Wilson Audio Yvette Loudspeaker Introduced
Wilson Audio announced its fifth all-new loudspeaker in as many years called the Yvette, which claims to be the most advanced and musically refined single-enclosure loudspeaker in company’s history. It derives its core technology directly from Wilson’s Sasha Series 2, the Alexia, and the Alexx — in some cases, with identical components.
Enclosure:
Like all recent Wilson loudspeakers, the Yvette is the beneficiary of Wilson’s state-of-the-art composites research, the heart of which is the laser vibrometer. Beyond using the best enclosure materials, the Yvette’s architecture is driven by two factors: time-domain performance, and extremely low-resonance and vibration contribution.
The enclosure is built primarily from two Wilson- developed composites: the third generation of X-Material, an extremely well-damped and inert composite, and S-Material, which was developed for exquisite midrange performance.
Wilson Audio Yvette Loudspeaker Rear
The S-Material midrange baffle is angled to its own plane in order to optimize its time-domain relationship between the woofer below and the tweeter above. Wilson’s engineers designed a new venting system for the midrange enclosure, similar to those found on the XLF, Alexx, Alexia, and Sasha Series 2.
The tweeter baffle is built from X- Material, and, like the mid baffle, is optimized for time-domain performance and dispersion. The X-Material woofer baffle is also positioned optimally in the vertical array. As is true for the Sabrina, Alexx, and the upcoming WAMM, Yvette’s bass baffle angles back slightly toward the midrange for better dispersion accuracy in the upper bass, and more optimized time alignment between the woofer and midrange. The lowest section of the enclosure, below the woofer, changes direction again, and is perpendicular to the ground. This facilitates a smaller footprint when compared to the Sophia.
Bracing in this system is more ambitious and heroic than any previous single-enclosure system—another direct result of laser vibrometer testing. Even the tweeter grille design was scrutinized and meticulously designed, with a frame shape that reduces acoustic interaction.
Wilson’s exclusive resistor tuning system, located in an isolated chamber on the rear of the enclosure, can be accessed through a convenient cover on the rear of the loudspeaker. It features improved hardware and accessibility over that found in the Sophia 3.
The Yvette shape and overall aesthetic may call to mind the Sasha Series 2 and elements of the Sabrina. She is simple and organic, with sculpted lines that remind the viewer of the important function her shape serves.
Wilson Audio Yvette Loudspeaker Drivers
Drivers:
In conjunction with the WAMM project, Wilson Audio recently completed yet another wave of research into tweeter technology and driver materials. Tweeters with domes constructed from beryllium and diamond—the seemingly ubiquitous choice of many loudspeaker engineers—were developed, tested, and rigorously compared to the latest version of Wilson’s Convergent Synergy Tweeter. While many of these designs held promise on paper, they all fell well short of the musicality, natural resolution, and coherence of Wilson’s tweeter.
The Yvette employs the MK III version of the Convergent Synergy Tweeter, which is also found in the Sasha Series 2 and the Alexx. The MK III features Wilson’s latest thinking on rear-wave diffraction and ultra-low resonance rear chambers. It mates seamlessly with Wilson’s proprietary midrange driver, which is the same unit found in the Alexandria XLF.
The ten-inch woofer chosen for the Yvette was (one of two woofers) originally developed for the Alexia, and is a cousin to the ten-inch in the Alexx and the upcoming WAMM. These newest series of bass drivers are partially responsible for Wilson’s unique blend of dynamic contrast, impact, speed, and musicality. When installed in Yvette’s bass enclosure, which was optimized for this driver in terms of volume and resonance control, it pushes the boundary of musical accuracy, extension, and dynamics for such a compact loudspeaker.
Time-Domain Performance:
While not adjustable in the time domain as are Wilson’s larger, modular designs, the Yvette benefits from Wilson’s patented testing protocols, and is uniquely time coherent for a single-enclosure design. Wilson continues to be the only loudspeaker company in the world that fully understands the musically deleterious artifacts caused by time-domain smearing endemic to all multi-driver systems, and has, for decades, continuously and rigorously innovated better and more effective solutions for propagation-delay distortion.
Price and Availability
The Wilson Yvette will begin shipping mid-July 2016 for $25,500 a pair in Wilsongloss Standard Colors. $26,150 in Wilsongloss Upgrade Colors.
Wilson Audio Yvette Loudspeaker in Austin Yellow
Specifications
  • Enclosure Type Woofer: Rear Ported
  • Enclosure Type Midrange: Rear Vented
  • Enclosure Type Tweeter: Sealed
  • Woofers: 10-inches (25.4 cm) Paper Pulp
  • Midrange: 7-inch (17.78 cm) Cellulose/Paper Pulp Composite
  • Tweeter: 1-inch (2.54 cm) Silk Dome
  • Sensitivity: 86dB @ 1 Watt @ 1 meter @ 1kHz
  • Nominal Impedance: 4 ohms / minimum 2.94 ohms @ 90 Hz
  • Minimum Amplifier Power: 50 Watts per channel
  • Frequency Response: 20 Hz – 25 kHz +/- 3 dB Room Average Response [RAR]
  • Overall Dimensions:
    • Height—41 inches (104.14 cm) w/o spikes
    • Width—13 1/4 inches (33.66 cm)
    • Depth—20 1/16 inches (50.92 cm)
  • System Weight Per Channel: 175 lbs (79.38 kg)
  • Total System Shipping Weight (approx.):  515 lbs (233.60 kg)
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Wilson Audio Sabrina V features the same 8-inch woofer as the Sasha V and WATT/Puppy, delivering agile, authoritative, and textured bass for audiophiles seeking...
From $38,500/pair, Wilson Audio remasters its WATT/Puppy loudspeaker for 2024 in celebration of the company's 50 year anniversary.
The Wilson Audio LōKē subwoofer may be small in size, but carries a big price tag. Do you have room under your desk for...
$30,000 for a subwoofer? The Wilson Audio Submerge might play down into the lower depths but can your wallet handle the hit.
Center Speakers
Wilson Audio's Mezzo CSC Center Channel Loudspeaker tips the scale at over 200 pounds and $21,000. Overkill to say the least.
In-Wall Speakers
At 62 lbs per speaker you'll need some serious muscle to get Alida CSC mounted to your wall or ceiling.
Center Speakers
From $9,500, the WASAE center channel speaker should pair nicely with the Wilson Audio's entry-level speakers for home theater.
Hi-Fi Components
The EISA Awards 2023-2024 include 82 winners across 6 categories. We have the full list of winning products.
