Car Accessories
Vizualogic Quantum Overhead Monitor/DVD Player
OLYMPUS DIGITAL CAMERA
Installs With or Without DVD Player
Corona, CA – With the introduction of the all-new Quantum Overhead Video System, Vizualogic now offers consumers and mobile entertainment dealers the widest choice of mobile entertainment products.
Available as a stand-alone monitor or with an optional 1 ¼-inch DVD Player, the thinnest in the industry, the Quantum is designed for use in virtually any vehicle on the market, particularly minivans that don’t have a factory-installed mobile entertainment system.
Designed to Vizualogic’s stringent quality standards, the Quantum is available with either a 7- or 10.2-inch screen.  The optional DVD player module easily installs between the flip-down monitor and the headliner/mounting bracket for a flawless, original equipment look. Backlit control buttons ensure easy operation of the monitor and/or DVD player. The 500 NIT Super Brite low-profile monitor measures just 1 1/8-inches deep, and features a wide, 120° viewing angle for great sight lines all across the rear seats.
The system features a front and rear seat unified IR remote control with a Mute button, for operation and control from the front seat, allowing the driver (or Mom) to shut down or control the volume, as well as all the other remote functions.  The Quantum also features a built-in IR Audio Transmitter for optional wireless headphones.
The Quantum features three AV inputs and one AV output for the utmost versatility.  It also comes with an integrated FM modulator, controlled by the remote, with seven available frequencies.
In addition, dual dome lights on the monitor housing connect to the vehicle’s existing dome light wire assembly, and a 15-foot AV I/O wire assembly is included for easy installation of a separate DVD player or other source unit.
Technical Specifications
MONITOR
  • Monitor Size 7” or 10.2” diagonal
  • Monitor Aspect Ratio 16:9 Widescreen
  • Display System Low-reflection, rear-projection type TN liquid crystal panel
  • Drive System TFT active matrix drive, normally white display
  • Number of Picture Elements To come
  • Brightness Min. 400 cd/m², typ. 500 cd/m²
  • Temperature Operating Range -30°C to 85°C
DVD
  • Signal System NTSC/PAL
  • Horizontal Resolution 500 lines or greater
  • Video S/N Ratio 60 dB
  • Audio S/N Ratio 100 dB
  • Frequency Response 17 Hz to 20 kHz (± 1dB)
  • Dynamic Range 90dB
  • Harmonic Distortion 0.5%
  • Temperature Operating Range 0°C to 55°C
  • DVD Format DVD Video (Single/Double Layer), DVD Recordable, Video CD, CD Digital Audio (CD Text), CD Recordable, CD ReWritable, MP3 Playback (ID3 TAG), HDCD, Hybrid SACD (CD layer only), SVCD
Vizualogic specializes in the development and manufacture of high quality integrated mobile electronic systems and accessories.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
