / analog boards with integrated power supply circuits
  • Single-stage configuration I / V conversion circuit enables direct analog output
  • Exceptionally high performance 32-bit D/A converter
  • Built-in USB DAC functions
  • ASIO 2.3 Yamaha Steinberg USB driver
  • Pure Direct mode further enhances the quality of analog sound
Pricing and Availability
The Yamaha A-S3000 and CD-S3000 will be available exclusively at authorized Yamaha dealers in September 2013 for $6,999.95.
Yamaha CD-S3000 SACD Player Back
Specifications
Disc Compatibility SA-CD, CD, CD-R/RW (MP3, WMA) and USB devices
Output Level 2 +/- 0.3 V (1 kHz, 0 dB)
Signal-to-Noise Ratio 116 dB
Dynamic Range [CD] 100 dB, [Super Audio CD] 110 dB
Harmonic Distortion [CD] 0.002% (1 kHz), [Super Audio CD] 0.002% (1 kHz)
Frequency Response [CD] 2 Hz-20 kHz, [Super Audio CD] 2 Hz-50 kHz (-3 dB)
Dimensions (W x H x D) 435 x 142 x 440 mm; 17-1/8” x 5-5/8” x 17-5/16”
Weight 19.2 kg; 42.3 lbs.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
The very best personal audio experience from Yamaha combines the new HA-L7A headphone amplifier and YH-5000SE headphones. Total system cost is $9,000.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
Yamaha's new True X soundbar lineup includes two soundbar models, an optional wireless subwoofer, and optional wireless surround speakers.
