Vincent Audio Announces the SV-237MK II Hybrid Integrated Amplifier
Vincent Audio’s SV-237MK II Hybrid Integrated Amplifier offers the best of vacuum tube and solid-state design with Bluetooth thrown in.
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Silver
Vincent Audio has announced the availability of the SV-237MK II, an update of its popular SV-237 and SV-237MK Hybrid Integrated Amplifiers.
From Steve Niemi, Director of Global Sales, Pangea Audio, LLC: “The SV-237 is one of the most successful Vincent Audio models sold across the globe…But, like all of the brand’s products, the team is constantly looking for ways to make the best at a given price even better.”
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Black Angle
Cosmetically, the front panel received an upgrade so that it resembles other models in the current lineup of Vincent Audio integrated amplifiers.
On the inside, the SV-237MK II features the company’s acclaimed hybrid design that was featured in the original SV-237, offering the rich, natural-sounding audio associated with vacuum tubes while providing the power and control of solid-state electronics.
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Inside
Tip: The SV-237MK II uses One 12AX7 (aka ECC83) and two 6N1P vacuum tubes.
SV-237MK II also adds Bluetooth 5.0, allowing listeners to wirelessly stream high-resolution audio files to the integrated amplifier from compatible devices, such as smartphones.
The  SV-237 MKII can output a lot of power (refer to specifications section below), but when used in ‘Class A‘ mode, it outputs 10 watts per channel. This gives instruments and vocals a warm, natural texture associated with solid-state electronics sold at a significantly higher price.
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Silver Angle
The integrated amp includes three analog (RCA) and two digital (1 optical/1 coaxial) audio inputs. The digital inputs are paired with a Burr-Brown PCM 5102 DAC. The DAC  is designed to bring out the best in compact discs as well as several digital file formats, such as WAV, FLAC, APE, LPCM, MP3, AAC, AC3, and WMA
Tip: The SV-237 MKII also provides separate sets of RCA Record Out and Preamp Outputs. You don’t see Record Out connections too much anymore.
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Rear
Vincent Audio SV-237MK II Hybrid Integrated Amplifier Silver Front
Specifications
  • Maximum Power Output (Class AB operation at 8 Ohms): 2 x 150 Watt (RMS)
  • Maximum Power Output (Class AB operation at 4 Ohms): 2 x 250 Watt (RMS)
  • Maximum Power Output (Pure Class A operation at 8 Ohms): 2 x 10 Watts (RMS)
  • A/B Speaker Terminals: Two sets of L/R channel speakers can be connected.
  • Headphone Output: Front panel, ¼-inch connection.
  • Control: Front panel controls, as well as a silver or black remote control, are provided, Two 12-Volt Triggers are available on the rear connection panel.
  • Voltage Selector: 110/230
  • Dimensions (WHD): 16.8 x 6 x 17 inches)
  • Weight: 45 lbs
Vincent Audio VRC-12 Remote Controls for SV-237MK II Hybrid Integrated Amplifier
Availability and Pricing
The Vincent Audio SV-237MK II is available in a black or silver finish and is priced at $2,999.95 through authorized Vincent Audio Dealers (Pangea Audio is the U.S. Distributor).
Related reading: Vincent SV-737 Hybrid Integrated Amplifier Review
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
We've been listening to a lot of integrated amplifiers over the past 12 months, and these 4 are some of the best below $3,000.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
