Weizhi Precision PRS-6 Six Outlet Power Distributor
Perfectly Shields Against Electrical Noise, Vibrations, Magnetic and RF Interference
Aaudio Imports, a leading supplier of world-class high-end audio products, introduces into the U.S. market the extraordinarily noise-free PRS-6 Power Distributor, designed specifically to meet the demanding needs of home audio, video and theater systems, by Weizhi Precision of Taiwan.
The PRS-6 Power Distributor is by far the best available solution to shield audio components from noise in electrical systems, as well as vibrations, and magnetic and radio frequency (RF) interference. Its electrical neutrality helps preserve an audio or video signal’s correct tone, pitch, pace and timing. It provides support for unlimited dynamics, high resolution, micro details and an ultra-low noise floor, and introduces no signal compression.
A professional R&D team programmed the PRS-6’s innovative and compact chassis design, and extremely high build quality. Computerized CNC machinery, for example, precisely cut the brick of Swiss-made Extra Super Duralumin that houses the receptacles and provides a base for the carbon fiber topped chassis. Duralumin is an especially hard, light aluminum alloy often used in aircraft fabrication.
The PRS-6’s six Oyaide R1 outlets provide a perfect safeguard against vibration. The Oyaide R1 receptacle is designed specifically for audio/video components, with a fit and finish more like a Swiss watch than an AC receptacle. It exceeds the standards for conventional hospital-grade receptacles, which improve contact security but not necessarily sound quality, and is totally non-magnetic to minimize potential disturbances from magnetic fields. It uses twice-polished beryllium copper as a base metal, plated with platinum, then finished with palladium. Twenty-four karat gold-plated brass fittings add strength and durability, and glass-filled nylon adds high rigidity, resonance absorption, and safe insulation.
A special nanotech coating of FAM material on the PRS-6’s interior and exterior surfaces shields it from 99.9 percent of RF and EMI interference.
The PRS-6 Power Distributor is available now from authorized Aaudio Imports dealers at a suggested price of $3,200 (U.S. MSRP).
About Audio Imports
Based in Parker, Colorado, Aaudio Imports is a leading supplier of truly world-class high-end audio products to top quality dealers. Its high-end manufacturers, selected from companies around the world, also stand out from the crowd, and include Acapella in Germany, Audiotop in Switzerland, Bergmann Audio in Denmark, Einstein Audio Components in Germany, Isoclean Power in Hong Kong, Lindemann and Millennium Audio in Germany, Stage III concepts in the U.S., Tidal Audio in Germany, Weizhi Precision in Taiwan, and Ypsilon Electronics in Greece. Aaudio Imports dealers are true music lovers, selected for their product knowledge, listening skills, and desire to seek out only the best for their customers.
About Weizhi
Based in Taiwan, Weizhi Precision specializes in manufacturing speakers, power distributors, isolation components, transformers, inductors, EMI Components and the like. Its R&D-driven computerized CNC machining center is capable of high-quality turning, milling, drilling, grinding, adjustment and polishing operations. All products are produced entirely in-house in the belief that only in this way can Weizhi precisely control production quality to consistently deliver excellent performance for its stereo and other musical components.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
