Center Speakers
Wilson Audio Introduces its Most Affordable Center Channel Speaker
From $9,500, the WASAE center channel speaker should pair nicely with the Wilson Audio’s entry-level speakers for home theater.
Wilson Audio WASAE Center Channel Speaker Front No Grille in Crimson
Wilson Audio has gone through a rather interesting transition since the passing of its founder, David Wilson. The Utah-based loudspeaker maker has always been a family business and it seemed almost impossible to fill the the void after his passing; Wilson was one of the most successful brands in the entire industry for almost 3 decades and its charismatic owner was a huge part of that success. To their credit, the family has carried on his legacy with a new generation of products that offer superior engineering and build quality. The new Wilson WASAE Center Channel Loudspeaker adds a new “affordable” option to their home theater lineup.
Wilson Audio WASAE Center Channel Speaker with Grilles in Ivory with Grey Grilles
Wilson Audio WASAE Center Channel Speaker with grilles in Ivory
The WASAE Center Channel
The latest entry into the Wilson lineup is the Wilson Audio Special Applications Engineering (WASAE) Center Channel Speaker.
The WASAE cabinet incorporates advanced X-Material (used for cabinet bracing) and S-Material (a blend of materials that form a stable and low-resonance coupling surface for the midrange driver) for precise vibration control.
Featuring the same Convergent Synergy MK5 tweeter found in the WAMM Master Chronosonic, the WASAE Center is designed to deliver linear high-frequency extension and harmonic nuance found in its larger siblings. The mid-woofer utilized is the same as in the Alexx V, SabrinaX, and the wall-mounted Alida.
Wilson Audio WASAE Center Channel Speaker without Grilles in Grigio
WASAE Center’s crossover components, include Wilson’s new AudioCapX-WA capacitors. The capacitors are wound at Wilson Audio to extremely tight tolerances specifically for this product, thus increasing low-level resolution.
To support a cleaner signal path, the WASAE Center is equipped with Wilson Audio spade + banana plug binding posts
Wilson Audio WASAE Center Channel Speaker rear angle in Grigio
Specifications
  • Enclosure Type: X-Material / S-Material / Rear Vented (Bass Reflex)
  • Mid-Woofers: 2 x 5.75 inches (14.61 cm)
  • Tweeter: 1 inch (2.54 cm)
  • Sensitivity: 88 dB @ 1 Watt @ 1 meter @ 1 kHz
  • Impedance: 4 ohms/minimum 3.9 ohms @ 198 Hz
  • Minimum Amplifier Power: 20 Watts
  • Frequency Response: 65 Hz – 31 kHz (+/- 3 dB)
  • Height: 7 3/4 inches (19.62 cm) w/o spikes
  • Width: 26 3/4 inches (67.95 cm)
  • Depth: 13 3/16 inches (33.46 cm)
  • Weight: 57 lbs (25.85 kg)
  • Total System Shipping Weight (approx.): 100 lbs (45.36 kg)
Wilson Audio WASAE Center Channel Speaker front angle in Grigio
Wilson Audio WASAE Center Channel Speaker rear in Grigio
In the Box
  • WASAE Center Manual
  • Warranty Registration Form
  • (1x) Polishing Cloth
  • (2x) 3/8-inch 16 Stainless Adjustable Spike with Nut
  • (2x) “AA” Stainless Spike
  • (4x) Small Aluminum Spike Pad
  • (1) 1/2-inch Nut Driver (binding posts)
  • (1) 7/16-inch Combo Wrench (“AA” spike)
  • (1) 9/16-inch Wrench (adjustable spike nut)
  • (1) 1/4-inch Flat Wrench for Adjustable Spike tip (spike install/removal)
  • (1) 3/16-inch Allen Wrench (spike set screws)
  • Universal Allen Driver
  • (1) 1/8-inch Allen Bit (resistor panel screw)
  • (1) 5/32-inch Allen Bit (driver screws)
  • Full-Line Brochure
  • Wilson Audiophile Recordings leaflet
Wilson Audio WASAE Center Channel Speaker Front Angle with Black Grilles in Crimson
Finish Options
The WASAE Center Channel Speaker is being offered with an abundance of cabinet and grill colors in standard (5 colors), upgrade (14 colors), and premium (10 colors) options (upgrade and premium color options require an extra fee). A custom finish option is also available.
Tip: The standard color offerings are Galaxy Gray, GT Silver, Quartz, Carbon, and Medio Grigio
Pricing and Availability
Pricing for the Wilson Audio WASAE is based on the finish option chosen:
  • Standard Finish: $9,500
  • Upgrade Finish: $10,000
  • Custom Finish: $11,000
  • Premium Finish: $11,500
The Wilson Audio WASAE is available through Authorized Dealers and Distributors
Wilson Audio Mezzo CS Center Channel Speaker
BONUS: If you want a more substantial higher-end center channel speaker to complement a Wilson Audio setup, you might consider the Wilson Audio MEZZO CS (Convergent Synergy) price from $17,600 to $20,600 depending on the finish.
Comparison
Here is a basic specifications comparison of WASAE and MEZZO CS.
WASAEMEZZO CS
Standard Finish$9,500$17,600
Upgrade Finish$10,000$18,100
Custom Finish$11,000$19,800
Premium Finish$11,500$20,600
Woofers2 x 8 inches (20.32 cm)
Midrange or Mid-Woofers2 x 5.75 inches (14.61 cm)1 x 7 inches (17.78 cm) Cellulose/Paper Pulp
Tweeter1 inch (2.54 cm)1 inch (2.54 cm) silk dome
Sensitivity88 dB @ 1 Watt @ 1 meter @ 1 kHz96 dB @ 1 watt @ 1 m @ 1 kHz
Impedance4 ohms/minimum 3.9 ohms @ 198 Hz4 ohms, minimum 2.8 ohms @ 98 Hz
Minimum Suggest Amp Power20 Watts25 watts
Frequency Response65 Hz – 31 kHz (+/- 3 dB)20 Hz – 22.5 kHz +/- 3 dB Room Average Response [RAR]
Height 7 3/4 inches (19.62 cm) w/o spikes17 3/8 inches (44.13 cm)
Width 26 3/4 inches (67.95 cm)29 ½ inches (74.93 cm)
Depth13 3/16 inches (33.46 cm)20 7/8 inches (53.06 cm)
Weight 57 lbs (25.85 kg)159 lbs (71.21 kg)
Total System Shipping Weight (approx.)100 lbs (45.36 kg)250 lbs (113.40 kg)
Here are other Wilson Audio Loudspeakers in their current lineup that we have covered:
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
