Wharfedale’s AURA Speakers Are Designed to Deliver Great Sound Without Breaking the Bank
The AURA sits between Wharfedale’s EVO4 and Elysian loudspeaker lineups, designed for both music and home theater.
Wharfedale AURA Loudspeakers Lifestyle
Wharfedale is one of the oldest British manufacturers of high-end loudspeakers and over the past decade we’ve seen a successful focus on more affordable products that continue to sell well in almost every market. The brand has offered more expensive loudspeakers like the Linton Heritage, Evo, and flagship ELYSIAN series — but they always utilize the technology in their most expensive products in brand new lineups like the Wharfedale AURA models.
Let’s take a look at these models that were first shown at High-End Munich 2023.
Aura Features
Wharfedale AURA Serie Loudspeakers 2023
Cabinet Design
The cabinets for the AURA speakers are lacquered and polished to provide a beautiful furniture look with smooth curves that can be integrated into almost any home decor similar to the higher-priced ELYSIAN series speakers.
In addition to being visually pleasing, the cabinet design also helps to disperse the acoustic output of the drive units into the room without undesirable reflections.
AURA speakers are available in Black, White, and Walnut natural wood veneer finishes.
AURA AMT
AURA speakers are equipped with Wharfedale’s AMT (Air Motion Transformer) tweeters.
Wharfedale AURA Treble Unit Parts Exploded
An AMT provides a higher volume of air to be moved than with a conventional soft dome tweeter. The diaphragm is folded and carries conductive elements immersed in a strong magnetic field. This provides an efficient way of moving air resulting in a wide bandwidth transducer with extremely low distortion and reproducing extraordinary musical detail via speed and dynamic ability.
AURA Cones
The AURA midrange and bass speakers use a proprietary woven glass fibre matrix diaphragm for the cones in combination with high-flexibility rubber surrounds. The voice coils driving the cones are immersed in high flux magnetic fields, with eddy currents and inductance controlled by copper-clad pole pieces.
Wharfedale AURA Bass Unit Parts Exploded
The motor system is mounted on a die-cast aluminum chassis, fixed to the cabinet with six high-tensile bolts. This helps to maintain the rigidity and provide an accurate transient response. The rubber trim rings surrounding each chassis are not just decorative but limit unwanted resonance at the junction of the aluminum chassis and wood cabinet.
AURA Crossover
Peter Comeau, IAG’s Director of Acoustic Design, has created the sophisticated crossover design to ensure a seamless blend between the drive units. As with all Wharfedale series, only the highest grade, acoustically transparent components are used throughout the crossover network, ensuring all the musical detail is heard.
Wharfedale AURA loudspeaker crossover example
SLPP
Wharfedale’s SLPP (Slot Loaded Profiled Port) bass reflex design was developed from the original idea of Gilbert Briggs, the entrepreneur who set up and ran Wharfedale from 1932 to 1964. For the AURA series, the high-pressure, high-velocity airflow from a downward-facing port is matched to the low air pressure in the room by distributing the airflow through a series of slot ports in the cabinet. This reduces unwanted turbulence from the port and improves the efficiency of the bass reflex system.
Wharfedale SLPP Illustration
The following comparison table provides more detailed specifications for each speaker in the AURA series.
Wharfedale AURA Loudspeaker Collection 2023
Speaker ModelAURA 4AURA 3AURA 2AURA 1AURA CSAURA C
Speaker Type3-Way Floorstanding3-Way Floorstanding3-way Bookshelf 2-way Bookshelf 2-way Center 2-way Center
Enclosure TypeBass ReflexBass ReflexBass ReflexBass ReflexBass ReflexBass Reflex
Bass Driver (Woofer)2 x 6.5″ (150mm) Black Glass Fibre Matrix Cone 2 x 5″ (130mm) Black Glass Fibre Matrix Cone 1 x 6.5″ (150mm) Black Glass Fibre Matrix Cone 1 x 5″ (130mm) Black Glass Fibre Matrix Cone 2 x 5″ (130mm) Black Glass Fibre Matrix Cone 2 x 6.5″ (150mm) Black Glass Fibre Matrix Cone
Midrange Driver1 x 4″ (100mm) Black Glass Fibre Matrix Cone1 x 4″ (100mm) Black Glass Fibre Matrix Cone1 x 4″ (100mm) Black Glass Fibre Matrix Cone
Treble Driver (Tweeter)27 x 90mm AMT27 x 90mm AMT27 x 90mm AMT27 x 90mm AMT27 x 90mm AMT27 x 90mm AMT
Sensitivity (2.83V @ 1M)89dB88dB88dB86dB88dB89 dB
Recommended Amplifier Power30 to 200 watts25 to 150 watts25 to 150 watts25-100 watts25 to 150 watts25-200 watts
Peak SPL107dB104dB103dB103dB105dB107dB
Nominal Impedance4Ω (8Ω Compatible)6Ω (8Ω Compatible) 6Ω (8Ω Compatible) 6Ω (8Ω Compatible) 6Ω (8Ω Compatible) 4Ω (8Ω Compatible)
Minimum Impedance3.1Ω3.1Ω3.5Ω4.1Ω3.8Ω3.6Ω
Frequency Response (+/-3dB)37Hz ~ 22kHz39Hz ~ 22kHz42Hz ~ 22kHz48Hz ~ 22kHz56Hz ~ 22kHz48Hz ~ 22kHz
Bass Extension (-6dB)26Hz28Hz33Hz44Hz45Hz40kHz
Crossover Points475Hz, 3.3kHz460Hz, 3.3kHz520Hz, 4.5kHz2.9kHz2.4kHz1.9kHz
Dimensions (HWD)43.58 x 11.22 x 14.173 inches40.827 x 9.685  x 13.779 inches22.05 x 11.26 x 15.83 inches14.41 x 9.69 x 13.86 inches9.92 x 24.21 x 13.86 inches11.93 x 26.3 x 13.86 inches
Net Weight54 lbs50.7 lbs45 lbs27.5 lbs41 lbs60 lbs
Availability and Pricing
The Wharfedale AURA speaker line is through authorized UK and US Dealers and Global Distributors at the following prices.
  • Aura 1: £1499 / US $1999 / AU $3499 (pair)
  • Aura 2: £1999 / US $2499 / AU $4499 (pair)
  • Aura 3: £2999 / US $3999 / AU $6499 (pair)
  • Aura 4: £3999 / US $4999 / AU $8999 (pair)
  • Aura CS: £1099 /US  $1499 / AU $2499 (each)
  • Aura C: £1299 / US $1799 / AU $2999 (each)
Optional Stands (sold in pairs)
2 Comments
2 Comments
  1. BobPM
    October 9, 2023 at 7:31 pm
    Stands seem a little pricy, but otherwise love the look and specs.
    • Ian White
      October 9, 2023 at 11:29 pm
      Bob,
      They are supposed to fall in-between the Evo range and Linton/Elysium. Having not heard them yet…impossible to know how they compare to the Evo which I happen to think are excellent loudspeakers. I own 2 pairs of Wharfedale Diamond Series loudspeakers and if these are substantially better for only 3 times the price…this might be a huge bargain.
      Best,
      Ian White
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
