Car Amplifiers
Visonik V1802A Car Amplifier Announced
When you’re looking for a new amplifier that has the cleanest output with super low distortion, high efficiency, lots of usable features and still enough power to push an arsenal of woofers, check out the Visonik V1802A 2-channel class AB amplifier.
Aside from its exciting cosmetics, innovatively engineered and modernly sleek design, here are some of the features that make this amplifier second to none. It starts off with a double sided glass epoxy circuit board with full Mosfet circuitry and power supply, Variable low pass (50-250Hz) and high pass (50-250Hz) filters, Variable 0-18 dB bass boost, THD 0.05%, S/N ratio: 85dB, 3 way thermal, short and overload protection, and a variable 220mV — 8V RCA input voltage.
At 12.5 volts the unit will produce the following power: 2 x 300 watts RMS @4-ohm stereo, 2 x 600 watts RMS @2-ohm stereo, 1 x 1800 Watts Peak Power @ 4-ohm mono. The amp utilizes a series of 21 Red LED’s that make it look as hot as it performs.
There are 3 other models completing this series including a mono block, a 4-channels and another 2-channel amplifier. No matter what you’re looking for, Visonik has an amplifier to fill your needs.
Check out the V1802A and Visonik’s complete line of mobile audio products at a dealer near you so you can see and feel what you’ve been missing.
For more information, you may contact Visonik at (310) 223-0400 or you may write them at 18601 S. Susana Road, Rancho Dominguez, CA 90221 or visit them on the web at www.visonikcaraudio.com
MSRP $386.00
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
