Loudspeakers
Wharfedale Opus2 Series Loudspeakers
The Wharfedale Opus2 top-of-the-line loudspeakers includes two bookshelf speakers, three floorstanding towers, two center-channel speakers (one wall-mountable) and two wall-mountable surround loudspeakers. Prices range from approximately $900 to $7,000 per pair.
Opus2 loudspeakers are available in four striking, piano-grade real-wood finishes, including Satin Cherry, Satin Rosewood, Satin Bird's Eye Maple and high-gloss Piano Black, to complement the most elegant home decors, custom installation audio/video systems and living environments. The finishes feature 10 coats of hand-polished clear varnish and take 11 days to complete. The wide range of Opus2 models and configurations make them suitable for use anywhere from smaller spaces to larger installations.
Opus2 loudspeakers are designed entirely without compromise to reproduce music and movies with exceptional realism and low distortion even at high volume levels. The woofers employ either a woven carbon fiber or glass/fiber/glass cone (depending on the model), while the midrange drivers utilize tri-laminated cone material. The Opus2 midrange driver is capable of reproducing the complete range of the human voice, yielding remarkable coherence and purity to male and female vocals. This driver is mounted in a die-cast aluminum housing that provides partial horn loading, and a dispersion characteristic that mimics the way real voices are heard in real life. The soft-dome Opus2 tweeter features a copper-coated aluminum voice coil, and a rear housing that acoustically isolates the tweeter, for smooth yet fast and detailed high-frequency response to beyond 50kHz.
All Opus2 drivers are produced in matched pairs within a less than 1dB tolerance across their entire range. All the drivers are closely matched to their enclosures; as a result, crossovers with a minimum of parts can be used, resulting in better phase linearity and smoother frequency response over a wider listening area. The loudspeakers' measured frequency response is extremely flat, yielding outstanding tonal accuracy, and the speakers are equally adept at reproducing movies and music with an effortless musical presentation.
Opus2 loudspeakers are built to the highest standard, utilizing variable-density multilayer cabinets made from Australian eucalyptus and pine, blended with synthetic fibers to create rigid, highly damped enclosures. Additional refinements include high-purity oxygen-free copper internal wiring, vibration-free crossover mountings, premium-grade capacitors and more.
Unlike many loudspeakers, Wharfedale Opus2 models are designed and built completely in-house, from their drivers and internal components to their striking, painstakingly finished cabinets. This vertical integration enables Wharfedale to have complete design and quality control over every aspect of every loudspeaker. In addition, the company can employ materials and techniques that are unavailable to other companies.
Wharfedale Opus2 loudspeakers are now available in the U.S.
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Wharfedale elevates its loudspeaker line with the Super Linton. Find out what the deal is.
Are high-end floorstanding loudspeakers becoming more affordable? The options in 2022 are a mixed bag and we are already thinking wireless for 2023.
Digital Music Systems
Can you really build a high-end audio system with vinyl playback around the Arylic H50 Network Amplifier?
The AURA sits between Wharfedale's EVO4 and Elysian loudspeaker lineups, designed for both music and home theater.
Can the $600 Wharfedale Diamond 12.2 loudspeakers offer a full-range experience? We build a system around them that can.
