Loudspeakers
Wharfedale Achromatic Series Loudspeakers
The Wharfedale Achromatic Series loudspeakers combine striking, slim design with custom-installation-friendly features and newly developed drivers that are engineered to deliver superlative sound.
The Achromatic lineup includes two wall-mountable left/right/surround speakers (models WA-S1 and WA-S2); two wall-mountable center-channel speakers (WA-C2 and WA-C4); two floorstanding towers (the WA-T4 and WA-T8) and two powered subwoofers (models WA-8SB and WA-12SB). The loudspeakers are available individually, or as part of the Micro, Basik, Supro, L/C/R or Ultimo system packages for smaller, mid-sized and larger rooms. Prices range from $169 to $599 for individual speaker pairs and from $699 to $1,699 for system packages.
Achromatic Series loudspeakers are sleek and elegant, making them ideal for custom-installation, architectural and designer applications. All models have a stunning piano-black finish with soft leatherette accents. Their slim-profile design complements any flat-panel TV and home decor. The wall-mountable models can be installed either horizontally or vertically using their standard keyhole wall mounts.
“Achromatic” literally means “without coloration” — the sonic design goal of the Achromatic Series. To achieve their clear, neutral, yet expressive and detailed sound, Wharfedale developed new drivers exclusively for the Series. The compact yet powerful 3-inch woofer/midrange driver features an inverted aluminum dome, along with a high-sensitivity, long-throw voice coil that is directly coupled to the edge of the dome via a butyl rubber surround.
The 1-inch soft-dome tweeter utilizes a ferrofluid-cooled, copper-coated aluminum voice coil, to preserve subtle high-frequency nuances and avoid dynamic compression. The powered subwoofers employ composite-cone drivers in reflex-ported enclosures for maximum efficiency and bass output.
All the drivers are closely matched to their enclosures. As a result, crossovers with a minimum of parts can be used, resulting in greater sonic purity and smoother frequency response. The drivers and enclosures are also designed to provide more uniform in-room response and smooth dispersion over a wider listening area.
Unlike many loudspeakers, all Wharfedale models are designed and built completely in-house, from their drivers and internal components to their elegantly finished cabinets. This vertical integration enables Wharfedale to have complete design control over every aspect of every loudspeaker, and ensure unit-to-unit consistency. In addition, the company can manufacture superior-performance loudspeakers at attractive price points and employ materials and techniques that are unavailable to other companies.
Wharfedale Achromatic Series loudspeakers are now available in the U.S.
1 Comment
1 Comment
  1. Jmostyn
    May 23, 2012 at 1:47 pm
    I just bought this full system of Wharfedale speakers at JB  Hi Fi in Sunshine last Friday and set them up on the weekend.  A magnicifent system as I’d already done my homework before I bought them.  Also I was very lucky to get them at $600 down from $2000  due to end of model sale.  The best system I’ve ever had and compliment my Sony Bravia led tv, Yamaha receiver and Samsung blue ray player.  Altogether by buying all my components at JB separately I saved a huge 50%  off the original prices [mean average when adding all the prices and subtracting the final price from the original].  I’d recommend these speakers to any one and to do their homework by going and dealing with JB. They are very good to deal with, their staff know exactly what they are talking about and will give you good advice and good value by being smart and doing your homework before you go there.
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Wharfedale elevates its loudspeaker line with the Super Linton. Find out what the deal is.
Are high-end floorstanding loudspeakers becoming more affordable? The options in 2022 are a mixed bag and we are already thinking wireless for 2023.
Digital Music Systems
Can you really build a high-end audio system with vinyl playback around the Arylic H50 Network Amplifier?
The AURA sits between Wharfedale's EVO4 and Elysian loudspeaker lineups, designed for both music and home theater.
Can the $600 Wharfedale Diamond 12.2 loudspeakers offer a full-range experience? We build a system around them that can.
