X-Arm Robotic Mount for Largest Flat Screens from CLO Systems
CLO SYSTEMS AWARD-WINNING ROBOTIC MOUNTING ARM
HANDLES THE ‘HEAVY LIFTING’ AND MOVEMENT
FOR EVEN THE LARGEST FLAT PANELS
Programmable, Remote Controlled Mounting Solution Designed to Manage the
Largest Screens and Recessed Mounting Location Options
West Covina, CA, October 22, 2007 — CLO Systems, an industry leader in advanced mounting solutions for flat panel displays, is shipping its award-winning X-arm robotic mount for elegant and secure movement of today’s largest flat panel displays. CLO’s exclusive X-arm is available now for custom installations that accommodate plasma or LCD flat panel TVs from 40- to 63-inch sizes, and screen weights of up to 180 pounds.
“The X-arm has proven itself to our dealers’ installation designers and technicians to be sturdy and strong enough to provide a reliable mount for these large screens,” said Ken Nguyen, director of sales and marketing at CLO Systems. “It is the only robotic mount that can tilt, swivel and extend the bigger screens without a hint of stress or failure.”
The X-arm is also the choice for installations that require the display to recess into a cabinet or etagere. The arm easily moves the screen in and out of the cabinet and then using the remote control, the robotic arm adjusts the viewing angle of flat panel displays in order to eliminate glare, reflection, and off-axis viewing problems. Cable management provisions include full concealment via a bellows located behind the display. The same bellows also prohibits foreign objects from interfering with the movement of the actuators. A universal mounting attachment kit is provided to facilitate easy coupling with the flat panel.
At the touch of a button on the provided universal remote control or via a RS-232 controlled touch panel, X-arm’s Robotic Display Mounting Solution (RDMS) smoothly extends, even the largest TV, 12 inches allowing the viewer to then adjust the swivel left/right range of motion from 20&#186 to 28&#186 (depending on display size) in either direction, and tilt range up to 20&#186 down and 7&#186 up until the optimum glare-free, on-axis viewing angle is obtained and stored. Four programmable memory locations are provided to recall viewing preferences for day and night, or user one and two.
“X-arm’s sturdy design and mechanisms guarantee that even installations of the largest flat panel displays are secure and flexible,” said Nguyen. “This X-arm solution, in conjunction with its one-touch remote operation capabilities, also allows the end user to have the TV installed exactly where they want it, even inside a cabinet or home theater equipment case for fully recessed and hidden placement opportunities.”
X-arm is available exclusively through CLO System’s strategic partners Chief | Sanus Systems; model # CM7 at www.chiefmfg.com and model# LA112-B1 at www.sanus.com.
About CLO Systems, LLC
California-based CLO Systems, LLC was founded in 2005 to provide advanced robotic and manual mounting solutions for challenging consumer and Pro AV installations. CLO’s team of robotic engineers and designers create and deliver inspired, elegant mounting solutions for today’s demanding flat panel display applications. For more information on CLO Systems, please visit www.closystems.com.
application/mswordUpload
CLO Logo.doc (44.0 k)
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
