Wilson Audio dropped the Sabrina X back in 2020, and like most things bearing the Wilson name, it didn’t exactly come cheap. But it earned its place, staying in the lineup for five solid years—no small feat in a market that chews up and spits out “flagship killers” every six months. Still, even speakers that cost as much as a decent used car eventually get the refresh treatment. Enter the new Sabrina V for 2025, stepping in to replace the X with refinements that Wilson claims push performance even further… just don’t expect the price of admission to get any more forgiving.
Wilson Audio claims the new Sabrina V is engineered to defy expectations, offering sonic performance and musical realism well beyond what its modest 39 x 12 x 25 3/8-inch footprint might suggest. Let’s pull back the velvet curtain and see what makes this latest floorstander tick.
H-Material
The Sabrina V swaps out the SabrinaX’s front baffle X-Material for Wilson’s new H-Material—a high-density composite that blends organic and phenolic elements. It’s a little softer than X-Material, which Wilson says allows for more midrange musicality. In plain terms: it’s engineered to sound a bit warmer and more natural, without giving up the structural integrity needed for accurate playback. Think of it as X-Material’s more laid-back cousin—still tough, just less uptight.
Connection Panel Access
The Sabrina V relocates its resistor access to the rear panel, ditching the bottom-mounted setup used in the Sabrina X. This makes servicing and fine-tuning much less of a contortionist act. Wilson now uses premium tool-less thumbscrews to secure the resistors, making midrange and tweeter swaps quicker and more convenient—no hex wrenches or yoga poses required.
Acoustic Diode Design
Wilson Audio carries over its Acoustic Diode isolation tech to the Sabrina V but ups the ante by incorporating V-Material into the bottom of the enclosure. The result? Better vibration control and lower mechanical noise. This means a blacker background and cleaner, more defined sound—because the last thing you want interfering with your music is your speaker wobbling like it’s had too much espresso.
Woofer Capacitor Upgrade
Wilson Audio equips the Sabrina V with a newly designed woofer capacitor built using the same proprietary tech as its revered midrange capacitors from Reliable Capacitors (yes, that’s Wilson’s own division). The goal? Seamless integration between bass and midrange frequencies. The result? A low end that doesn’t just thump—it sings, blends, and breathes in lockstep with the rest of the sonic picture. It’s not just low-frequency support—it’s bass with brains.
Convergent Synergy Carbon Tweeter
Trickled down from the flagship Alexx V, the Convergent Synergy Carbon (CSC) tweeter makes its way into the Sabrina V. This isn’t your average high-frequency driver—it’s a lightly coated textile dome that delivers airy, extended highs with precision and finesse. More importantly, it integrates effortlessly with the AlNiCo midrange and 8-inch woofer, creating a cohesive, natural soundstage. Expect crystalline treble, refined harmonic nuance, and a sense of space so convincing you might start checking for hidden microphones in your listening room.
Midrange
Wilson Audio has dropped its trusty 7-inch AlNiCo (Aluminum-Nickel-Cobalt) QuadraMag midrange driver into the Sabrina V. This isn’t just any driver—it first debuted in the Chronosonic XVX and has since made cameos in the Alexx V, Alexia V, Sasha V, and The WATT/Puppy. The AlNiCo QuadraMag is famed for its smooth, stable linearity, which means you get more depth, dimensionality, and that elusive “real” sound that separates the serious from the casual audiophile crowd.
Woofer
The Sabrina V rocks the same 8-inch woofer found in the Sasha V and The WATT/Puppy. This woofer doesn’t just grunt; it anchors the low end with a mix of agility and authority, delivering bass that’s not only deep but articulate and textured—because nobody wants sloppy boom when they’re paying top dollar.
Crossover Components
The crossover components for the Sabrina V incorporate Reliable Capacitors’ AudioCapX-WA capacitors. The capacitors are wound at Wilson Audio to extremely tight tolerances specifically for this product, thus increasing low-level resolution.
Comparison
Sabrina V (2025) | Sabrina X (2020) | |
Product Type | Floorstanding Speaker | Floorstanding Speaker |
Price (pair) | $28,000 (some color options may have an extra charge) | $18,900 (standard colors) $19,600 (upgrade colors) |
Enclosure Type | Tweeter: (Sealed): X-Material / H-Material baffle Midrange: (Rear vented): X-Material / H-Material baffle Woofer: (Rear ported): X-Material / H-Material baffle Damping Inserts: V-Material (spike/footer interface) | Tweeter: (Sealed): X-Material baffle Midrange (Rear Vented) X-Material Baffle Woofer: (Rear Ported) X-Material Baffle |
Woofer | 8 inches (20.32 cm) Paper Pulp | 8 inches (20.32 cm) Paper Pulp |
Midrange | 7 inches (17.78 cm) Paper Pulp Composite | 5 3/4 inches (14.61 cm) Doped Paper Pulp |
Tweeter | 1 inch, Dome (2.54 cm) Doped Silk Fabric | 1 inch Dome (2.54 cm) Doped Silk Fabric |
Sensitivity (1W @ 1m @ 1kHz) | 87 dB | 87 dB |
Impedance | 4 ohms / minimum 2.23 ohms @ 121 Hz | 4 ohms / 2.60 ohms minimum @ 135Hz |
Minimum Amplifier Power | 50 Watts per channel | 50 Watts per channel |
Frequency Response (+/- 3 dB: Room Average Response [RAR] ) | 27 Hz – 24 kHz | 31Hz – 23kHz |
Height | 38 31/32 inches (98.98 cm) w/o spikes [Variable] | 38 inches (96.46 cm) – with spikes: 40 5/16 inches (102.34 cm) |
Width | 12 inches (30.48 cm) | 12 inches (30.48 cm) |
Depth | 15 3/8 inches (39.07 cm) | 15 5/16 inches (38.96 cm) |
Weight | 123 lb (55.79 kg) | 112 lb (50.80 kg) |
Total Shipping Weight (per speaker) | 140 lb (63.50 kg) | Not Indicated |
Total Shipping Weight (system boxes + pallet): | 310 lbs (140.61 kg) | 290 lbs (131.54 kg) |
The Bottom Line
The Wilson Audio Sabrina X was already a pretty impressive floorstander, but after five years, even a classic needs a facelift — enter the Sabrina V. It builds on the solid foundation of the Sabrina X while sneakily borrowing tech and tweaks from Wilson’s pricier siblings. The end result? A high-end cocktail of design, tech, and performance that’ll have audiophiles drooling over their two-channel setups.
Of course, the catch here is the price: the Sabrina V arrives with a cool $10,000 premium over the Sabrina X. Because why settle for a great speaker when you can pay for bragging rights, right? That said, Wilson might keep the Sabrina X around a bit longer for those of us whose budgets don’t include the phrase “jumbo mortgage.”
Wilson’s given us the teaser info, but the full story—along with whatever sonic sorcery they’ve saved up—won’t be revealed until June 20, 2025. What other secrets does the Sabrina V have hidden in its luxurious cabinet? Stay tuned… and maybe start saving.
Price & Availability
The Wilson Audio Sabrina V will be available in Galaxy Grey, GT Silver, Quartz, Carbon, and Saffron Pearl, beginning on July 3, 2025, from Authorized Dealers with a price of $28,000 per pair..
As mentioned at the top of this article, the Sabrina V is replacing the Sabrina X, which will be available in Galaxy Gray, Carbon, and Quartz. while supplies last for $18,500 per pair or $19,500 in Diamond Black, Crimson Satin, or Ivory.
Related Reading
