Hard Drives
Be Warned of Hard Drives at Risk
Being able to spot trouble before it occurs is always a good thing. Airplanes have instruments that inform the pilot of altitude, attitude and even the proximity of other aircrafts. Cars have gauges that alert the driver if the vehicle is low on fuel or oil, if the engine is overheating, and nowadays even if tires are low on air. Weather stations have instrumentation that can spot severe storms many miles away, often saving entire towns.
The builders of computers have instituted trouble warnings as well. Pop-up messages warn of hardware problems, utilities such as Windows Task Manager allow monitoring of performance, application resource usage and networks, and other utilities exist to monitor and warn of other problems.
Unfortunately, there is no native utility to warn of file fragmentation levels on hard drives showing danger of decreasing disk performance and even the risk of hard drive failure. Diskeeper Corporation, developers of Diskeeper automatic defragmentation solutions, has filled this gap with a product called Disk Performance Analyzer for Networks.
Disk Performance Analyzer for Networks is a stand-alone utility that detects and reports fragmentation-related performance loss on networked systems. It allows IT personnel and system administrators to identify performance bottlenecks, scan systems from one access point, and pinpoint system problems before they become help desk headaches–without having to run painstaking manual analysis on each system.
“With the aid of Disk Performance Analyzer for Networks, I was able to locate servers in our environment that were at risk of failure or had poor performance due to severe fragmentation,” said Steven Enair, Senior Technology Specialist with Telus Production Operations in Burnaby, B.C., Canada. “We have started implementing Diskeeper through all server farms.”
“Disk Performance Analyzer for Networks, alerted me to several servers in our domain that needed my attention,” added Jasons Draus, Network Services Manager with Deloitte & Touche in Guam and Micronesia. “It also showed me how I was using my storage space in a concise, easy to read report.”
Additional features of the product include the ability to create custom groups for easy management, to select systems to scan through the Active Directory or IP addresses, and to run scheduled reports and have the results emailed.
Disk Performance Analyzer will warn you of problems and dangers missed by other utilities, and allow you to quickly take corrective actions. Download it free of charge from the Diskeeper web site at http://www.diskeeper.com
Contact: Colleen Toumayan
Email: ctoumayan@diskeeper.com
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
