VIZIO XVT323SV and XVT373SV Razor LED LCD HDTVs
VIZO XVT373SV Razor LED LCD HDTV - Side
VIZIO announced the 32-inch XVT323SV and the 37-inch XVT373SV Edge Lit Razor LED LCD HDTVs with local dimming that produce a 1,000,000:1 contrast ratio with full HD 1080p resolution and a 120 Hz refresh rate. The new XVT televisions feature a sleek and slimmer new profile at less than a 2-inch depth.
The new Edge Lit Razor LED LCD models bring the major improvement of local dimming for the first time to these screen sizes, improving contrast ratios to 1,000,000:1, an enormous increase over the 50,000:1 contrast ratio seen in the previous generation products. Another new addition to these screen sizes is VIZIO's complete VIA platform, with integral Dual Band 802.11n Wi-Fi and VIZIO's unique Bluetooth remote control with QWERTY keyboard.
VIZIO Internet Apps
VIZIO XVT373SV Razor LED LCD HDTV HDMI Inputs
Each of these VIZIO XVT series HDTVs brings the best of the web to the home through VIZIO Internet Applications, the industry leader with over 75,000 movie and TV show options and 10 Million songs. Unlike competitive sets that require the purchase of external adaptors, VIZIO provides seamless state-of-the-art wireless Internet access through integral Dual Band 802.11n Wi-Fi. The user experience is vastly improved through the industry's only remote control with dual Bluetooth/Infrared functionality and a slide-out QWERTY keyboard.
Class-leading Sound Experience
High definition audio is an important element in each XVT Series set, enabled through the use of quality speakers and SRS TruSurround HD premium audio processing, which creates an immersive virtual surround sound from stereo and surround sources. In addition, SRS TruVolume eliminates sharp jumps in volume that may be heard when switching from channel to channel or coming in and out of commercial breaks.
All the Right Connections
Providing great flexibility for multiple sources including disc players, portable devices and gaming, the XVT373SV and XVT323SV each have 4 HDMI 1.3 inputs. All sets are available and shipping now.
VIZIO XVT Series
Model Size/
Res.
Contrast Ratio Smooth Motion Smart Dimming HDMI 1.3 Inputs Dual Band 802.11n VIZIO Internet Apps Bluetooth Remote SRS Audio MSRP
XVT553SV TruLED 55″ FHD 10M:1 240 Hz SPS 120 Zones 5 Yes Yes Yes Yes $2,199
XVT473SV TruLED 47″ FHD 10M:1 240 Hz SPS 160 Zones 5 Yes Yes Yes Yes $1,799
XVT423SV TruLED 42″ FHD 10M:1 240 Hz SPS 120 Zones 5 Yes Yes Yes Yes $1,199
XVT373SV Razor LED 37″ FHD 1M: 1 120 Hz Yes 4 Yes Yes Yes Yes $899
XVT323SV Razor LED 32″ FHD 1M: 1 120 Hz Yes 4 Yes Yes Yes Yes $699
SilentPower Omni Lan Connection Front
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
In addition to its TVs, Vizio also makes an extremely popular line of soundbars. The M-Series has been updated for 2023.
The Vizio M51ax-J6 5.1-channel Sound Bar includes external surround speakers, support for Dolby Atmos, DTS:X and more for only $329.
For 2024 VIZIO is introducing seven new soundbars priced from $99 to $499 that easily attach to the bottom of a TV.
HDTV 4K & 8K TV
At 86-inches in diagonal, Vizio's largest 4K TV ever arrives at the end of April for only $999.
HDTV 4K & 8K TV
Walmart has acquired Vizio and that could be good news for consumers looking to get a good price on a new TV.
