Worlds Most Important Software
Next to the operating system, what’s the next most important software you can own? The answer may surprise you.
Make no mistake. The most important piece of software on your computer is the operating system. Without an operating system your computer isn’t going to do much computing. But, assuming you do have an operating system, what should come next? A very strong argument can be made that a defragmentation program (also known as defrag software) is among the most important software you can install, and that no Windows-based system or computer should ever be without it.
There are those that would argue that anti-virus and spyware programs should be next on the list when installing software. However, there is a flaw in this logic. Anti-virus and anti-spyware programs are important, make no mistake about it. But, how are you going to run these important programs if your computer isn’t functioning correctly (or perhaps not functioning at all)?
We’ve all experienced it; we run our favorite anti-virus program and then have to wait forever for it to do its job. An anti-virus scan is not a minor job in most instances, and it is not unusual for this process to literally take hours and hours to perform. There is a reason why scans and similar operations take so long.
There is a hidden danger lurking within every Windows-based PC or server in existence. It’s called fragmentation, and it is a dangerous and unavoidable byproduct of every Windows-based operating system.
Fragmentation is the scattering of data and the wiping out of continuous free space on a hard drive. Every time you use your computer, the information that is written to the hard drive is fragmented or scattered into little pieces. These little pieces multiply and exponentially grow in number – relentlessly choking off the ability of the computer to properly perform.
As a result, when you see a computer or network begin to have problems – slow downs, taking forever, slow downloads, freeze-ups, and crashes just to name a few — it’s very likely to be a result of fragmentation.
This is why defrag software is so incredibly valuable and why no Windows-based computer on should ever be without it. Some of the better defrag programs, like those made by industry leader Diskeeper (www.diskeeper.com) for example, will even make the defragmentation process totally and completely automatic.
Research has shown that when a system is fully defragmented, and then kept that way, all other programs tend to run smoother and faster. As a result, lengthy virus scans tend to happen much, much faster, as well as just about every other operation running on a system.
The best thing to do is to see for yourself. Download and install a defrag program and see why it’s among the most valuable software that you now own.
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
