Vivitek D8300 and H9030FD DLP Projectors
Vivitek announced two front projectors which include the H9030FD LED extreme short-throw and the D8300 large-venue crossover projectors. These will complement the current 1080p models consisting of the entry-level H1080FD, H1082, H1085; mid-level professional grade models, the H5080, H5082 and H5085; and high-end LED model H9080FD.
H9030FD Key Features/Specifications:
  • Native 1080p (1920×1080) resolution
  • LED-lamp based projection with estimated 20,000 hours of lamp life
  • 50,000:1 Contrast Ratio at 1000 ANSI Lumens
  • DLP® and BrilliantColor technologies from Texas Instruments
  • Connectivity options include: HDMI v1.3 (3x), VGA-in, Composite video, S-video, Component video
  • 3D-Ready
  • Available Summer 2011; Price TBD
D8300 Key Features/Specifications:
  • 6500 Lumens and 2000:1 Contrast Ratio
  • Advanced image processing from Gennum
  • Connectivity options include: HDMI v1.3 (2x), BNC, Component and Composite video, S-video and RS-232c
  • Built-in 1.3x zoom with manual lens shift (+/-120% vertical and +/-30% horizontal)
  • Available Fall 2011; Price TBD
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
