Monitors
Vizualogic Introduces Headrest Monitor/DVD Player for Mercedess-Benz M-Class
OLYMPUS DIGITAL CAMERA
FOR IMMEDIATE RELEASE
Contact:
Mariellen Fagan
Crowl, Montgomery & Clark
330-494-6999, ext. 201
mfagan@crowlinc.com
VIZUALOGIC INTRODUCES ALL-IN-ONE
HEADREST MONITOR/DVD PLAYER FOR 2006
MERCEDES-BENZ ML-CLASS
CORONA, CA — Vizualogic has introduced a new A-1000 all-in-one headrest monitor/DVD player designed specifically for the 2006 Mercedes-Benz ML-class SUV. The A-1000 headrest monitor is available for all Mercedes-Benz ML models and interior colors. The headrest is a PerfectMatch to the exact shape, size and color of the original factory headrest. Simply remove the existing factory headrest and replace it with the A-1000 system.
And with no cutting required, the Vizualogic A-1000 is a perfect option for leased vehicles — at the end of the lease, it’s easy to replace the Vizualogic headrests with the original equipment headrests.
The top-loading monitor/DVD player makes inserting and changing DVDs easier for children and other backseat passengers, and the A-1000 has many additional, unique advantages that other combination monitor/DVD players do not offer:
Viewing Flexibility/Versatility
The A-1000 is the only all-in-one headrest monitor/DVD system that enables the user to select the output of either DVD source, and view the DVD on the monitor of choice. Other combination monitor/DVD players on the market today do not allow for viewing the same movie or game without extensive customer reprogramming or the use of external jumper wires suspended between headrests. And the A-1000 still allows for independent DVD or game viewing on each individual headrest monitor as well. All totaled the A-1000 features three flexible inputs.
Wireless Audio
The A-1000 also is the only combination headrest monitor/DVD player that features a built-in wireless FM modulator, providing audio through the vehicle’s radio system. From an on-screen display, consumers can select from six FM frequencies to allow for the clearest, interference-free audio reproduction.
Since it’s wireless, installers can reduce 15-20 minutes of installation time that would be required when installing wired systems. Plus, Vizualogic still provides the option of listening through wireless stereo headphones.
Multi-Source Capability
The Vizualogic A-1000 features standard Multi-source, easy to understand, switchable video source selection. Users simply select the following video options via remote control: Driver DVD, Passenger DVD, or Aux (game).
Environmentally Sound
Many video components are easily susceptible to low or high temperature conditions. But Vizualogic’s products have the widest operating temperature range (-10C to 70C) in the industry, surpassing OEM specifications to ensure that your mobile video system will operate in even the harshest conditions.
Currently, Vizualogic offers more than 5000 different make/model/color variations of its PerfectMatch Headrest Monitors, which match the original OEM headrest with installed monitors that require no cutting.
Technical Specifications
MONITOR
Monitor Size 7″ diagonal
Monitor Aspect Ratio 16:9 Widescreen
Display System Low-reflection, rear-projection type TN liquid crystal panel
Drive System TFT active matrix drive, normally white display
Number of Picture Elements 336,960 dots (W:1440 x H:234 dots)
Brightness Min. 400 cd/m², typ. 500 cd/m²
DVD
Signal System NTSC/PAL
Horizontal Resolution 500 lines or greater
Video S/N Ratio 60 dB
Audio S/N Ratio 100 dB
Frequency Response 17 Hz to 20 kHz (± 1dB)
Dynamic Range 90dB
Harmonic Distortion 0.5%
Vizualogic also offers a line of A-1000 All-In-One Headrest Monitors/DVD Players for 2005 Mercedes-Benz C, E and S-Class headrests.
Vizualogic specializes in the development and manufacture of high quality integrated mobile electronic systems and accessories. Vizualogic is a division of TMI Products, Inc. TMI, with more than 190 employees, was founded in 1982, and is based in Corona, CA. For more information, contact Mariellen Fagan, director of public relations, at 330-494-6999, ext. 201, or email mfagan@crowlinc.com. For press information and downloadable releases and images, visit the Vizualogic online pressroom at www.editorpressroom.com/vizualogic, or www.vizualogic.com.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
