Digital Music Systems
WiiM for Custom Installations? Check out the CI MOD S Streamer and A80 Streaming Amplifier
Whole-home budget priced music streaming solutions are coming from WiiM this fall. Should Sonos be worried?
WiiM CI MOD A80 and MOD S Music Streamers
WiiM Audio, makers of popular affordable media streamers and streaming amps established a partnership in 2023 with Origin Acoustics to develop products using its technologies for distribution in the CI (Custom Installation) space.
As a result of this collaboration, WiiM has announced two products, the CI MOD S streamer and the CI MOD A80 streaming amplifier. The devices are designed to provide streaming options for custom-install audio and home theater setups.
Building on a year of successful partnership, WiiM continues to set the standard for innovation in the CI market. The new MOD S and MOD A80 embody WiiM’s quality, ease of use, and seamless compatibility with various control platforms.
WiiM CI MOD S
WiiM CI MOD S Music Streamer
WiiM CI MOD S Streamer
The WiiM CI MOD S is an audiophile-grade streamer that provides access to abundant streaming services via the WiiM Home App, incorporates an AKM AK4493SEQ DAC, supports Hi-res audio up to 24-bit/192kHz, and versatile connectivity and control options for various installation needs. The CI MOD S needs to be connected to an amplifier (or powered speakers) in order to hear the sources you are accessing.
WiiM CI MOD A80
WiiM CI MOD A80 Network Amplifier
WiiM CI MOD A80 Streaming Amplifier
The WiiM CI MOD A80 combines the streaming capabilities of the MOD S with an ESS 9018K2M DAC and TI TPA3255 Class-D two-channel amplifier that delivers 60W per channel at 8 ohms. In other words, just add speakers and you are set to go.
Pro Tip: WiiM Bass Management and Room Correction are included in both devices, as well as both WiFi and Ethernet connectivity.
Comparison
WiiM CI MOD S vs. A80 rear inputs
CI MOD SCI MOD A80
Product TypeStreamer (no Amplifier)Streaming Amplifier
Power InputUSB Type-C, requires 5V, 1.5A or higher100-240V AC
Bundled adapter5V, 2AN/A
Digital Audio OutputUp to 192 kHz, 24-bit with digital optical or coaxial outputN/A
Network802.11 b/g/n/ac 2.4 GHz and 5 GHz dual band Wi-Fi
10/100M Ethernet
Wi-Fi 6E, 802.11 b/g/n/ax 2.4 GHz, 5 GHz, and 6 GHz triple bands
BluetoothBluetooth 5.1Bluetooth 5.3 with BLE and BT supports both A2DP receiver and transmitter, AVRCP, HID, works with the WiiM Voice Remote
Audio Input1 x Analogue RCA Line input,
1 x SPDIF in Optical, up to 192kHz/24-bit
Analogue (RCA),
Digital Optical Port,
HDMI ARC, up to 24-bit/192 kHz
Audio Output1 x Analogue RCA Line output,
1 x Digital optical (SPDIF) output,
1 x Digital Coaxial output, up to 192kHz/32-bit
Banana (x2), Subwoofer out
USB AudioSupports two-channel USB audio output
USB HostConnects to USB disk for local music playback
AmplifierTI TPA 3255 Class-D digital amplifier
Power Output60 W/channel (8 ohms), 120 W/channel (4 ohms)
DACAKM AK4493SEQESS Sabre 9018K2M
Trigger Out3.5mm Trigger outN/A
SNR120 dB108 dB
THD+N0.00032% (-110 dB)– 95 dB, 5W @ 8 Ohms
Audio CodecMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGGMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Equalizer24 preset EQ settings for different music genres
10-band graphic EQ (Line-in, BT, or Network)
10-band parametric R/L EQ that can adjust based on room characteristics
Bass management
Built-In Room Correction
24 preset EQ settings for different music genres.
10-band graphic EQ (Line-in, BT, or Network).
Bass management
Streaming PlatformsChromecast Audio, DLNA, Spotify Connect, TIDAL Connect, Amazon Music Casting, Qplay 2.0, RoonChromecast Audio, DLNA, Spotify Connect, TIDAL Connect, Amazon Music Casting, Qplay 2.0, Roon
Streaming Services (via WiiM Home App)Spotify, Amazon Music, Deezer, TuneIn, Tidal, Qobuz, SoundCloud, Pandora, iHeartRadio, vTuner, Napster, SoundMachine, BBC Radio, Calm Radio, Radio Paradise, Sound Track Your BrandSpotify, Amazon Music, Deezer, TuneIn, Tidal, Qobuz, SoundCloud, Pandora, iHeartRadio, vTuner, Napster, SoundMachine, BBC Radio, Calm Radio, Radio Paradise, Sound Track Your Brand
Supported Control PlatformsControl 4, RTI, URC, Josh.aiControl 4, RTI, URC, Josh.ai
Touch ButtonsPlay/Pause/Setup, Volume +, Volume -, PresetN/A
Dimensions (LWH)5.5 x 5.5 x 1.6 Inches
(140 x 140 x 42 mm)
7.48 x 7.48 x  2.52 inches
(190 x 190 x 64 mm)
Weight11.6 oz (330g)68.26 oz (1.935 kg)
Included AccessoriesOptical cable (1)
Stereo RCA cable (1)
HDMI cable (1)
Power cable (1)
Screws (7)
Mounting brackets (2)
Optical cable (1)
USB Type C cable (1)
Adapter (1)
Screws (3)
WiiM Pro Plus Network Streamer App
WiiM App
The Bottom Line
Custom install components tend to be priced high (higher than they probably need to be – but installers need to make a profit). And while WiiM hasn’t announced exact pricing on these CI products yet, our conversations with WiiM reps at CEDIA Expo suggest only a slight premium for the CI market. For example, we expect the Mod S streamer will sell for around $350. As a result of this pricing, some dealers and installers feel that the WiiM products are actually too inexpensive in relation to the premium brands they normally deal with such as Bluesound and Sonos, which generally cost more.
However, the point can be made that most customers have a budget in mind for a project. And if you have, say, $20,000 for a 3-room music system, customers will only need to invest around $1,000 for 3 WiiM streamers, and that leaves $19K for the speakers, amps, cables, installation, etc. This may be a better investment for the customer than having to allocate $3K to $4K just for Sonos zones, leaving less budget left for the rest of the system.
Price & Availability
The first batch of these products is scheduled to ship by October 2024. They will be available through authorized CI distributors and dealers. Contact your local dealer or custom installer for availability and pricing for your specific project needs.
Related Reading
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
HDTV 4K & 8K TV
