HDTV 4K & 8K TV
Vizio’s V-Series 4K UHD 86-inch TV is Only $999 But Is It Worth Considering?
At 86-inches in diagonal, Vizio’s largest 4K TV ever arrives at the end of April for only $999.
VIZIO V4K86C-0804 86-inch 4K HDR Smart TV Front with OS Menu
It was not that long ago that consumers considered a 65-inch TV to be the largest screen that they would consider for a living room or den. The COVID pandemic changed all of that and with consumers staying home to enjoy their favorite TV shows and movies, TV makers took the most logical step and began introducing screen sizes of between 85 and 100+ inches. A number of manufacturers introduced 98″ models (and larger) at CES 2024 and whilst the first generation of high-end models are not inexpensive — we expect to see prices fall rather dramatically over the next 12 months giving consumers a real alternative to projectors.
With that in mind, Walmart-owned Vizio has entered the large screen landscape with a new 86-inch TV. Although this screen size doesn’t match the 98-inch and larger screen sizes from some other TV makers such as Samsung, TCL, and Hisense, at 86-inches it is more than large enough for those looking for a larger screen, especially with its $999 price tag – that’s right, an 86-inch TV for about $1,000 is definitely appealing.
However, before you grab your wallet let’s find out what this TV actually offers.
VIZIO V4K86C-0804 86-inch 4K HDR Smart TV Left Angle
Key Features
The Vizio V4K86C-0804 is an entry-level 4K UHD LCD TV with Direct Full Array LED Backlighting. More advanced display technologies such as Local Dimming and Quantum Dots are not included, but are offered in Vizio’s step-up Quantum and Quantum Pro models.
HDR Support: Dolby Vision, HDR10, HDR10+, and HLG provide improved contrast, color, and detail on encoded content. However, the effectiveness of HDR depends on how much light the TV can display – that information has not been provided by Vizio.
Gaming: Although the TV only provides a 60Hz refresh rate – it is compatible with 120Hz 1080p gaming from PC or Game Console sources. The TV does not provide 4K/120Hz gaming support.
Streaming: In addition to access to an extensive number of streaming services (Netflix, Disney+, Amazon Prime Video, etc..), Vizio’s 86-inch TV also includes WatchFree+ which is Vizio’s free streaming option that includes over 260 free channels. Apple Airplay 2 and Chromecast are also built-in.
Bluetooth: This allows users to send audio wirelessly from the TV to a pair of Bluetooth headphones.
Voice Remote: Browse Apps, search for titles, and access some TV functions using voice commands. The TV is also compatible with the Vizio Mobile Control App for Android and iOS
VIZIO V4K86C-0804 86-inch 4K HDR Smart TV - Right and Left Sides
Specifications
  • Model: V4K86C-0804 (Vizio V-Series)
  • Screen Class Size: 86-inches (Viewable Display Size is 85.50-inches)
  • Display Resolution: 3840 x 2160 pixels (4K UHD)
  • Backlight Type:  DLED (Direct LED)
  • HDR Support: Dolby Vision, HDR10+, HDR10, HLG
  • Wide Color Gamut: Ultra Color Spectrum™
  • Active Pixel Tuning: No (This is the only model in the Vizio V Series that does not list Active Pixel Tuning as a feature)
  • UHD Upscaling: Spatial Scaling Engine (effectively scales lower resolution sources to look better on the TV’s 4K UHD screen.
  • Refresh Rate: 60Hz
  • Additional Motion Processing: Dynamic Motion Rate 60, Clear Action
  • Display Processor: IQ Active™
  • Gaming Support: VRR (Variable Refresh Rate), ALLM (Auto Low Latency Mode),  V-Gaming Engine™. Input Lag < 10ms @60Hz, measuring middle of screen
  • HDMI Inputs: 3 HDMI ver 2.1, ARC/eARC support included.
  • USB: 1 (This allows users to play compatible image, video, or music files from a USB flash drive).
  • Wi-Fi: WiFi 6, Ethernet connectivity also provided,
  • Bluetooth Support: Ver 5.2 with BLE
  • Audio Outputs: Analog Audio  Output, Digital Audio Output (SPDIF) 1 (rear)
  • Speaker System: 2 x 10 watts
  • Additional Audio Support: DTS Virtual:X
  • Dimensions with Stand: 75.59 x 46.08 x 16.89-inches (1920 x 1170.4 x 429 mm)
  • Dimensions without Stand: 75.59 x 43.13 x 3.30 inches (1920 x 1095.5 x 83.8 mm)
  • Weight with Stand: 82.01 lbs (37.2kg)
  • Weight without Stand: 80.69 lbs (36.6kg)
Wall mounted VIZIO V4K86C-0804 86-inch 4K HDR Smart TV
Included Accessories
  • XRT270 Voice Remote
  • Remote Control Batteries: 2 x AAA (Duracell)
  • Power Cord Type
  • Detachable 2-prong. North America Plug Type A
Price & Availability
The 86-inch Vizio V4K86C-0804 4K TV is listed on Vizio’s Website for $999. It is expected to be available for purchase beginning April 29, 2024, through Vizio and select retailers.
View other 86-inch TVs at Amazon.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
