Wadax PRE1 Ultimate Digital Preamplifier
Wadax PRE1 Ultimate
Wadax announced the new $72,670 PRE1 Ultimate remote-controlled digital preamplifier with DIVIN phono stage, Zepto super clock, and Hermes SSD server. The PRE1 Ultimate accepts inputs from a computer via its USB HD hub, SPDIF, TOSLINK, BNC, stereo line inputs and all phono cartridges. It can be connected to any amplifier through its single-ended or differentially balanced outputs. Additionally, digital outputs are provided to connect with digital-input speakers for a lossless connection.
The proprietary Wadax musIC signal processor operates in the digital domain, without loss. Both A/D and D/A converters process under ideal conditions.
Vinyl Replay Redefined
The optional phono stage combines the warmth and delicacy of vinyl playback with perfect channel balance, spectral accuracy, and phase coherence via customized RIAA signal reconstruction ‘maps’ specific to your cartridge.
• Reducing the signal losses inherent in traditional phono preamplifiers
• Avoiding RIAA process errors by applying custom mapping
• Also addresses non-linear cartridge distortions
Wadax PRE1 Ultimate Back
Native DSD and 24/192 playback
24 bit 192 kHz capable
1 USB cable, no networking elements – plug and play
No Ethernet streaming – total stability
JRemote is the recommended control software for Apple and Android
Convergence
The PRE1 is the ultimate remote-controlled digital preamplifier. Facilities include user-assignable analog and digital inputs and outputs. The optional Hermes SSD Server and DIVIN phono stage facilitate easy integration into any system. The playback chain is shorter, more accurate and musically expressive.
Price and Availability
Hi Fi One is the exclusive North American distributor. MSRP for the PRE1 is $72,670.
2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
