Yamaha A-S500 Integrated Amplifier / T-S500 Tuner
Yamaha announced the A-S500 integrated amplifier and T-S500 matching tuner hi-fi components. With 85 watts per channel output, dual aluminum extruded heat sinks and the highest-quality parts, the A-S500 is a work of audio technology art. Yamaha's Pure Direct technology enables signal to travel the shortest possible route, bypassing non-essential circuitry and tone controls for the purest reproduction of sound. With a full array of digital AM/FM tuning capabilities and features, the optional T-S500 tuner is an excellent addition to the A-S500.
A-S500 Integrated Amplifier$449.95 (Available End of October)
The A-S500 is designed for superb musical expression with high performance, outstanding power and sound quality combining ToP-ART technology and ART Base chassis construction with gold–plated speaker terminals and dual aluminum heat sinks and a Center Bar for crisp, clean sound. Advanced features include continuously variable loudness control, Pure Direct, along with Yamaha iPod dock connection, for endless music enjoyment options.
Features
  • Dual aluminum-extruded heat sinks ensure effective heat dissipation and help achieve crisp, clean sound.
  • Gold-plated speaker terminals and RCA in/out jacks are durable and provide highest quality connections.
  • Center bar reinforces the internal structure to further prevent vibration from affecting the sound quality.
  • Pure Direct uses the shortest signal route for higher sound purity with low noise and transmission losses.
  • Yamaha's exclusive Continuously Variable Loudness Control for listening at low volumes.
  • The built-in iPod Dock has an independent power supply for extremely high S/N ratio.
Specifications
  • 85W x 2 high power output
  • ToP-ART (Total Performance Anti-Resonance Technology)
  • Aluminum-extruded front panel
  • Subwoofer out
  • Speaker A, B or A+B selection
  • Rec Out selector
  • Power management (Auto power off)
  • Slim-design remote control
  • Dimensions (W x H x D): 17-1/8″ x 6″ x 15-1/4″
Yamaha T-S500 Tuner
T-S500 AM/FM Stereo Tuner$299.95 (Available End of October)
A user-friendly tuner that provides convenient tuning functions and a high visibility, two-line display. Uses Yamaha's new HiFi component design that matches the A-S500 Integrated Amplifier.
Features
  • 40-station AM/FM preset tuning
  • All 40 stations can be accessed with two turns of the rotary encoder knob, after which it stops. Favorite stations can be set at either end for greater convenience.
  • Auto FM Station Memory
  • Automatically presets the 40 strongest FM stations on the dial so you don't have to select and preset them manually.
  • Multi-Status Station Memory
  • Thanks to Multi-Status Station Memory, each station memory includes the parameters set when it was memorized, for optimum quality each time it is selected.
  • 2-line, 16-character (5×7 dot matrix) display
  • This high and wide display offers better visibility than previous types (1-line, 11-character displays). It provides a larger amount of more precise information, making the tuning operation easier.
  • Auto search and manual tuning
  • IR Sensor on Front Panel
  • Allows the remote control from Yamaha Integrated Amplifiers (including the A-S500) to control the tuner
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
The very best personal audio experience from Yamaha combines the new HA-L7A headphone amplifier and YH-5000SE headphones. Total system cost is $9,000.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
Yamaha's new True X soundbar lineup includes two soundbar models, an optional wireless subwoofer, and optional wireless surround speakers.
