Vizio’s 2024 Soundbar Lineup Includes A Rather Affordable Surprise
For 2024 VIZIO is introducing seven new soundbars priced from $99 to $499 that easily attach to the bottom of a TV.
VIZIO SV510M08 5.1 Soundbar with Surround Speakers and Subwoofer
The soundbar market appears to be getting stronger with each new product cycle and Vizio has announced seven new entries for 2024 ranging in price from $99.00 to $499.00 USD. The most surprising development is the introduction of an entry-level model priced below $100 that supports Dolby Atmos for the first time.
Vizio 2024 Soundbars
VIZIO QuickFit
QuickFit soundbar easily mounts under a VIZIO TV.
QuickFit: This feature allows users to attach any of their soundbars to the bottom of a TV with two included thumb screws, sliding underneath the posts of the TV with just a click.
Surround Sound Format Support: Dolby Atmos, DTS:X, and Dolby Audio decoding are included with additional DTS Virtual:X processing support.
Tech Note: Keep in mind that for most of these soundbars, Dolby Atmos and DTS:X are reproduced virtually as there are no height-channel speakers (except for the Elevate SE – more on that later).
Enhanced Dialog Mode (Clear Dialog): This feature provides more even volume levels and dialog presence.
Bluetooth ver 5.2: You can use Bluetooth to play music from compatible devices, such as smartphones, or connect an Amazon Echo device to access Alexa voice assistant features or play music from the echo device through the soundbar.
HDMI-eARC: This feature passes audio from the TV to the soundbar using the HDMI-ARC/eARC connection on the TV and soundbar. This connection also allows users to use their Vizio soundbar remote to control basic TV functions, such as power, and volume. For select Vizio TVs, via HDMI-eARC the soundbar remote can access the TV’s settings menu. Also, the TV’s remote can be used to control the soundbar which eliminates the need for a secondary remote, integrating the audio control menu directly into the TV.
VIZIO SV210M-0808 Soundbar Rear Inputs
Rear inputs on VIZIO Soundbars include HDMI-eARC for one cable hookup to TVs.
Vizio Mobile App: All of the soundbars are compatible with the Vizio Mobile App (iOS, Android) which provides access to settings (including bass, treble, and speaker levels) to fine-tune your soundbar listening experience.
From John Schindler, Vizio Vice President of Product Management: “Experiencing some of your favorite movies, TV shows or live events with sound as though you are in the theater or in the center of the ac4on is what makes the new VIZIO soundbars a league all their own,…We’re proud to continue innovating what is possible with soundbar technology and ensuring customers can experience the best sound quality possible, at any price point.
Along with its technical enhancements, the 2024 VIZIO Soundbar lineup is designed to complement any interior decor; textures with satin-finished enclosures, and low physical profiles are designed to align with a TV and living space. This soundbar lineup places as much attention and care to design as it does on room-filling sound.
2024 VIZIO Soundbars
VIZIO SV200M Soundbar
VIZIO SV200M-08 2.0 Soundbar
VIZIO SV200M-08 2.0 ($99.00)
In addition to the features listed above, this entry-level model in Vizio’s soundbar is 30 inches wide and incorporates a 2-channel configuration with two full-range drivers,
VIZIO SV210X-08 2.1 SE  ($149.00)
As the immediate step-up model from the SV200M08, the SV210X08 SE packages a 2.0 channel 30-inch soundbar with two full-range drivers with a compact wireless subwoofer to deliver more impact for TV viewing.
VIZIO SV210M-08 2.1 ($169.00)
Similar to the SV210X08 SE, this soundbar package also combines a 30-inch soundbar with 2 full-range drivers but has a slightly larger wireless subwoofer for more bass impact.
VIZIO SV210D-08 All-in-One Soundbar ($129.00)
This soundbar has the distinction of receiving a 2024 iF Design Awad. It houses 2 full-range speakers and 2 integrated 3” subwoofers built right into the soundbar cabinet. If you want to save space and would like to get some subwoofer performance without the clutter of an external subwoofer, this might be a good choice for you.
VIZIO SV510X-08 5.1 SE  ($229.00)
This soundbar elevates the TV viewing experience further with the combination of a 33-inch soundbar, 3 full-range drivers, 2 low-profile surround sound speakers, and a compact wireless subwoofer with a 4.7-inch driver.
VIZIO 5SV510M-08 5.1 ($249.00)
Similar to the.SV510X-08 SE, this a 5.1-channel soundbar system that combines a 33-inch soundbar, 3 full-range drives, 2 surround sound speakers, and a wireless subwoofer that is slightly larger than the one that comes with the SE version.
VIZIO Elevate SL512X-08 SE ($499.00)
The unique feature of this soundbar is that it includes auto-rotating Adaptive Height Speakers on the ends of its 36-inch wide soundbar, 3 full-range drivers, two wireless surround speakers, and a 6-inch wireless subwoofer. The adaptive height speakers activate when Dolby Atmos content is detected. The Elevate SL512X08 SE is also a 2024 iF Design Award winner.
Comparison
VIZIO SV210X08 2.1 SE Soundbar with Subwoofer
2-Channel Soundbars
ModelSV200M-08SV210X-08 (SE)SV210M-08 SV210D-08
Channels2.02.12.12.1 All-in-One
Surround Speakers
Height Speakers
SubwooferYesYesInside Soundbar
Dolby AtmosYesYesYesYes
Dolby Audio YesYesYesYes
DTS:XYesYesYesYes
DTS Virtual:XYesYesYesYes
BluetoothYesYesYesYes
HDMI eARCYesYesYesYes
USBYesYesYesYes
Frequency Response 70Hz – 20kHz50Hz – 20kHz 45Hz – 20kHz50Hz – 20kHz
SPL95 dB96 dB96 dB96 dB
Dimensions – Soundbar (WxHxD)30 x 2.32 x 3.23 inches30 x 2.32  x  3.23 inches30 x 2.32 x 3.23 inches 34 x 2.6 x 4.7 inches
Dimensions – Subwoofer (WxHxD)6.1 x 7.15 x 10.24 inches6.59 x 7.71 x 11.07 inches
QuickFitYesYesYesYes
5-Channel Soundbars
ModelSV510M-08 SV510X-08 (SE)SL512X-08 (SE)
Channels5.15.15.1.2
Surround SpeakersYesYesYes
Height Speakers– Yes – Adaptive Rotation
SubwooferYesYesYes
DTS:XYesYesYes
BluetoothYesYesYes
HDMI eARCYesYesYes
USBYesYesYes
Frequency Response 45Hz – 20kHz50Hz – 20kHz45Hz – 20kHz
SPL 96 dB96 dB103 dB
Dimensions – Soundbar (WxHxD)33 x 2.32 x  3.23 inches33 x 2.32 x  3.23 inches36 x 2.6 x 4.8 inches
Dimensions – Surround Speaker (WxHxD)4.92 x 2.32 x 3.35 inches4.92 x 2.32 x 3.35 inches4.2 x 2.6 x 4.7 inches
Dimensions – Subwoofer (WxHxD)6.59 x 7.71 x 11.07 inches6.1 x 7.15 x 10.24 inches7.9  x 9.4  x 13.8 inches
QuickFitYesYesYes
VIZIO QuickFit Snap into place
Vizio Soundbar with QuickFit snap into place under a TV
Pricing & Availability
Customers can begin seeing select 2024 VIZIO soundbars online beginning May 13, 2024 with additional models to come in the fall.
  • SV200M 08 (2.0): $99.00
  • SV210D 08 (All-in-One): $129.00
  • SV210X 08 SE (2.1): $149.00
  • SV210M 08 (2.1): $169.00
  • SV510X 08 SE 5.1:  $229.00
  • SV510M08 5.1: $249.00
  • SL512X08 5.1.2 Elevate SE: $499.00
Tip: Check Amazon for deals on last year’s Vizio soundbars while they last.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
