Center Speakers
Wilson Audio’s Mezzo CSC Center Channel Speaker is One Beast of a Loudspeaker
Wilson Audio’s Mezzo CSC Center Channel Loudspeaker tips the scale at over 200 pounds and $21,000. Overkill to say the least.
Wilson Audio MEZZO CSC Center Channel Speaker Front View Grill Off
Following the recent release of its WASAE center channel speaker and Alida CSC Wall Mount Speakers, Wilson Audio is adding a new flagship center channel speaker, the Mezzo CSC.
This speaker is a step up from the WASAE and replaces its previous flagship center channel speaker, the Mezzo CS.
A quick look at the specifications reveals that the Mezzo CSC will require two or three adults to properly install this monstrosity of a center channel speaker and a dedicated stand that can handle at least 250 pounds.
Wilson Audio MEZZO CSC Center Channel Speaker with black grilles in ivory
Wilson Audio MEZZO CSC on stand in ivory with black grilles.
Tech Note: CSC stands for Convergent Synergy Carbon (more on that later).
The Mezzo CSC Center Channel Speaker
Here is a look at what the MEZZO CSC offers for home theater applications.
Construction Materials: The Mezzo CSC cabinet incorporates advanced X-Material (used for cabinet bracing) and S-Material (a blend of materials that form a stable and low-resonance coupling surface for the midrange driver) for precise vibration control.
Adjustable CSC Tweeter: The CSC tweeter is placed in a fully adjustable module. This allows users to customize the center channel alignment to any installation environment. Whether the Mezzo CSC is placed on the floor, on a stand, or in a cabinet, the Mezzo CSC’s drivers can be aligned to accommodate.
The adjustable tweeter module enhances the listening experience by matching the CSC tweeter with the midrange and woofers for tighter time-alignment accuracy, regardless of the listening position.
Wilson Audio MEZZO CSC Center Channel Speaker Tweeter Adjustment
Tech Note: Wilson’s Convergent Synergy Carbon (CSC) Tweeter was designed initially for the Alexx V and subsequently incorporated into the design of Alexia V and Sasha V. The CSC tweeter components are 3D printed by Wilson Audio.
Crossover Components: The Mezzo CSC’s crossover components, include Wilson’s AudioCapX-WA capacitors. The capacitors are wound at Wilson Audio to extremely tight tolerances specifically for this product, thus increasing low-level resolution.
Main Module: Mezzo CSC’s main module includes two horizontal woofers, each located on either side of the midrange driver. First introduced in the Chronosonic XVX, Mezzo CSC features the same 7” Alnico (Aluminum-Nickel-Cobalt) QuadraMag midrange coupled with an S-Material baffle.
Wilson Audio MEZZO CSC Center Channel Speaker Rear Binding Posts
Connections: To support a cleaner signal path, the Mezzo CSC Center is equipped with Wilson Audio spade + banana plug binding posts.
Specifications
  • Enclosure Type: Woofer: Front Ported (Bass Reflex), Midrange: Sealed, Tweeter: Sealed
  • Woofers: 2 x 8 inches (20.32 cm) Paper Pulp
  • Midrange: 1 x 7 inches (17.78 cm) Paper Pulp Composite
  • Tweeter: 1 x 1 inch (2.54 cm) Doped Silk Fabric
  • Sensitivity: 89 dB @ 1 Watt @ 1 meter @ 1 kHz
  • Impedance: 4 ohms / minimum 2.66 ohms @ 687 Hz
  • Minimum Amplifier Power: 25 Watts per channel
  • Frequency Response: 19 Hz – 32 kHz +/- 3 dB Room Average Response [RAR]
  • Height: 18 inches (45.70 cm) w/o spikes
  • Width: 31 inches (78.74 cm)
  • Depth: 22 7/32 inches (56.47 cm)
  • Weight: 200 lb (90.72 kg)
  • Total System Shipping Weight (approx.): 288 lb (130.63 kg)
In the Box
  • Replacement Resistors
  • Books and Literature
  • Custom Loudspeaker Covers
  • Installation Tools and Accessories
  • New Grilles and Diffraction Blankets
  • WilsonGloss Care Products and Kits
  • Wilson Audio Signature Apparel
  • Upgrade Spikes and Binding Posts
Red Wilson Audio MEZZO CSC Center Channel Speaker Rear View
Finish Options
The Mezzo CSC Center Channel Speaker is being offered with an abundance of cabinet and grill colors in standard (5 colors), upgrade (14 colors), and premium pearl (10 colors) options (upgrade and premium pearl color options require an extra fee). A custom finish option is also available.
Tip: The standard color offerings are Galaxy Gray, GT Silver, Quartz, Carbon, and Medio Grigio
Pricing and Availability
Pricing for the Wilson Audio Mezzo CSC is based on the finish option chosen:
  • Standard Finish: $21,250
  • Upgrade Finish: $21,750
  • Custom Finish: $23,250
  • Premium Pearl Finish: $24,250
The Wilson Audio Mezzo CSC is available through Authorized Dealers and Distributors. Shipping starts on December 22, 2023.
Wilson Audio MEZZO CSC and WASAE Center Speakers
Wilson Audio MEZZO CSC and WASAE Center Channel Speakers
Comparison
Here is a basic specifications comparison of WASAE, Mezzo CS, and Mezzo CSC Center Channel Speakers from Wilson Audio.
WASAEMEZZO CSMEZZO CSC
Standard Finish$9,500$17,600$21,250
Upgrade Finish$10,000$18,100$21,750
Custom Finish$11,000$19,800$23,250
Premium Pearl Finish$11,500$20,600$24,250
Woofers2 x 8 inches
(20.32 cm)
2 x 8 inches
Midrange  or Mid-Woofers2 x 5.75 inches (14.61 cm)1 x 7 inches
(17.78 cm)
Cellulose/Paper Pulp
1 x 7 inches
(17.78 cm)
Tweeter1 inch
(2.54 cm)
1 inch
(2.54 cm) silk dome
1 x 1 inch
Sensitivity
(@ 1 Watt @ 1 meter @ 1 kHz)
88 dB96 dB89 dB
Impedance4 ohms
minimum 3.9 ohms @ 198 Hz
4 ohms
minimum 2.8 ohms @ 98 Hz
4 ohms
Minimum Suggest Amp Power20 Watts25 watts25 Watts
Frequency Response65 Hz – 31 kHz (+/- 3 dB)20 Hz – 22.5 kHz +/- 3 dB Room Average Response [RAR]19 Hz – 32 kHz +/- 3 dB Room Average Response [RAR]
Height 7 3/4 inches (19.62 cm) w/o spikes17 3/8 inches
(44.13 cm)
18 inches
Width 26 3/4 inches
(67.95 cm)
29 ½ inches
(74.93 cm)
31 inches
(78.74 cm)
Depth13 3/16 inches
(33.46 cm)
20 7/8 inches
(53.06 cm)
22 7/32 inches
(56.47 cm)
Weight 57 lbs
(25.85 kg)
159 lbs.
(71.21 kg)
200 lbs
(90.72 kg)
Shipping Weight
(approx.)
100 lbs
(45.36 kg)
250 lbs
(113.40 kg)
288 lbs
(130.63 kg)
Here are other Wilson Audio Loudspeakers in their current lineup that we have covered:
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
Polk Audio have been quite aggressive with their Reserve and Legend Series speakers, and news has dropped on a brand new lineup called the...
Wilson Audio Sabrina V features the same 8-inch woofer as the Sasha V and WATT/Puppy, delivering agile, authoritative, and textured bass for audiophiles seeking...
Discover the Starke Sound HALO Series, featuring the M1 bookshelf speakers, C2 center channel, W1 on-wall speakers, SUB1 and SUB5 subwoofers, and A2 and...
Priced from $2,250 to $7,000 per pair, Monitor Audio's Gold Series 6G loudspeakers include six models for stereo or home theater setups.
From $300 to $1,000 a pair, ELAC's Debut 3.0 series loudspeakers provide an affordable hi-fi and home theater solution with 7 new models.
Priced from $399 to $1,199 a pair, the Q Acoustics 3000c loudspeaker series includes five new models along with new finishes.
From $38,500/pair, Wilson Audio remasters its WATT/Puppy loudspeaker for 2024 in celebration of the company's 50 year anniversary.
