XGIMI Announces HORIZON Ultra 4K UHD Projector with Dolby Vision
With support for Dolby Vision, UHD 4K, and some rather unique setup features, the XGIMI HORIZON Ultra 4K Projector looks like a great option for backyard theaters and smaller rooms.
XGIMI Horizon Ultra 4K Projector
Building on its success in the UST and portable video projector categories, XGIMI has announced the HORIZON Ultra which supports UHD 4K, Dolby Vision, and offers advanced setup features making it a rather compelling option for those looking for a high-end outdoor projector.
The XGIMI HORIZON Ultra was a recent recipient of the 2023-2024 EISA Award in the projector category against some rather stiff competition.
XGIMI Horizon Ultra 4K Projector in daylight
Features
Product Design: The HORIZON Ultra features a unique cube-like minimalist design that makes it easier to setup on a coffee table or media unit. It also weighs 11.5 pounds and is less than 9 inches tall. The weight and industrial design make it easier to move and we suspect that it will become popular with families who desire a portable projector for the backyard or cottage.
Display Technology: The HORIZON Ultra achieves 4K UHD Resolution resolution via pixel shifting (supported by a .47-inch DLP imaging chip) and a light output rating of 2300 ISO lumens (via 25,000 use hour rated Dual LED/Laser light source). HDR (HDR10, HLG, and Dolby Vision) support and both 2D and 3D viewing options are included (glasses require optional purchase).
XGIMI Horizon Ultra Lens
Tip: The XGIMI HORIZON Ultra is the first long-throw projector that supports Dolby Vision HDR
Portability: The HORIZON Ultra can be moved and placed in any room of the house or used outdoors. Traditional projectors have to be set up again and adjusted at each new location which is time-consuming and inconvenient. However, XGIMI has come up with a creative solution which is discussed in the next section..
ISA 3.0 (Intelligent Screen Adaptation): Builds on their current ISA (Intelligent Screen Adaption) technology, which includes Autofocus, Automatic Vertical Keystone Correction, Obstacle Avoidance, and Intelligent Screen Alignment.
XGIMI includes Dynamic Iris, Dynamic Color, Seamless Auto Keystone Correction, Seamless Auto Focus, Intelligent Eye Protection, and Wall Color Adaption in the 3.0 version.
XGIMI Wall Color Adaption
Wall color adaption means that you can project on a wall (no screen required) and the projector will compensate for the wall color (in most cases).
Tip: Most ISA functions take place without interrupting projection which is great as it doesn’t impair the viewing experience while being noticeably faster and more accurate than previous versions. Intelligent focusing and stabilization occur automatically and are unnoticed by the user.
Screen Size: The HORIZON Ultra can project an image as large as 200 inches. The complete size range is 40 to 200 inches.
XGIMI Horizon Ultra Projector Android 11
Smart Features: The HORIZON ULtra incorporates the Android TV OS (ver 11) and Chromecast Built-in which provides access to abundant streaming content.
For Gamers: The HORIZON Ultra incorporates a gaming mode with low latency (18 ms) and 4K at 60Hz support.
Wired Connections: 2 HDMI (1 with ARC/eARC Support), 2 USB Type A, 1 Digital Optical output, 1 Analog  Audio Output (3.5mm – can be used for headphones)
XGIMI Horizon Ultra 4K Projector Rear Connections
Wireless Connections: Wi-Fi, Ethernet/LAN, Bluetooth 5.2/BLE (allows direct streaming from compatible smartphones and tablets). This allows you to use the HORIZON Ultra as a Bluetooth speaker.
Built-in Speaker System: Harman Kardon 2 × 12 watts per channel. Dolby Audio, Dolby Digital, Dolby Digital Plus, DTS-HD, DTS Studio Sound decoding (mixdown to 2 channels for audio playback)
Control: Bluetooth Remote provided.
Product Size (HWD): 224 × 170 × 265mm (8.8 × 6.7 × 10.4 Inches)
Product Weight: 5.2 kg (11.5 lbs)
Included Accessories
  • Power Cable
  • User Manual
  • Warranty Card
  • Bluetooth Remote Control with AAA Batteries
Price and Availability
The XGIMI HORIZON Ultra is available for $1,699 at Amazon and XGIMI.com.
Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
