Waterfall Audio Debuts Niagara XT Series Speakers
Choose from three high-end glass enclosed loudspeakers with horn tweeters encased in wood or glass.
Waterfall Audio Niagara XT1, XT2 and XT3 Loudspeakers
Based on what we have seen from manufacturers so far in 2024, affordable high-end loudspeakers seem to be taking a backseat to ultra high-end models from a wide range of brands (check our examples in the “related reading” section at the bottom of this article).
It has been somewhat fascinating (and disturbing) to cover the rather extensive list of new loudspeakers that have been released since January that require selling an organ (or child) to afford. If spending $750,000 on a pair of loudspeakers does not feel excessive to you — we have some recommendations in regard to sources and amplification that will easily take that system to over $2,000,000 USD.
With that in mind, in this article, we are taking a look at a very interesting new speaker line from Waterfall Audio, the Niagara XT series.
Unveiled at the recent 2024 ISE tradeshow, the Niagara XT series of floorstanding loudspeakers are a stylish, loudspeaker design combining a refined sense of haute couture elegance with clear and vibrant sound.
Waterfall Audio Niagara XT2 Loudspeakers Lifestyle Angle
From Cedric Aubriot, CEO and Founder of Waterfall Audio: “Niagara XT dramatically moves the needle in terms of what is achievable in contemporary loudspeakers,…Using all our expertise in loudspeaker aesthetics, materials, and performance, we have created a beautiful new series for luxury home cinema, media room and hi-fi projects that will not only be a striking addition to any interior but will also produce audio of magical precision and quality. Visitors to ISE 2024 were among the privileged few to see and hear this significant breakthrough, one that will delight integrators, interior designers, and their clients for many years to come.
Niagara XT Series
The Niagara XT Series is comprised of three models, the XT2, XT3, and XT1. All three speakers share the following key features.
Waterfall Audio Niagara XT Series Passive Radiator
Glass Enclosures: The speaker enclosures are made of transparent platinum safety glass (XT2 and XT3: 10mm thick; XT1: 6mm thick), This provides visual impact in natural light, subtly reflecting and refracting sunbeams. With a transparent enclosure the mid/bass Atohm drivers appear suspended in mid-air and are underpinned by an ultra-low frequency 21cm passive radiator in a down-firing position in the solid, CNC cut, brushed tapered aluminum base.
Waterfall Audio Niagara XT Series Horn Tweeter
Horn Tweeters:  The speakers incorporate horn tweeters with the XT1 and XT2 using a wood enclosure and the XT3 using a glass enclosure. The wood tweeter sections are available in alternative wood finishes, including walnut, to suit the client. preference. Offered is a variety of colors, textures, and grains, the wood is individually selected, paired, and matched for each speaker.
Waterfall Audio JESTREAM Damping Technology
Jetstream Damping: The drivers are equipped with Waterfall Audio-developed JETSTREAM damping technology. This maximizes performance and supports the mechanical decoupling of the mid-bass driver from the glass structure. JETSTREAM allows for deeper and faster bass, along with a smoother response in the midrange and treble range, along with optimized heat dissipation and control of the rear wave on the cone.
Waterfall Audio Niagara Loudspeakers Leather Encased Base
Leather Speaker Base: The XT Series aluminum speaker base is housed in luxurious, hand-stitched Nappa Leather, renowned for its smooth grain, softness, and durability.
Tip: Nappa leather is used as interior fabric in premium automotive brands, including Mercedes and Porsche.
Recommended Subwoofers for Home Theater Use: Waterfall HF2-250X or HF3-500X.
Waterfall Audio Niagara XT1,  XT2 and XT3 Loudspeakers Size Comparison
Left to right: XT2, XT3, XT1
Comparison
Niagara XT1Niagara XT2Niagara XT3
Enclosure Type and ThicknessTransparent Platinum Safety Glass (6 mm)Transparent Platinum Safety Glass (10 mm)Transparent Platinum Safety Glass (10 mm)
Speaker Type2 ½ way – 4 drivers2 ½ way – 4 drivers2 ½ way – 4 drivers
Ultra Low-Frequency Driver1 x 210 mm
(8.3-inches), Atohm UFR210
1 x 210 mm (8.3-inches), Atohm UFR2101 x 210 mm (8.3-inches), Atohm UFR210
Bass/Midrange Driver2 x 150 mm (6-inches), Atohm LD1502 x 180 mm (6-inches), Atohm LD1802 x 180 mm (6-inches), Atohm LD180
Tweeter1 x 20 mm (.9 inches), Atohm SD20X + wood horn1 x 20 mm (.9 inches), Atohm SD20X + wood horn1 x 20 mm (.9 ihches), Atohm SD20X + glass horn
Passive Radiator 1 x 21 cm (8.3 inches)1 x 21 cm (8.3 inches)1 x 21 cm (8.3 inches)
Recommended Amp Power (w/o clipping)40 – 200 Watts40 -250 Watts40 -250 Watts
Peak Power 400 Watts500 Watts500 Watts
Nominal Impedance8 ohms8 ohms8 ohms
Minimum Impedance4 ohms4 ohms4 ohms
Sensitivity (2.83 v/1 m)89 dB90 dB90 dB
Frequency Response (+/- 3 dB) 42 Hz – 28 kHz35 Hz – 28 kHz35 Hz – 28 kHz
Dimension (WxHxD)250 x 280.65 x 991.20 mm
(9.8 x 11 x 39 inches)
300 x 346.25 x 1169.20 mm
(12 x 13.63 x 46 inches)
Weight 20 kg/44 lbs40 kg/88 lbs44 kg/97 lbs
Waterfall Audio Niagara XT2 Loudspeakers Front
Pricing & Availability
The Waterfall Niagara XT speakers are available through authorized distributors and dealers.
Note: US prices forthcoming. If you have questions, contact Waterfall Audio directly.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
The Bowers & Wilkins 703 S3 is the least expensive floorstanding loudspeaker with a tweeter-on-top design in the 700 series.
