Vizio Refreshes Entry-level Soundbar for 2023
The Vizio V214X-K6 is a budget soundbar with wireless subwoofer that provides a no-frills boost for your TV sound. Is it all you need?
2023 Vizio V214X-K6 Soundbar Lifestyle
Following up on our reports of the 2023 Vizio TVs and M-Series soundbars announced this week, it looks like Vizio is also introducing a new V-Series entry-level soundbar with little fanfare.
The Vizio V214X-K6 is a soundbar with wireless subwoofer that covers all the basics plus a few bonuses. If you desire to boost your TV sound quality without a complicated setup, then this soundbar might be just the ticket.
2023 Vizio V214X-K6 Soundbar with Subwoofer Angle
Features & Specs
Product Description: The Vizio V214X-K6 is 30-inches wide and just over 2-inches high. At this size it should fit under any TV, but will likely sound best in smaller rooms matched with TVs sized 55-inches or under.
The soundbar houses left and right channel full-range speakers. That means there isn’t a separate tweeter so high frequency response will be limited.
2023 Vizio V214X-K6 Soundbar Speaker
An additional wireless ported (bass reflex) subwoofer with a 5-inch driver is provided for bass. That’s not a huge driver as far as subwoofers go, so we’d expect limited low frequency output as well. On the plus side, its lower bass output is unlikely to disturb neighbors or people in other rooms.
2023 Vizio V214X-K6 Wireless Subwoofer
Frequency Response: 50Hz to 20kHz. The 50Hz low-frequency cut-off isn’t going to deliver really deep bass, but for an all-in-one soundbar design, it will fill out the low frequencies much better than any TV’s built-in speaker system.
SPL (Sound Pressure Level): 90dB. This provides lots of sound output to fill an average size room.
Dolby Format Support: Dolby Audio. Although it decodes Dolby Audio, there aren’t enough speaker drivers to deliver enveloping sound effects capable with more expensive Dolby Atmos enabled soundbars.
DTS Support: Virtual:X processing and DTS TruVolume (this provides more even volume levels).
EQ Sound Modes: Movie, Music, Game, Dialogue. These settings could be helpful to fine tune your listening preference based on how you use it.
Bluetooth ver 4.1: You can use Bluetooth to play music from compatible devices, such as smartphones, or connect an Amazon Echo device to access Alexa voice assistant features or play music from the echo device through the soundbar.
Tip: Ethernet/Wi-Fi connectivity is not provided thus there are no built-in smart features.
Control: IR Wireless Remote plus Control buttons on the top of the soundbar.
Voice Control: Voice control is not built-in but you can access Alexa, Google, and Siri by connecting your preferred voice assistant device via the Aux VA 3.5mm input or Bluetooth. The wired and wireless input is always active and ready for a voice command. The volume of your content is automatically lowered so you can hear voice feedback clearly.
2023 Vizio V214X-K6 Soundbar Rear Connections
Connections
  • 1 Digital optical audio input.
  • 1 Analog (3.5mm) audio input (can be used to connect the audio output of a compatible Amazon Echo or Google Home/Nest). This connection is labeled AUX VA
  • 1 USB Port – Supports .WAV and MP3 music file playback only from connected USB Flash Drives (USB port is not shown in connection photo example).
Included Accessories
  • Soundbar
  • Subwoofer
  • 2 x Power Cords (soundbar and subwoofer)
  • Quick Setup Guide
  • User Manual
  • Remote
  • Digital Optical Cable
Dimensions
  • Soundbar: 30 x 2.24 x 3.30 inches (762 x 56.9 x 83.8 mm)
  • Subwoofer (with feet): 7.68 x 8.47 x 7.68 inches (195.1 x 215.1 x 195.1 mm)
Weight
  • Soundbar 3.81lbs (1.7kg)
  • Subwoofer:  6.01lbs (2.7kg)
Price & Availability
The Vizio V214X-K6 Soundbar System is priced at $149.99 plus tax and shipping at Vizio.com. However, it’s currently listed as $184.64 at Amazon with free shipping and an expected ship date of August 3, 2022.
Interested shoppers should also consider the previous generation Vizio V-Series soundbar that’s now on sale for $123.99 at Amazon (model V21-H8R).
Related reading:
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Does Sony's advanced new wireless home theater system earn its lofty price tag?
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
