Vivitek D963 DLP Projector
Vivitek announced the D963 1080p crossover multimedia DLP projector for the office or home theater that uses the latest video processing technologies to deliver amazing performance and impressive color reproduction.
The Vivitek D963 features a brightness level of 4500 lumens, a contrast ratio of 3000:1 (full on/off) and native resolution of 1920×1080 (1080p). The projector incorporates DLP and BrilliantColor technologies for bright, digital images, as well as Vivitek's proprietary processing technology for improved color reproduction and automatic gain control.
“The D963 multimedia projector offers the best in brightness and HD projection,” said Christopher Yang, senior product manager at Vivitek. “We've put in a lot of features that ensures the buyer will get the best picture from the projector. From the connectivity options and video and color processing technologies, the Vivitek D963 can accommodate pretty much any type of light condition and produces amazing image quality whether you're at home or in the office.”
D963 Key Features:
  • 1080p (1920×1080) Resolution
  • 4500 lumens of brightness with 3000:1 contrast ratio
  • DLP and BrilliantColor technologies from Texas Instruments
  • Connectivity options include: (two) HDMI v1.3, VGA-In, S-Video, Composite, RS-232, 12v trigger and RJ45
  • Network-ready for integration and system administration via RJ45
  • Top-loading, sliding cover for quick and easy lamp replacement
  • Keypad lock prevents accidental system adjustments
  • Weighs 7.5 pounds
Price and Availability
The Vivitek D963 DLP projector will be available October 2011 for $2,199.
Specifications:
Brightness 4500 Lumens (Typical)
Native Resolution 1080p (1920 x 1080)
Contrast Ratio 3000:1 (Full On/Off)
Lamp Life and Type ~2500/2000 Hours (Standard/Boost Mode), 300W Lamp Part # TBD
Display Type Single 0.65″ DLP Technology by Texas Instruments
Throw Ratio 1.6 to 1.92:1 (Distance/Width)
Image Size (Diagonal) 23.5″ to 282.3″ (0.6 to 7.2 m)
Projection Distance 3.3' to 32.8' (1.0 to 10.0 m)
Projection Lens F=2.5, f=23.5-28.2mm
Zoom Ratio 1.2:1 Manual Zoom/Focus Aspect Ratio 16:9 Native, 4:3 Compatible Offset 130%
Keystone Correction ±15° Vertical
Color Spectrum 16.7 Million
Horizontal Scan Rate 15, 30 to 90 KHz
Vertical Scan Rate 43 to 85 Hz
Speaker 5W Mono
Remote Control Fully Featured IR Remote with Laser Pointer and Mouse
Projection Method Table Top or Ceiling Mount (Front or Rear) Uniformity 85%
Computer Compatibility 1080p, WUXGA, SXGA+, SXGA, XGA, SVGA, VGA Resized; VESA Standards; PC and Macintosh Compatible
Video Compatibility SDTV(576i), EDTV (480p, 576p), HDTV (720p, 1080i), NTSC/NTSC 4.43, PAL B/G/H/I/M/N 60, SECAM
I/O Connection Ports HDMI v1.3 (x2), VGA-In, VGA-Out, Composite Video, Component Video, S-Video, RCA Audio-In, Mini-Jack Audio-In, Mini-Jack Audio-Out, RS-232c, RJ45, 12v Trigger, USB (Service)
Security Kensington Lock Port, Security Bar Weight 7.5 lbs (3.4kg)
Dimensions (W x H x D) 13.1″ x 4.4″ x 10″ (333 x 113 x 255 mm)
Noise Level 30dB/35dB (Standard/Boost Mode)
Power Supply: AC 100-240V, 50/60Hz
Consumption: 290W (Standard Mode), 350W (Boost Mode), <1W (Standby Mode)
Operating Temperature 41 to 104°F (5 to 40°C)
Standard Warranty 3-Year Limited Warranty, 1-Year Lamp Warranty
Standard Accessories AC Power Cord, VGA Cable, Carrying Case, Remote Control, Batteries for Remote, Lens Cap, User's Manual (CD), Warranty Card
Optional Accessories Replacement Lamp, Remote, Carrying Case
See more: Projectors, DLP Projectors, Vivitek Projectors
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
