Digital Music Systems
WiiM’s New Streaming Amplifier Delivers A lot for $299
$299 for a network streaming amplifier? The new WiiM Amp offers support for TIDAL and Spotify Connect, HDMI ARC, and support for Alexa, Siri, and Google Assistant.
WiiM Amp
We love the new WiiM Amp for a myriad or reasons, and will have much more to say when we review it in a few weeks. If only this product had been used in multiple rooms at CAF 2023, offering a much more affordable system option for music listeners looking to build their first high-end system.
Spare us with “It’s only $299…how can it be a high-end audio component?”
95% of audiophiles can’t afford any of the $100K systems at the show and we’re pretty sure that most people are not spending $50,000 or even $30,000 on new systems right now either. People are looking at ways of simplifying what they already own or building less expensive secondary systems.
Products like the WiiM Amp make a lot of sense.
The WiiM Amp is a network streamer that also includes an internal power amplifier, along with a lot of other features.
From Dr. Lifeng Zhao, CEO of WiiM: “We’ve dedicated ourselves to designing products that elevate the music streaming experience, and the WiiM Amp is the first step in our expanded lineup,…With valuable user feedback and our team’s commitment to superior audio quality, the WiiM Amp delivers audiophile-grade sound and a seamless experience for music enthusiasts to unlock a world of musical possibilities.
WiiM Amp Streaming Amplifier
WiiM Amp Features
Built-in Amplifier: The TI 3255 Class-D amplifier chip can output 60 Watts per channel (8 ohms) or 120 Watts per channel (4 ohms).
Tech Note #1: Unlike its streaming players, the WiiM Amp does not have analog or digital outputs to connect to a powered speaker, soundbar, or AV receiver. Only speaker connections are provided.
Tech Note #2: The WiiM Amp doesn’t provide a dedicated physical headphone output. However, it can pair with Bluetooth headphones.
WiiM Amp Rear
Audio Inputs: Physical audio inputs include analog (RCA), digital Optical ports, and HDMI ARC. Up to 192 kHz/ 24-bit, varying sample rate and bit depth based on the audio source without resampling.
Compatible Audio Formats: MP3, AAC, ALAC, APE, FLAC, AIFF, WAV, WMA, OGG, PCM. Dolby and DTS formats are not supported.
DAC: The WiiM Amp incorporates the ESS Sabre ES9018
Subwoofer Out: When connected to an external powered subwoofer, automatic bass management is engaged if needed.
USB Host for Storage: Access personal media libraries for playback or use it as a media server for other WiiM devices.
EQ Settings: Preset, 10-band Graphics EQ, 4-band parametric EQ
Wireless Connectivity: Wi-Fi 5, 802.11 b/g/n/ac 2.4 GHz and 5 GHz dual-band (A Wired Ethernet connection option is also included).
Bluetooth 5.0 with BLE: Support is provided for A2DP reception and transmission, AVRCP, and HID, and works with the WiiM Voice Remote
Voice Control: The WiiM Amp has Alexa built-in but also works with Siri and Google Assistant. This allows easy control of music selection, volume adjustments, and playback.
Streaming Platform and Services Support: The WiiM Amp supports AirPlay 2, Alexa Casting, Spotify Connect, TIDAL Connect, Qobuz, Amazon Music, TIDAL, Deezer, TuneIn, iHeartRadio, and more. It also features Chromecast Audio, which lets you cast YouTube Music, TV audio, radio stations, podcasts, and local content directly from Chromecast-enabled Apps.
Multiroom Audio: You can use the WiiM Amp with AirPlay 2 speakers, Amazon Echo, Google Home, and other WiiM-branded devices for a multiroom audio experience.
Tip: Roon Ready Certification is forthcoming via firmware update.
The WiiM Home App: The WiiM Amp will pop up automatically in the WiiM Home app. With the simple in-app guide and compact size, the device can be set up in less than two minutes.
WiiM Home App
What’s Included
  • WiiM Amp
  • Bluetooth voice remote
  • Quick start guide
  • 100~240v AC power cable
  • HDMI cable
  • RCA audio cable
  • Optical audio cable
Pricing & Availability
The WiiM Amp is available in silver and space gray for $299 at Amazon and Crutchfield.
Also available are other WiiM Network Streamers (without built-in amp):
ModelWiiM MiniWiiM ProWiiM Pro PlusWiiM Amp
MSRP$99$149$219$299
Ethernet NoYesYesYes
Chromecast AudioNoYesYesYes
Group with Nest Speakers and DisplayNoYesYesYes
Group with Echo Speakers and DisplayYesYesYesYes
Alexa Multiroom with UHDNoYesYesYes
Group with HomepodsYesYesYesYes
Works with AlexaYesYesYesYes
Works with GoogleNoYesYesYes
Works with SiriYesYesYesYes
Group with WiiM or Linkplay DevicesYesYesYesYes
Airplay 2YesYesYesYes
DLNAYesYesYesYes
Spotify ConnectYesYesYesYes
TIDAL ConnectYesYesYesYes
Gapless PlaybackYesYesYesYes
PEQYesYesYes (after firmware update)Yes
10 Band Graphic EQYesYesYesYes
Linkplay Music Streaming PlatformYesYesYesYes
Roon ReadyNoYesYes (after firmware update)Yes (after firmware update)
CPUDual Core A7Dual Core A53Quad Core Amlogic A113XInfo not provided
DRAM128mb512mb512mbInfo not provided
Flash128mb512mb512mbInfo not provided
Audio Input (wired)AuxLine-in, OpticalLine-in, OpticalLine-in, Optical,  HDMI-ARC, USB
Audio Output (wired)Aux, OpticalLine-out, Optical, CoaxLine-out, Optical, CoaxNo – Speaker Connections Only
AKM 4493SEQ DACNoNo YesNo – Saber ESS 9018
TI Burr-Brown Audio PCM1861 ADC NoNoYesInformation Not provided
Built-in AmplifierNoNoNoYes
Subwoofer OutputNoNoNoYes
4 Comments
4 Comments
  1. Mark Silgalis
    November 28, 2023 at 1:37 am
    This is a fantastic product. Having a WiiM pro I can attest to the company’s dogged commitment to software updates. The user experience brings to mind early days of the Apple Macintosh. Human interface design was the zeitgeist of development and it showed. Is this the ne plus ultra of hi-Fi? Nope. Will it suffice for most everyone? Most certainly. Heck, with an integrated like this it might actually get people to invest heavier into whatever speakers they choose to pair with this astonishing device.
    • Ian White
      November 28, 2023 at 3:03 am
      Mark,
      WiiM is making some really good affordable products right now. I have the Wiim Pro Plus on my desktop and it’s fabulous. Read my review if you have not seen it yet.
      Best,
      Ian White
  2. Jon D
    December 2, 2023 at 9:07 pm
    Was very surprised at the software quality of the wiim mini compared to my more expensive streamer I won’t mention. This amp looks impressive for the price, and the ESS 9018 is a solid DAC chip.
    • Ian White
      December 4, 2023 at 2:43 pm
      Jon,
      I agree. Super impressed with the WiiM Pro Plus and its app. Other high-end brands need to rethink their existing ones.
      Best,
      Ian White
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
The WiiM Vibelink drops streaming, but users gain an inexpensive, flexible, and powerful integrated amplifier.
WiiM is well-known for its streaming products, but they are expanding their reach with a dedicated integrated amplifier.
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Onkyo Icon Series includes three components offering network streaming, MM/MC phono capabilities, Roon-Ready support, and Class A/B amplification priced below $2,000 each.
