Digital Music Systems
Wadax Hermes ClearStream Music Streamer and Server
Wadax of Spain announced the Hermes ClearStream digital music streaming solution for audiophiles. It adds plug n’ play streaming playback to the Wadax PRE1 and PRE1 Mk II universal digital preamplifiers. This optimized product solution is comprised of three parts that can be added at anytime.
  1. A recording and playback streamer module housed inside the Wadax PRE1.
  2. A one box external server (see below)
  3. An Application control point being an iPad 2 or later (not included) as the user interface.
The internal streaming module requests data from the external server, which is asynchronously clocked to the D/A master clock. A buffer stores data and sends it in bursts as required by the DAC. This topology cancels the timing issues in data transfer and is superior to all SPDIF connections. Jitter at less than 1ps and other audio data induced errors approach theoretical limits. This performance is only possible if the DAC and the streamer are within the same box as the master clock. Also, asynchronous transmission is ideal for networking.
The Hermes playback streamer combines digital file management with the D/A conversion stage. With this protocol, the best possible CD content for the PRE1 is the recording and playback streamer feeding the one box external server.
No “spinning disc” transport can improve this connection for sound quality. File formats are upgradable and include WAV, AIFF, FLAC, ALAC, WMA and MP3. Hermes can playback files from 32KHz to 192KHz, 16 to 32 bits. Note: 32 bits is only available when the source is the Wadax musIC chip. It can record at 96KHz and 24 to 128 bits. Note: 128 bits is only available when an analog input source is coded via the musIC chip.
The Hermes Server is connected to the PRE1 via RJ45. Cat 6 or later is required. Music can be stored internally via solid-state drive or by connected NAS. Both are optional, POA. Up to 2 SSD drives can be connected in the bays at the back of the server. The integral CD drive rips bit perfect ‘read till right’ disks and requires Internet connection for automatic meta-tagging.
Wadax Hermes ClearStream - front
Additionally, the Hermes Server + control point, (an iPad 2 or later application) is uPnP-DLNA compatible and can be used with third party uPnP streamers’.
Pricing
Hermes ClearStreamtm Streamer: 4,300 USD
Hermes ClearStreamtm Server: 7,670 USD
Hermes ClearStreamtm Streamer and Server: 11,055 USD
Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
