Yamaha AVENTAGE RX-A 60 Series AV Receivers Add MusicCast
Yamaha VENTAGE RX-A 60 Series network AV receivers
Yamaha today announced six new premium AVENTAGE RX-A 60 Series network A/V receivers, priced from $650 to $2,200. These new home theater receivers are said to be crafted with the highest-quality components that are obsessively matched and engineered using short signal path runs, painstakingly grounded circuit boards and secure anchoring by a sturdy frame-and-beam chassis design, all to provide the ultimate sonic excellence. These models replace the AVENTAGE RX-A 50 line-up from last year.
Like the growing family of Yamaha wireless speakers, sound bars and Hi-Fi gear, AVENTAGE RX-A 60 Series AV receivers include the ability to play and distribute the exclusive MusicCast wireless multiroom audio system. MusicCast offers more flexibility than other wireless multiroom audio solutions with built-in Wi-Fi and Bluetooth for added connectivity to music services and to smartphones or tablets to easily stream music through the AV receiver.
4K Ultra HD video and HDMI ports capable of high dynamic range (HDR) pass through are included in all six AVENTAGE RX-A 60 Series models. This ensures the ability to see pictures with eight-times higher resolution than 1080p full HD and the widest possible contrast ratio, ranging from nearly perfect black to more than 1,000 nits of peak brightness. The result is breathtakingly pristine 4K Ultra HD video supporting: 3840 x 2160p resolution; up to 60 Hz high frame rates; coverage of the BT.2020 wide color gamut; 10 / 12-bit color; 4:4:4 chroma subsampling and HDCP 2.2 copy protection.
Additionally, all models support high-resolution audio music files including: ALAC at 96 kHz / 24 bit, WAV, AIFF, FLAC up to 192 kHz / 24 bit, DSD to 5.6 MHz. Vinyl music aficionados will find that AVENTAGE AV receivers, starting with the RX-A760 through the RX-A3060, have a phono input with preamp support for turntables with cartridges. With MusicCast, these AV receivers can even send music from a turntable wirelessly to MusicCast-enabled products in other rooms in the house. The MusicCast app ties it all together with simple-to-use operation using iOS or Android smart devices.
All AVENTAGE RX-A 60 Series AV receivers include the proprietary YPAO sound optimization system, which has garnered growing acclaim for its ability to automatically analyze speaker placements, then tune and calibrate sound levels to the dynamics of the specific listening environment. AVENTAGE AV receivers ensure the sound experience is tailored to the unique conditions of each home. Subwoofer equalization (EQ) is supported in all AVENTAGE RX-A 60 Series models and the RX-A760 model on up benefit from subwoofer parametric EQ down to 15.6 Hz. Further, the Yamaha Compressed Music Enhancer is now optimized for Bluetooth audio transmission to ensure wirelessly delivered music remains clean, crisp and complete with a full range of sound. Dolby Atmos and DTS:X is support in all models.
The AVENTAGE RX-A660 is a high-performing, base-level model featuring 7.2-channel surround, four HDMI inputs and one output with HDCP 2.2 copy protection supporting 4K Ultra HD video resolution with HDR and BT.2020; Dolby Atmos and DTS:X object-based surround sound speaker setups of 5.1.2 channels; built-in Wi-Fi and Bluetooth wireless connectivity and YPAO sound optimization. The AV receiver outputs 80 W per channel and includes Extra Bass to enrich sound even with small speakers and high-resolution audio playback.
The AVENTAGE RX-A760 features 7.2 channels with Dolby Atmos and DTS:X set up to 5.1.2 channels or can output 5.1 channels plus Zone 2 with auto switching. The AV receiver steps up to 90 W per channel; six HDMI inputs (three with HDCP 2.2); one HDMI/HDCP 2.2 output and includes: phono input; Rhapsody and SiriusXM Internet Radio; YPAO with Reflected Sound Control (R.S.C.) and intelligent assignable amps.
The AVENTAGE RX-A860 is a 7.2-channel network AV receiver that enables Dolby Atmos and DTS:X setups of 5.1.2 channels or a 5.1 channel plus Zone 2 with auto switching. The AV receiver steps up to 100 W per channel; eight HDMI inputs (three with HDCP 2.2) and dual HDMI/HDCP 2.2 outputs. The receiver includes: YPAO R.S.C. with multipoint measurement and a vanity door front panel. Also included are intelligent assignable amplifiers with the user’s choice of surround back or front presence channels.
The AVENTAGE RX-A1060 features 7.2 channels and enables a Dolby Atmos and DTS:X setup of 5.1.2 channels or can output 5.1 channels plus Zone 2 with auto switching. The AV receiver steps up to 110 W per channel; eight HDMI inputs (seven with HDCP 2.2) and dual HDMI/HDCP 2.2 outputs. The AV receiver also features: symmetrical amp layout; advanced dual ESS SABRE DACs for quieter and more fluid sound and YPAO R.S.C. with multipoint measurement with a 7.1-channel equalizer. Other features include: advanced HDMI zone switching that allows all sources to be output via HDMI to a second zone and Zone 2 features including Zone Volume EQ, Zone Extra Bass and Zone Enhancer.
The AVENTAGE RX-A2060 boasts 9.2 channels in a network AV receiver that enables Dolby Atmos and DTS:X speaker setups of 5.1.4 or 7.1.2 channels. The AV receiver steps up to 140 W per channel and includes dual ESS SABRE DACs and YPAO R.S.C. with 3D, multipoint and angle measurement and 9.2-channel equalizer.
Yamaha AVENTAGE RX-A3060 network AV receiver
The flagship AVENTAGE RX-A3060 features 11-channel processing in a network AV receiver and enables Dolby Atmos and DTS:X setups of 5.1.4 channels, 7.1.2 channels or 7.1.4 channels (with an external 2-channel amplifier). The AV receiver steps up to 150 W per channel; ESS SABRE 32-bit DAC with the ability to fine-tune ultra-low jitter phase lock loop (PLL) mode to exactly the desired level; and YPAO R.S.C. with 3D, multipoint, 11.2-channel precision equalizer and 64-bit resolution.
Price and Availability
The new Yamaha AVENTAGE models will be available exclusively at authorized Yamaha AV dealers with the following MSRPs:
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Yamaha expands its premium headphone lineup with the YH-4000 open-back and YH-C3000 closed-back models, featuring advanced drivers, handcrafted housings, and high-end comfort.
All 2020 Yamaha wireless headphones feature proprietary adaptive technology that allows listeners to hear full-range sound even at low volume settings. The top models...
The flagship Yamaha TW-E7B True Wireless Earbuds need to be exceptional considering the competition.
Can the Yamaha TW-E5B True Wireless Earbuds compete with Sony, Sennheiser, and Final Audio at this price point?
At $3,499, Yamaha's new flagship Dolby Atmos soundbar features sound beam technology with AI, but does performance justify its price?
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
Yamaha's flagship AVENTAGE A/V Receivers now "Work with Sonos" thanks to a free firmware update enabling multi-room audio with Sonos Port.
