Digital Music Systems
WiiM’s Ultra Delivers Hi-Res Streaming and More For Under $330: HIGH END Munich 2024
At $329, WiiM Ultra is the company’s top-of-the-line digital music streamer which adds a touchscreen, HDMI ARC and a subwoofer out.
WiiM Ultra Network Streamer Front
WiiM Ultra
Is WiiM becoming the next Schiit Audio or FiiO? We think that would be a fantastic development for the high-end audio world at a time when manufacturers seem overly focused on ultra high-end products with zero appeal to the vast majority of music listeners under the age of forty. Reality is products like the new WiiM Ultra Streamer that will retail for only $329 USD.
We have already posted a preview of the Ultra, but more details have been revealed at High-End Munich 2024.
The WiiM Ultra is the successor to the popular and very capable WiiM Pro Plus introduced in August 2023.
As we mentioned in our previous preview article, the WiiM Ultra is designed to function as a central hub for your audio system with components normally found in more expensive units, along with solid build quality, flexible connectivity, and a front panel 3.5” full-color touchscreen.
Hi-Res streaming capability, advanced room correction, and smart home integration is provided.
Also, just as with the previous WiiM Streamers, the Ultra works with the WiiM Home App.
WiiM Home App
Upgrades in WiiM Ultra
Wireless Connectivity: Wi-Fi 6E and Bluetooth 5.3 with two antennas offering rock-solid Bluetooth or Wi-Fi audio streaming
Wired Connectivity: The Ultra includes a comprehensive selection of physical audio inputs and outputs, including HDMI ARC, Line-In, Phono-in (MM), and Optical Inputs, along with Line-Out, Optical, Coaxial, USB, Subwoofer, and dedicated Headphone output port (3.5mm)
DAC: A Premium 32-bit/384kHz ES9038 Q2M SABRE DAC provides the best possible reproduction of digital audio sources for headphone listening, powered speakers, and external audio systems.
Case: Compact, well-built, aluminum case.
WiiM Ultra Digital Music Streamer Angle
Front Panel Display: 3.5-inch touchscreen display covered with glass that can show:
  •  App widgets, large album pictures, playback control, playing queue, presets, EQ, audio input and output, and device settings.
  • Provide feedback when there’s a change in the play mode.
  • Allow users to customize the wallpaper and display the time and date during standby mode.
Room Correction: Built-in room correction technology actively takes precise acoustic measurements of your room, crafting customized corrections for your speaker and subwoofer.
Hi-Res Audio Streaming: Stream Hi-Res music with the bit-perfect digital output or high-fidelity analog audio (SNR>120dB, THD+N<0.0002%)
WiiM Ultra Digital Music Streamer Rear Inputs
WiiM Ultra (rear)
WiiM Streamer Comparison Chart
Note: This Chart does not include a WiiM Amp/WiiM Amp Pro comparison as they are included in our companion article on the WiiM Amp Pro.
WiiM MiniWiiM ProWiiM Pro PlusWiiM Ultra
MSRP$99$149$219$329
Ethernet YesYesYes
WiFi5556E
Bluetooth5.05.05.05.3
Chromecast AudioYesYesYes
Group with Nest Speakers and DisplayNoYesYesYes
Group with Echo Speakers and DisplayYesYesYesYes
Alexa Multiroom with UHDYesYesYes
Group with HomepodsYesYesYesYes
Works with AlexaYesYesYesYes
Works with GoogleYesYesYes
Works with SiriYesYesYesYes
Group with WiiM or Linkplay DevicesYesYesYesYes
Airplay 2YesYesYesYes
DLNAYesYesYesYes
Spotify ConnectYesYesYesYes
TIDAL ConnectYesYesYesYes
Gapless PlaybackYesYesYesYes
PEQ (Parametric EQ)YesYesYes (after firmware update)Yes
10 Band Graphic EQYesYesYesYes
Linkplay Music Streaming PlatformYesYesYesYes
Roon ReadyYesYes (after firmware update)Yes
CPUDual Core A7Dual Core A53Quad Core Amlogic A113XQuadcore A53
DRAM128 MB512 MB512 MB512 MB
Flash128 MB512 MB512 MB512 MB
Audio Input (wired)AuxLine-in, OpticalLine-in, OpticalLine-in, Optical, HDMI-ARC, Phono (MM), USB
Audio Output (wired)Aux, OpticalLine-out, Optical, CoaxLine-out, Optical, CoaxLine-out, Optical, Coax, Subwoofer, Headphone
DACTI PCM 5121TI PCM 5121AKM AK4493SEQESS ES9038Q2M
Built-in Amplifier
Subwoofer OutputYes
Front Panel Display Yes – Full Color/Touchscreen
Price & Availability
The WiiM Ultra will be available for $329 on Amazon in Q3.
For more information: wiimhome.com
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
