Wharfedale DX-1 HCP Home Theater Speaker System
Wharfedale announced the DX-1 HCP (Home Cinema Package) consisting of four satellite speakers for the front and rear, plus a similarly diminutive center speaker and a compact active subwoofer. The speakers take their design cues from their Diamond 10.1 standmount speakers, with their curved cabinets and silver-finished cone surrounds, albeit shrunk to a much smaller size — the satellite speakers are just 19cm high.
Each DX-1 Satellite sports a 19mm silk dome tweeter and 75mm mid/bass driver with woven polypropylene cone. The enclosure is an infinite baffle (closed-box) design and the speakers can be sited in close proximity to a wall without affecting their performance.
The DX-1 Centre combines two 75mm mid/bass drivers either side of a 19mm tweeter. In addition, it incorporates an aperiodic loading system to aid bass response, consisting of a vent that is filled with resistive porous form to control airflow, thus contributing to a rich and detailed centre channel performance — a critical part of the surround sound experience.
The DX-1 Subwoofer combines a 200mm long-throw bass cone with a new-generation, 150W Class D amplifier, to deliver bass that's fast, deep and well-defined from an extremely compact unit — just 33.5×28.5x32cm (HxWxD). The quality of the subwoofer's design ensures it integrates superbly with the other speakers in the package, without any hint of bass bloating or overhang.
Available in high-gloss black or high-gloss white, the DX-1 HCP delivers smart, space-saving contemporary style and exhilarating sound for both movies and music — fast, punchy and detailed, with a sense of scale that belies the diminutive size of the speakers.
Price and Availability
The Wharfedale DX-1 HCP is available from September 2011 for £399.95.
Specifications
Model DX-1 Satellite DX-1 Centre
Description/Format Two-way closed-box system Two-way aperiodic system
High-Frequency Drive Unit 1 x 19mm silk dome 1 x 19mm silk dome
Mid/Bass Drive Unit 1 x 75mm woven PP cone 2 x 75mm woven PP cones
Frequency Response 120Hz – 20kHz ±3dB 80Hz – 20kHz ±3dB
Sensitivity (1W@1M) 84dB 86dB
Crossover Frequency 3.6kHz 3.6kHz
Recommended Amp (RMS) 20 – 80W 30 – 100W
Dimensions (HxWxD) 190x122x123mm (inc. grille and feet) 122x292x123mm (inc. grille and feet)
Net weight 1.8kg 2.5kg
Accessories Rubber feet Rubber feet
Model DX-1 Subwoofer
Description/Format Active subwoofer with reflex loading
Drive Unit 1 x 200mm long-throw cone
Frequency Response 40 – 120Hz ±3dB
Amplifier Power Output 150W RMS
Line Input Sensitivity 200mv for 75W
Crossover Range 30 – 150Hz (adjustable)
Inputs Stereo line in (2 x RCA-phono)
LFE line in (RCA-phono)
Stereo speaker level in
Signal-to-noise ratio (S/N) ≥75dB
Avg. Max Output @1m 110dB
Options Auto power; phase inversion
Dimensions (HxWxD) 335x285x320mm (inc. grille and feet)
Net weight 8.6kg
Accessories IEC power cord, rubber feet
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Wharfedale elevates its loudspeaker line with the Super Linton. Find out what the deal is.
Are high-end floorstanding loudspeakers becoming more affordable? The options in 2022 are a mixed bag and we are already thinking wireless for 2023.
Digital Music Systems
Can you really build a high-end audio system with vinyl playback around the Arylic H50 Network Amplifier?
The AURA sits between Wharfedale's EVO4 and Elysian loudspeaker lineups, designed for both music and home theater.
Can the $600 Wharfedale Diamond 12.2 loudspeakers offer a full-range experience? We build a system around them that can.
