Xerox DocuMate 3125 Scanner
Xerox introduced the DocuMate 3125, a compact, color sheet-fed document scanner that quickly converts paper documents, plastic cards and forms into searchable digital files that can be securely saved to a computer or in the cloud. By scanning images directly to the cloud, users can easily collaborate and share files while working in multiple locations.
The Xerox DocuMate 3125 scans up to 25 pages per minute (ppm) and 44 images per minute (ipm) in duplex mode and includes a 50-page automatic document feeder (ADF) that accepts various-sized items from business cards to A4 documents. Double Feed Detection (DFD) technology increases confidence while scanning by notifying the user if more than one page is scanned at a time. DFD prevents unexpected dropped pages due to forgotten staples or adhesives. The Xerox DocuMate 3125 has an exceptionally small footprint of 11.2″ x 6.7″ x 6.5″ with ADF and output paper trays that can be folded closed when not in use. Visioneer OneTouch, a software utility, is included to make scanning from the unit's front panel easy and flexible with the touch of a button.
Visioneer CONNECT is a set of links for Visioneer OneTouch that enables users to scan and automatically upload paper documents to popular cloud destinations with the touch of one button. The following OneTouch cloud links are certified and available for free download: Google Docs, Evernote, FilesAnywhere, OfficeDrop and DropBox.
The DocuMate 3125 includes bundled software that improves information accessibility, management and collaboration. Visioneer Acuity provides advanced image enhancement. Visioneer DriverPLUS enables sophisticated integration with your operating system and applications, with advanced options for consumer and enterprise customers. Certified TWAIN, ISIS and WIA drivers enable communication with hundreds of enterprise content management (ECM) and document image management (DIM) software solutions. Also included are Nuance PaperPort and OmniPage Pro OCR.
Pricing, Availability
The Xerox DocuMate 3125 is available now $495.
Specificationsdatasheet (pdf)
Model Number XDM31255M-WU
Scan Speed 25 ppm / 44 ipm: 200 & 300 dpi b&w, grayscale, color
Scan Method Contact Image Sensor
Optical Resolution 600 dpi
Output Bit Depth 24-bit color, 8-bit grayscale, 1-bit black & white
Interface Hi-speed USB 2.0 (1.1 compatible)
Dimensions (paper trays extended) 11.2″(w) x 10.25″(d) x 10.25″(h) (284 x 261 x 261 mm)
Dimensions (paper trays folded) 11.2″(w) x 6.7″(d) x 6.5″(h) (284 x 170 x 165 mm)
Weight 5.1 lb (2.3 kg)
ADF Minimum Document Size 2″x2.9″(51x74mm)
ADF Maximum Document Size 8.5″ x 38″ (216 x 965 mm)
ADF Capacity 50 pages (20 lb., 75-80 g/m2 paper)
Duty Cycle 3,000 pages/day
See more about: Newest Scanners, Xerox Scanners, Scanner News & Reviews
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
