Preview: 2023 Vizio M-Series M215aw-K6 Soundbar
For $299, the middle-of-the-range 2023 Vizio M-Series M215aw-K6 soundbar boasts easy set-up and Dolby Atmos, with a catch.
2023 Vizio M215AW-K6 Soundbar System
Following up on our reports on the Vizio TVs, M-Series, and V-Series soundbars announced for 2023, Vizio introduced yet another M-Series soundbar with little fanfare, the M215aw-K6. This middle-of-the-range soundbar provides affordable access to Dolby Atmos via virtual surround sound in an easy-to-set-up 2.1 channel system for under $300.
2023 Vizio M215AW-K6 Soundbar System Front
Features
Product Description: The M215aw-K6 is 36-inches wide and just over 2-inches high. The bar houses five speaker drivers within a 2.1 channel configuration. The woofer and tweeter for each of the left and right channels, plus the subwoofer driver equal 5 speakers.
Wireless Subwoofer: An external wireless subwoofer is included that features a Bass Reflex ported design with one downward-firing 5-inch Driver.
Vizio M215AW-K6 Wireless Subwoofer
Surround Sound Format Support: Although this sound bar can decode Dolby Atmos, DTS:X, Dolby Digital, and DTS 5.1 it uses DTS Virtual:X processing to approximate those formats within a 2.1 channel environment.
Tip: The M215aw-K6 does not have upfiring speakers specifically for Dolby Atmos, so DTS Virtual:X is used to produce height effects without the need for vertically firing speakers based on cues embedded in Dolby Atmos and DTS:X signals.
DTS TruVolume: This feature provides even volume levels and dialog presence.
Sound Modes: Additional preset sound modes include Movie, Music, Gaming, Direct
System Frequency Response: 50 to 20kHz
SPL (Sound Pressure Level): 100dB
Bluetooth ver 5.0: You can use Bluetooth to play music from compatible devices, such as smartphones, or connect an Amazon Echo device to access Alexa voice assistant features or play music from the echo device through the soundbar.
Tip: Ethernet and Wi-Fi connectivity are not provided, thus there are no built-in smart features.
Remote Control for Vizio M215AW-K6 Soundbar
Remote Control: A simple remote includes a function display. The soundbar is also compatible with many universal remotes and some TV remotes for access to basic functions (Volume, Mute, and Power).
Tip: The remote control includes settings for bass, treble, dialog, and subwoofer level.
Voice Control: Voice control is not built-in but you can access Alexa, Google, and Siri by connecting your preferred voice assistant device via the Aux VA 3.5mm input or Bluetooth. The wired and wireless input is always active and ready for a voice command. The volume of your content is automatically lowered so you can hear voice feedback clearly.
Vizio M215AW-K6 Soundbar Rear Connections
Connections
  • 1 HDMI 2.0 output with ARC/eARC compatibility.
  • 1 Digital optical audio input. (2-channel PCM, Dolby Digital, and DTS 5.1 compatible)
  • 2 Analog (3.5mm) audio inputs (one can be used to connect the audio output of a compatible Amazon Echo or Google Home/Nest).
  • 1 USB Port – Supports music file playback (MP3, .WAV) from connected USB Flash Drives.
Included Accessories
  • Remote Control with Batteries
  • HDMI Cable
  • Digital Optical Cable
  • Wall Mount Kit
  • Quick Setup Guide
Tip: Analog AV Cables are not included.
Dimensions
  • Soundbar (WHD): 36 x 2.24 x 3.54 inches (914.4 x 56.9 x 89.9 mm)
  • Subwoofer (with feet): 8.30 x 9.90 x 8.30 inches (210.8 x 251.5 x 210.8 mm)
Weight
  • Soundbar: 5.30lbs (2.4kg)
  • Subwoofer: 7.60lbs (3.5kg)
Price and Availability:
The Vizio M215aw-K6 2.1 Soundbar System is priced at $299.99 or less at Vizio.com and other Authorized Retailers.
Soundbar shoppers may consider the previous generation M-Series M51ax-J6 soundbar we reviewed, which includes rear speakers for $315 at Amazon.
1 Comment
1 Comment
  1. martin
    July 21, 2022 at 9:33 am
    nice product
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Does Sony's advanced new wireless home theater system earn its lofty price tag?
Before you buy a 2022 4K TV this year, take a much deeper dive into what's available and worth buying.
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
