XGIMI’s MoGo 2 Pro Compact Video Projector Takes Cinema Outdoors
The XGIMI MoGo 2 Pro Projector offers portability, 1080p resolution, HDR 10 support, and 3D capability.
XGIMI Mogo 2 Pro Projector
XGIMI first previewed the MoGo 2 Pro just before CES 2023, and we’ve been waiting for this very compact projector to finally arrive because it is almost time to take the movies back into the backyard.
Built on the foundation of its MoGo 2, the Pro includes most of the same features but adds some refinements that elevate its performance and practicality with simple setup and operation.
Hand picking up XGIMI Mogo 2 Pro Projector
Features
Product Design: The MoGo 2 Pro features a sleek and minimalist design with a weight of 2.4 pounds, and a height of 6.33 inches. This makes it easy to place and set up with limited room space.
Display Technology: The MoGo 2 Pro has a native 1080p display resolution (supported by a .23-inch DLP imaging chip) and a light output rating of 400 ISO lumens (via 25,000 use hour rated LED light source). HDR 10 support and both 2D and 3D viewing options are included (glasses require optional purchase).
Tip: 400 lumens isn’t typically enough light to support a high-contrast projected image, and the inclusion of HDR support is interesting considering the projector’s modest lumens output. Check out XGIMI’s luminance testing procedure
XGIMI Mogo 2 Pro Projector for Outdoor Movies
Portability: The MoGo 2 Pro can be moved and placed in any room of the house, or even travel with you. Even traditional projectors have to be painfully set up again and again, at each new location – this is time-consuming and inconvenient. However, XGIMI has thought of that too, and has come up with a creative solution.
  • Product Size (HWD): 161 × 119 × 108mm (6.33 × 4.68 × 4.25 Inch) 8
  • Product Weight: 1.1kg (2.42lb)
ISA (Intelligent Screen Adaptation): Building on their current ISA  (Intelligent Screen Adaption) technology, which includes Autofocus, Automatic Vertical Keystone Correction, Obstacle Avoidance, and Intelligent Screen Alignment. XGIMI has also added three enhancements for the 2.0 version: Seamless Auto Keystone Correction, Seamless Auto Focus, and Intelligent Eye Protection.
Tip: Most ISA functions take place without interrupting projection which is great as it doesn’t impair the viewing experience while being noticeably faster and more accurate. Intelligent focusing and stabilization occur automatically and are unnoticed by the user, as there is no physical set-up or waiting time compared to ISA 1.0.
Screen Size: The MoGo 2 Pro can project an image as large as 200 inches. The complete size range is 40 to 200 inches.
Smart Features: The MoGo 2 Pro incorporates the Android TV OS (ver 11) and Chromecast Built-in which provides access to abundant streaming content.
Wired Connections: 1 HDMI, 1 USB Type A, 1 USB C, Auxillary Audio output
Wireless Connections: WiFi, Bluetooth 5.0 (allows direct streaming from compatible smartphones and tablets). This allows you to use the MoGo 2 as a Bluetooth speaker.
Built-in Speaker System: 2×8 watts per channel. Dolby Audio, Dolby Digital, Dolby Digital Plus decoding (mixdown to 2 channels for audio playback)
Control: Bluetooth Remote with built-in Google Assistant Support via built-in mic.
XGIMI Mogo 2 Pro Projector Powerbank
Portable Power:  The MoGo 2 Pro can be powered by a direct connection to AC power or a plug-in power bank.
Included Accessories
  • Power Cable
  • User Manual
  • Warranty Card
  • Bluetooth Remote Control with AAA Batteries
XGIMI Mogo 2 Pro Projector Outdoors on Blanket
Price and Availability
The Mogo M2 Pro is available for $599 at XGIMI.com and is coming soon to Amazon and Best Buy. The step-own MoGo 2 is available for $399. A $50 Off coupon is available for a limited time. Shipping and wider availability will begin on April 25, 2023.
XGIMI Mogo 2 and Mogo 2 Pro Projectors
Differences
XGIMI MODELMoGo 2 MoGo 2 Pro
Native Resolution720p HD 1080p FHD (Full HD)
ISA (Intelligent Screen Adaptation) Version 1Version 2
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Podcasts
Find out who won and what happened at the 2025 UST Projector Showdown where 8 projectors were compared side-by-side.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Priced from under $2,700 to $6,000, this year's top eight UST projectors faced off against each other for the title of Best UST Projector...
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
UST Projector fans, get ready. The annual UST Showdown is scheduled for this weekend. Which of these eight high performance projectors will rise to...
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
The Wanbo Vali 1 and T2 Ultra are affordable LCD projectors offering sharp 1080p resolution, practical features, and flexible setup.
Four new Epson lamp-based 3LCD projectors feature high-brightness and versatile connectivity for under a grand.
