Audio Cables
XLO Cables Updated Reference 3 and Signature 3
Ultralink/XLO Products will feature completely updated Signature 3 and Reference 3 interconnects and cable lines at CES. The new interconnect and speaker cables are custom-drawn 99.99998% (“Six Nines”) pure Laboratory Grade copper. Signature 3’s higher specification calls for UP-OCC 6N copper (Ultra Pure Ohno Continuous Casting process), a material so expensive it’s sold by the gram. Proprietary Integrated Field Winding Geometry — how each signal-bearing conductor is arrayed relative to the others — is optimized for the interactive relationship between current-controlled electromagnetic fields formed around a cable’s conductors, and the electrostatic fields formed around its insulation when an audio or digital/video signal passes.
XLO Reference 3 Cables
Reference 3 and Signature 3 are designed with to minimize capacitive discharge effects. As current passes through insulated conductors capacitance effects store signal energy in the surrounding dielectric material that’s either turned into heat or quickly released out of phase back into the signal path as soon as the polarity changes. That leads to signal cancellations, reduced low-level detail, smearing, and out-of-phase artifacts causing spurious sound or picture distortions!
XLO reduces stored energy with low-mass dielectrics and by using the best materials with the minimum dielectric constant and the fastest release rate — the quicker the energy returns from the dielectric, the less distortion in the signal.
But that doesn’t stop Ultralink/XLO, a company in an excellent position to get closer to… the sound of nothing. “We control the manufacturing of our own product, just as we’ve done for more than 15 years,” enthuses XLO’s president Allen Sung, “giving us 100 percent quality control backed with a lifetime warranty. We have the capacity, machining and engineering expertise to work the conductor and dielectric materials. We design and produce all our specialist connectors. The product is of such quality,” Allen smiles, “that it’s supplied OEM to a surprising number of other brands.”
Even our hand-terminated connectors are direct-plated 24k gold with no shiny but poor-sounding Nickel substrate: Nickel is ferrous and becomes magnetized when passing signal current. The magnetic field is modulated by the electrical signal and the connector retains a residual magnetic charge. Making our own connectors also allows XLO to ensure constant impedance from one end to the other.
Price and Availability
Retail prices start at $290 for Reference 3 half meter audio pair and $590 for Signature 3 half meter audio pair.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
