Wharfedale’s Aston Heritage Loudspeakers Will Be Limited to Only 500 Pairs?
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Wharfedale Aston Stand-mount Speakers Pair
British audiophiles must be snickering with delight this weekend with the knowledge that Wharfedale’s latest Heritage Series loudspeaker, the stand mounted Aston, is considerably cheaper on their side of the pond — and that’s even with the custom-made iron stands that complete this package that is limited to only 500 pairs.
Having just extolled the virtues of the highly underrated Wharfedale Super Denton Loudspeakers that are a bargain under $1,400 USD (stands not included), Wharfedale has introduced something even smaller for more than double the price. The Cabin Audiophiler is not amused. He’s also writing this from a less than ideal spot at the moment where the only music one can hear is emanating from the group therapy room.
Wharfedale Aston
The Wharfedale Aston will be available from late February in a choice of mahogany, walnut or black oak wood veneers. For UK customers, the Aston will retail at £1999 per pair in the UK with the stands included, or £1699 without stands. The stands are also available to purchase separately at £499 per pair.
Outside of the UK, the speakers and stands are available as a package, priced at $3000 USD / €2500 / AU$5000. No Canadian pricing so far but we will update when we have it.
Superior to the Super Linton?
Wharfedale’s Chief Engineer, Peter Comeau, is apparently bursting with anticipation to demonstrate these at the forthcoming Bristol Hi-Fi Show next week for the simple reason that they represent his “Statement” level product for the entire series.
Forget everything you know about the existing Linton, Super Linton, and Super Denton, because the Wharfedale Aston feature a completely new midrange/woofer and tweeter that are more akin to the models in the far more expensive Dovedale series.
The 1-inch fabric dome tweeter features a damped rear chamber to minimise the impact of vibrations that are directed from the rear of its diaphragm; in practical terms this means that the treble range should offer a greater sense of detail and airiness without sounding hard at higher listening levels.
Wharfedale Aston Woofer
The 5.91-inch midrange and woofer utilizes a carbon fiber cone designed to offer a “natural and expressive” performance; which is fancy marketing lingo for a less thick sounding upper bass and midrange compared to the Super Denton and Super Linton loudspeakers.
The cabinet features dual bass ports and a single set of high-quality binding posts.
Speaking of the cabinet, the Aston’s is constructed from a mixture of different woods which helps to scatter panel resonances and reduce noise or distortion. The Aston also features an inner layer of high-density particle board bonded to an external sheet of MDF by a special glue with resonance-damping properties.
Stand By Me?
The matching open-frame Aston stand is also made in England, from hardened high-carbon British Steel; this 560 x 265 x 255mm (22″H x 10.4″W x 10.03″D) stand is considered to be essential to maximise the performance of the loudspeaker.
Placed on the stands, the entire package comes in at 35″H x 10.4″W x 10.3″D (the speaker width is slightly narrower than the top plate).
Specifications
General Description2-way vented-box / standmount
Enclosure TypeBass reflex
Transducer Complement2-way
Bass Driver6″ (150mm) black Carbon Fibre cone
Treble Driver1″ (25mm) soft dome
AV ShieldNo
Sensitivity (2.83V @1m)86dB
Recommended Amplifier Power25-100W
Peak SPL95dB
Nominal Impedance
Minimum Impedance3.9Ω
Frequency Response (+/-3dB)55Hz – 20kHz
Bass Extension (-6dB)44Hz
Crossover Frequency2.3kHz
Cabinet Volume (in litres)10.8L
Dimensions (HxWxD)340 x 200 x 255 mm
Wharfedale Aston Bookshelf Speaker
The Bottom Line
The Wharfedale Heritage Series has been one of their most successful since the launch of the company going back to 1932, and there is no question that they offer something for almost everyone at some good price points.
The Aston never drops below 3.9 ohms and the 86dB sensitivity rating makes it a relatively benign load for most integrated amplifiers that can produce at least 50 watts; which makes it ideal for the latest offerings from Leak, Audiolab, NAD, Cambridge Audio, Naim, and Rega. The recently reviewed MOON 250i v2 might be a suitable candidate as well but that will definitely depend on the overall tonal balance of the loudspeakers.
The “limited edition” angle (500 pairs is not a lot) will certainly help with sales, but will North American audiophiles pony up $3,000 USD for such a small loudspeaker and stands?
That feels like a rather valid question when you consider the price of the Super Linton (along with their stands) and the Super Denton which are 50% cheaper; one has to assume that the Super Linton will give these a genuine run for the money, play louder, and offer more resolute low end response.
These would almost be ideal for the Cabin Audiophiler if the price was closer to $2,000 versus $3,000.
For more information: Wharfedale Aston
5 Comments
5 Comments
  1. David
    February 18, 2025 at 12:37 am
    This is another good looking speaker from Wharfedale’s Peter Comeau. I find most of Comeau’s retro designs to have a very nice aesthetic, however, all of these speakers are designed to sound best with the grills on. Ugh. I want to be able to ogle those beautiful drivers AND get the best possible sound. #grillssuck
    • Ian White
      February 19, 2025 at 6:34 pm
      David,
      And they do sound better with the grilles on. The Super Denton do — but I prefer them naked.
      IW
  2. ORT
    February 18, 2025 at 12:53 am
    Hello the house! Hail and well met indeed. I too am not at all amused at the cost and availability due to low production numbers of these absolutely freakin’ gorgeous speakers and their attendant stands!
    Just because they are inefficient does not mean they are to be priced above the common audio enthusiast! I am soon to be giving away to a dear friend a pair of Klipsch Synergy F-300 speakers to make room for a pair of small stand mounts.
    These Wharfedales did far more that tickle my fancy let alone my ego, rather their looks (and looks MATTER!!) drew me in as few speakers have done in my lifetime.
    This isn’t by any measure “sour grapes”, this is my reality. I do not begrudge those that can afford (easily or through long time saving!) these beauties. I shall soon choose something suitable to both my Ortwellian taste and wallet. 🙂
    I think I shall go even smaller than these marvelous Wharfedales. Really small and augmented by a 10 inch sub. Time to, as Steve Martin once said, get small.
    Frugal need not be fugly, but still be functional. And in truth there is plenty of fun in functional.
    The ORTicles at HelFi
    • Ian White
      February 19, 2025 at 6:33 pm
      ORT,
      As much as I love them, and have multiple pairs of Wharfedale loudspeakers on the way to FL, the $3,000 asking price is way too high. The Super Denton are 1/2 the price and one can deal with their limitations by using the right amplifier.
      I love the look of the Aston, and they would make sense in the smaller spaces that I will be dealing with — but the cost gives me pause.
      IW
  3. JGP
    February 25, 2025 at 2:24 am
    Five or six years ago, I spent $3000 CAD for a pair of Buchardt S400’s. No regrets. They are tiny compared to some of the others in the house, but they command respect.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
HDTV 4K & 8K TV
HDTV 4K & 8K TV
